AGP2401
AGP2401
    AGMSEMI(芯控源)
    TO46-4
    温湿度传感器 TO46 0.1mA 0.06%
AGP2401 数据手册
AGP2401 Specification Thermopile Sensor P2401 Specification: 1) MEMS Thermopile element 2) TO-46 Package 3) High sensitivity 4) 5.5μm LWP Filter 5) High accuracy NTC Applications: 1) Non-contact temperature measurements 2) Ear thermometers、Forehead thermometer 3) Continuous temperature control of manufacturing 4) Consumer applications 5) Home appliance temperature measurement Model: P2401 Prepared by Chen Qiao Date 2019.01.21 Version 2.0 www.agm-mos.com Reviewed by Approved by Allen Li Allen Li 2019.01.21 1 2019.01.21 VER2.0 AGP2401 Absolute Maximum Ratings: Parameter Operating temperature Storage Temperature Performance specifications: Parameter Chip size Sensitive area Field of view Thermopile resistance Noise voltage NEP Responsivity Temp. coefficient of resistance Time constant Specific detectivity Thermistor resistance Thermistor BETA-value www.agm-mos.com Value -30 to +100 °C -40 to +125 °C Value 1.1 X1.1 0.85 X 0.85 112 Unit Operating temperature Storage Temperature Unit mm mm o 350±20% kΩ 60±2 nV/Hz1/2 nW/Hz1/2 V/W 0.44 125 0.06 %/℃ 15 0.63 E08 ms cmHz1/2/W KΩ 100 ± 3% K 3950 ± 1% 2 Conditions At 50 % intensity points temp=25℃ temp=25℃ 500K, 1Hz 500K, 5.5μm, long pass) temp=25℃-75℃ 500K, 1Hz 25℃ 25℃/50℃ VER2.0 AGP2401 Typical performance curves: Optical characteristics: Parameter Field of view www.agm-mos.com Value 112 Unit o 3 Description 50% Maximum signal VER2.0 AGP2401 Filter specifications: Parameter Transmission Range Transmission Value 5.5 Unit μm Description Long wave pass 1 % <5μm ≥75 Transmission blocking average % Average 5.5-14μm Electrical connections: Pin Define 1 Thermopile+ 2 NTC 3 Thermopile- 4 GND Temperature vs. Resistance of NTC: Temperature (℃) www.agm-mos.com R -40 (KΩ) 3305.055 -39 -38 Temperature (℃) R 2 (KΩ) 294.436 3094.400 3 2898.555 4 -37 2716.384 -36 Temperature (℃) R 44 (KΩ) 45.329 280.035 45 266.422 46 5 253.549 2546.847 6 -35 2388.988 -34 2241.930 -33 Temperature (℃) R 86 (KΩ) 10.237 43.575 87 9.917 41.898 88 9.608 47 40.293 89 9.310 241.372 48 38.758 90 9.022 7 229.849 49 37.289 91 8.745 8 218.942 50 35.882 92 8.478 2104.867 9 208.614 51 34.541 93 8.219 -32 1977.057 10 198.832 52 33.257 94 7.970 -31 1857.820 11 189.563 53 32.027 95 7.730 -30 1746.527 12 180.778 54 30.849 96 7.497 -29 1642.601 13 172.449 55 29.721 97 7.273 -28 1545.510 14 164.550 56 28.639 98 7.057 4 VER2.0 AGP2401 -27 1454.762 15 157.056 57 27.602 99 6.847 -26 1369.905 16 149.945 58 26.608 100 6.645 -25 1290.522 17 143.195 59 25.654 101 6.450 -24 1216.226 18 136.785 60 24.740 102 6.261 -23 1146.661 19 130.698 61 23.862 103 6.079 -22 1081.498 20 124.914 62 23.020 104 5.902 -21 1020.433 21 119.417 63 22.212 105 5.732 -20 963.184 22 114.191 64 21.436 106 5.567 -19 909.235 23 109.223 65 20.691 107 5.408 -18 858.642 24 104.497 66 19.976 108 5.253 -17 811.174 25 100.000 67 19.289 109 5.104 -16 766.621 26 95.721 68 18.628 110 4.960 -15 724.787 27 91.647 69 17.994 111 4.820 -14 685.489 28 87.768 70 17.384 112 4.685 -13 648.559 29 84.073 71 16.798 113 4.554 -12 613.841 30 80.554 72 16.234 114 4.428 -11 581.189 31 77.199 73 15.692 115 4.305 -10 550.469 32 74.002 74 15.170 116 4.187 -9 521.554 33 70.954 75 14.668 117 4.072 -8 494.330 34 68.046 76 14.186 118 3.960 -7 468.686 35 65.273 77 13.721 119 3.852 -6 444.523 36 62.627 78 13.274 120 3.748 -5 421.747 37 60.101 79 12.843 121 3.647 -4 400.269 38 57.690 80 12.429 122 3.549 -3 380.010 39 55.388 81 12.029 123 3.454 -2 360.893 40 53.189 82 11.643 124 3.362 -1 342.847 41 51.089 83 11.272 125 3.272 0 325.806 42 49.082 84 10.914 1 309.674 43 47.163 85 10.570 V-T Form (35°C-41°C) T_AMB=22.3℃ T_OBJ Vout T_OBJ Vout T_OBJ Vout T_OBJ Vout T_OBJ Vout T_OBJ Vout 35 1.082 36.1 1.184 37.1 1.277 38.1 1.370 39.1 1.463 40.1 1.555 35.1 1.091 36.2 1.193 37.2 1.286 38.2 1.379 39.2 1.472 40.2 1.565 35.2 1.100 36.3 1.202 37.3 1.295 38.3 1.388 39.3 1.481 40.3 1.574 35.3 1.110 36.4 1.212 37.4 1.305 38.4 1.398 39.4 1.490 40.4 1.583 35.4 1.119 36.5 1.221 37.5 1.314 38.5 1.407 39.5 1.500 40.5 1.593 35.5 1.128 36.6 1.230 37.6 1.323 38.6 1.416 39.6 1.509 40.6 1.602 35.6 1.137 36.7 1.240 37.7 1.333 38.7 1.425 39.7 1.518 40.7 1.611 35.7 1.147 36.8 1.249 37.8 1.342 38.8 1.435 39.8 1.528 40.8 1.621 35.8 1.156 36.9 1.258 37.9 1.351 38.9 1.444 39.9 1.537 40.9 1.630 35.9 1.165 37 www.agm-mos.com 1.268 38 1.360 5 39 1.453 40 1.546 41 1.639 VER2.0 AGP2401 Mechanical dimensions: www.agm-mos.com 6 VER2.0 AGP2401 AGM6014A Disclaimers: Information furnished in this document is believed to be accurate and reliable. However, Shenzhen Core Control Source Semiconductor Co., Ltd. assumes no responsibility for the consequences of use without consideration for such information nor use beyond it. Information mentioned in this document is subject to change without notice, apart from that when an agreement is signed, Shenzhen core control source complies with the agreement. Products and information provided in this document have no infringement of patents. Shenzhen Core Control Source Semiconductor Co., Ltd. assumes no responsibility for any infringement of other rights of third parties which may result from the use of such products and information. This document is the first version which is made in 12-Apr-18. This document supersedes and replaces all information previously supplied. is a registered trademark of Shenzhen Core Control Source Semiconductor Co., Ltd. Copyright ©2019 Shenzhen Core Control Source Semiconductor Co., Ltd. Printed All rights reserved. www.agm-mos.com 7 VER2.0
AGP2401 价格&库存
很抱歉,暂时无法提供与“AGP2401”相匹配的价格&库存,您可以联系我们找货
AGP2401
