PESD5V0S1BLN
PESD5V0S1BLN
    BORN(伯恩)
    DFN1006
    晶体管电压抑制二极管 DFN1006 VC=12V IPP=8A PPP=100W VRWM=5V
PESD5V0S1BLN 数据手册
PESD5V0S1BLN Transinet Voltage Suppression Diode »Features ■ 100Watts peak pulse power (tp = 8/20μs) ■ Tiny DFN1006 package ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 8A (8/20μs) »Applications »Mechanical Data ■ Cell Phone Handsets and Accessories ■ DFN1006 package ■ Microprocessor based equipment ■ Molding compound flammability rating: UL 94V-0 ■ Personal Digital Assistants (PDA’s) ■ Packaging: Tape and Reel ■ Notebooks, Desktops, and Servers ■ RoHS/WEEE Compliant ■ Portable Instrumentation »Schematic & PIN Configuration DFN1006 Revision 2018 www.born-tw.com 1/4 PESD5V0S1BLN »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 100 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 8 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Conditions Min Typical Max Units 5.0 V Reverse Stand-Off Voltage VRWM Reverse Breakdown Voltage VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ 0.1 Peak Pulse Current IPP tp =8/20μs 8 A Clamping Voltage VC IPP=8A,tp=8/20μs 12 V Junction Capacitance Cj VR = 0V, f = 1MHz 18 6.5 V μA 0.5 23 pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM VC VBR VRWM IT IR I IT R VRWM VBR VC V Breakdown Voltage @ IT Test Current IPP Note:. 8/20μs pulse waveform. Revision 2018 www.born-tw.com 2/4 PESD5V0S1BLN »Typical Characteristics Figure 2: Power Derating Curve 10 110 1 100w 8/20µs waveform 0.1 0.01 0.1 1 100 10 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform 100 125 150 18 Waveform Paramters tr=8µs td=20µs 90 16 Clamping Voltage–VC (V) 100 80 Ipp 75 Figure 4: Clamping Voltage vs.Ipp 110 Percent 50 Ambient Temperature - TA (℃) 70 e-1 60 50 40 30 td=Ipp/2 20 10 14 12 10 Test Waveform Paramters tr=8µs td=20µs 8 6 4 2 0 0 5 10 15 Time (µs) 20 25 30 10 0 0 2 4 6 12 8 Peak Pulse Current–IPP (A) Revision 2018 www.born-tw.com 3/4 PESD5V0S1BLN »Outline Drawing – DFN1006 »Marking PB »Ordering information Order code PESD5V0S1BLN Revision 2018 Package DFN1006 Base qty 10k www.born-tw.com Delivery mode Tape and reel 4/4
PESD5V0S1BLN 价格&库存
很抱歉,暂时无法提供与“PESD5V0S1BLN”相匹配的价格&库存,您可以联系我们找货
PESD5V0S1BLN
    • 1+0.12050
    库存:200
    PESD5V0S1BLN
    • 1+0.07482
    • 10+0.07192
    • 100+0.06496
    • 500+0.06148
    库存:227
