Wire Wound SMD Power Inductor ‒ NR Series
Operating Temp. : -40℃ ~ +125℃ (Including self-heating)
NR
Series
FEATURES
l
Magnetically shielded structure that ensures the high-density
mounting configurations.
l
Closed magnetic circuit design reduces leakage 、Small and
low profile inductor.tal material for large current and low loss.
l
Provided in embossed carrier tape packaging for use with
automatic mounting machines.
l
% higher current rating than conventional inductors of
equal size.
APPLICATIONS
l
Smart phone.
l
LED lighting
l
Flat-screen TVs, blue-ray disc recorders,set top boxes.
l
Notebooks, desktop computers, servers,graphic cards.
l
Smart TV
PRODUCT IDENTIFICATION
. Series Name : Wire Wound SMD Power Inductor
NR
. Size Code : Dimensions
N
R
. Nominal Inductance Value :
R
NR
μH, R = . μH,
. Inductance Tolerance : N=±
DIMENSIONS
Series
(unit:mm)
A
深圳市艾本特科技有限公司
SHENZHEN IBT TECHNOLOGY CO., LTD
B
μH
%, M=±
%, K=±
C(MAX)
D
E
F
TEL : +86-755-2103-8425
Specifications subject to change without notice. Please check our website for latest TOMIISHI information.
FAX : +86-755-2103-9491
Revised
E-mail : ibt@tomiishi.com
WWW.TOMIISHI.COM
APPLICATIONS
Inductance
Part NO.
Tolerance
DCR (mΩ)
Max.
Test Condition
L (μH)
▪ NR
Isat (A)
△L/L ≦
Series
NR
-R
N
MHz/ . V
NR
-R
N
MHz/ . V
NR
-R
N
MHz/ . V
NR
- R M
MHz/ . V
±2
NR
- R M
MHz/ . V
NR
- R M
MHz/ . V
NR
- R M
MHz/ . V
NR
- R M
MHz/ . V
NR
- R M
MHz/ . V
NR
M
MHz/ . V
NR
M
MHz/ . V
NR
M
MHz/ . V
NR
M
MHz/ . V
Notes
. All test data is referenced to
°C ambient .
. Isat:DC current(A)that will cause L to drop approximately
Operating temperature range -
°C to +
% TYP .
°C(Including self - temperature rise) .
. Storage temperature and humidity range (product with tapping):-
深圳市艾本特科技有限公司
℃,RH
% Max
Revised
WWW.TOMIISHI.COM
RELIABILITY TEST
TEST ITEM
REQUIREMENTS
TEST METHODS AND REMARKS
1.
Solder on PCB to Reflow test Peak Temp. 260±5℃ 5 〜 10
secs ,Cycles :2
times..Re-flowing Profile: Please refer to Fig-1
2.
Test board thickness: 1.5mm
3.
Test board material: glass epoxy resin
4.
The specimen shall be stored at standard atmospheric conditions
for 1 hour, after which the measurement shall be made.product
Resistance to
1.
No visible mechanical damage
Soldering Heat
2.
Inductance change: Within ±5%
showed no damage under microscope.(for microscope of Shun
Yu SZM-45 20X)
Fig-
High Temperature
1.
Temperature: 125±2℃
1.
2.
Duration: 1000 hours
2.
Inductance change: Within ±10%
3.
Steady damp-heat
1.
2.
1.
Temperature:85℃
2.
Humidity: 85% RH
3.
Duration:1000 hours
4.
1.
Frequency: 10HZ〜55HZ〜10HZ/Min Cycles
Mechanical
1.
2.
Amplitude: 1.5 mm
Vibration
2.
3.
Directions: X,Y,Z
4.
Time: 2 hours in each
深圳市艾本特科技有限公司
directions (total of 6 hours)
Revised
WWW.TOMIISHI.COM
RELIABILITY TEST
TEST ITEM
REQUIREMENTS
1.
Temperature and time: -40℃ for 30±3 min→125℃ for 30±3min,
please refer to Fig-2
2.
Transforming interval: Max. 3 Min
3.
Tested cycle: 1000 cycles
4.
Thermal Shock
1.
2.
Fig-
Salt Spray
1.
Salt concentration: (5 ± 1)% (mass percent)
2.
pH value:6.5 - 7.2
3.
Temperature: 35 ± 2 ℃
1.
4.
humidity: 85%
2.
5.
time: 24 hours
6.
in normal temperature and humidity for 1 〜 2 hours, testing
inductance, the inductance value change can not be more than
before test ± 10%.
1.
The electrode of the inductor is soldered to the PCB, to Fig-3 Then
apply a force in the X direction of the arrow.
2.
10N force.
3.
Keep time: 10(±1)s
4.
The first three tests were OK, and the force was applied until the
peak value of the product peeling. The test speed was set in the
Terminal Strength
1.
The peak thrust is greater than
range of
3 ~ 8mm/min.
10N
Fig-
深圳市艾本特科技有限公司
Revised
WWW.TOMIISHI.COM
PACKAGING INFORMATION
REEL DIMENSION (mm)
TAPING DIMENSIONS (mm)
Type
Series
NR
Tape dimensions (mm)
W
P
P0
P2
D0
D1
T
A0
B0
K0
E
F
8.0
4.0
4.0
2.0
1.50
1.00
0.20
2.40
2.85
1.40
1.75
3.50
±0.1
±0.1
±0.1
±0.05
±0.1
±0.05
±0.05
±0.1
±0.1
±0.1
±0.1
±0.05
PACKAGING QUANTITY (Standard)
Type
NR
Reel
Inner Box
pcs / Reel
Reel / Box (
Carton Box
pcs)
Middle boxes (
pcs)
PEEL FORCE OF TOP COVER TAPE
The peel speed shall be about
mm/minute
The peel force of top cover tape shall be between . to . N
深圳市艾本特科技有限公司
Revised
WWW.TOMIISHI.COM
很抱歉,暂时无法提供与“NR252012-3R3M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.18150
- 100+0.16500
- 500+0.14850
- 1000+0.13200
- 2000+0.12100
- 4000+0.11770
