Molded SMD Power Inductor - TOM Series
Operating Temp. : -55℃ ~ +125℃ (Including self-heating)
TOM
Series
FEATURES
l
Halogen Free ,ROHS compliance.
l
High rated current.
l
Low loss realized with low DCR.
l
Low core loss.
l
℃ maximum total temperature operation.
l
Ultra low buzz noise due to molding construction.
l
High performance (Isat) realized by metal dust core.
APPLICATIONS
l
Laptops and PCs
l
Base stations
l
DC/DC converter
l
SSD modules
l
Battery powered devices
l
Switch and servers
PRODUCT IDENTIFICATION
. Series Name : Molded SMD Power Inductor
TOM
R
M
. Size Code : Dimensions
(unit:mm)
. Nominal Inductance Value : R
. Inductance Tolerance : N=±
μH, R = . μH,
%, M=±
μH
DIMENSIONS
MARKING
B
E
C
A
D
Series
TOM
A
B
C
D
E
RECOMMEND LAND PATTERN
a
c
b
深圳市艾本特科技有限公司
SHENZHEN IBT TECHNOLOGY CO., LTD
Series
TOM
a typ
b typ
c typ
TEL : +86-755-2103-8425
Specifications subject to change without notice. Please check our website for latest TOMIISHI information.
FAX : +86-755-2103-9491
Revised
E-mail : ibt@tomiishi.com
WWW.TOMIISHI.COM
APPLICATIONS
Inductance
Part NO.
▪ TOM
Test Condition
L (μH)
Tolerance
DCR (mΩ)
Isat (A)
Irms (A)
Max.
Typ.
Typ.
Series
TOM
-R
M
kHz/ V
TOM
-R
M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
- R M
kHz/ V
TOM
M
kHz/ V
TOM
M
kHz/ V
TOM
M
kHz/ V
TOM
M
kHz/ V
TOM
M
kHz/ V
Notes
All test data is referenced to
°C ambient
Operating temperature range -
Irms (A):DC current (A) that will cause an approximate ΔT of
Isat(A):DC current (A) that will cause L to drop approximately
The part temperature (ambient + temp rise) should not exceed
°C to +
°C
°C(reference ambient temperature is
°C)
°C under worst case operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
深圳市艾本特科技有限公司
Revised
WWW.TOMIISHI.COM
MECHANICAL RELIABILITY
TEST ITEM
SPECIFICATION
TEST DETAILS
1. Acceleration : 100G
Mechanical shock
1. No case deformation or change in
2. Pulse time : 6ms
apperarance
3. Direction : ±X ±Y ±Z
2. △L/Lo≦±10%
4. 3 times in each positive and negative direction of
3 mutual perpendicular directions
. Reflow : times
Mechanical
vibration
apperarance
. △L/Lo≦±
. Frequency :
. Amplitude : .
HZ〜
HZ,
Min/Cycles
mm
. Directions : X,Y,Z
. Time :
Solderability
HZ〜
apperarance
cycle / direction
. Preheat:
S± S
. Tin : lead-free.
. New solder coverage More than
. Temperature :
℃± ℃,flux . S± . S.
ENDURANCE RELIABILITY
TEST ITEM
SPECIFICATION
TEST DETAILS
. First -
℃ for
minutes,last
Go through
℃ for
minutes as
cycles
. Max transfer time is
minutes
. Measured at room temperature after placing for
Inductance change :
Thermal Shock
Within ±
NO.
Temperature
% Without distinct
damage in appearance
± ℃(Themostat No. )
Standard atmospheric
Resistance
Low temperature
storage
High temperature
storage
Inductance change :
Within ±
% Without distinct
Inductance change :
Within ±
% Without distinct
Inductance change :
Within ±
% Without distinct
深圳市艾本特科技有限公司
± hours
Duration
min.
Within
minutes
No. →No.
± ℃(Themostat No. )
Humidity
cycle.
min.
Within
minutes
No. →No.
1. Reflow 2 times
2. 85℃,85%RH,1000 hours
3. Measured at room temperature after placing for 24±2 hours
. Temperature : . Time :
hours
. Temperature : +
. Time :
hours
± hours
Revised
± hours
WWW.TOMIISHI.COM
PACKAGING INFORMATION
REEL DIMENSION (mm)
TOMIISHI
Thickness
330
Max
Tape width
TAPING DIMENSIONS (mm)
Type
Tape dimensions (mm)
Series
TOM0650
W
P
P0
P2
D0
D1
T
A0
B0
K0
E
F
16
12
4
2
1.5
1.5
0.4
6.9
7.5
5.4
1.75
7.5
±0.3
±0.1
±0.1
±0.1
±0.1
±0.1
±0.05
±0.1
±0.1
±0.1
±0.1
±0.1
PACKAGING QUANTITY (Standard)
Type
Reel
TOM
Inner Box
pcs / Reel
Reel / Box (
Carton Box
pcs)
Middle boxes (
pcs)
PEEL FORCE OF TOP COVER TAPE
The peel speed shall be about
mm/minute
The peel force of top cover tape shall be between . to . N
深圳市艾本特科技有限公司
Revised
WWW.TOMIISHI.COM
很抱歉,暂时无法提供与“TOM0650-150M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59400
- 20+0.54000
- 100+0.48600
- 500+0.43200
- 1000+0.40680
- 2000+0.38880
