PMEG4020EPK
40 V, 2 A low VF MEGA Schottky barrier rectifier
11 February 2014
Product data sheet
1. General description
Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with
an integrated guard ring for stress protection, encapsulated in a leadless ultra small
DFN1608D-2 (SOD1608) Surface-Mounted Device (SMD) plastic package with visible
and solderable side pads.
2. Features and benefits
Average forward current: IF(AV) ≤ 2 A
Reverse voltage: VR ≤ 40 V
Low forward voltage VF ≤ 660 mV
Low reverse current
AEC-Q101 qualified
Solderable side pads
Package height typ. 0.37 mm
Ultra small and leadless SMD plastic package
3. Applications
Low voltage rectification
High efficiency DC-to-DC conversion
Switch mode power supply
LED backlight for mobile application
Low power consumption applications
Ultra high-speed switching
Reverse polarity protection
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF(AV)
average forward
current
δ = 0.5; f = 20 kHz; Tsp ≤ 130 °C;
2
A
2
A
square wave
δ = 0.5; f = 20 kHz; Tamb ≤ 25 °C;
[1]
square wave
VR
reverse voltage
Tj = 25 °C
40
V
VF
forward voltage
IF = 2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02;
585
660
mV
Tj = 25 °C
PMEG4020EPK
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IR
reverse current
VR = 10 V; Tj = 25 °C
1
5
µA
trr
reverse recovery time
IR = 0.5 A; IF = 0.5 A; IR(meas) = 0.1 A;
4
ns
Tj = 25 °C
[1]
Device mounted on a ceramic Printed-Circuit Board (PCB), Al2O3, standard footprint.
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
K
2
A
Simplified outline
Graphic symbol
cathode[1]
1
1
anode
2
2
sym001
Transparent top view
[1]
The marking bar indicates the cathode.
6. Ordering information
Table 3.
Type number
PMEG4020EPK
PMEG4020EPK
Product data sheet
Package
Name
Description
Version
DFN1608D-2
DFN1608D-2: leadless ultra small plastic package; 2 terminals
SOD1608
All information provided in this document is subject to legal disclaimers.
11 February 2014
Nexperia B.V. 2017. All rights reserved
2 / 15
PMEG4020EPK
Nexperia
7. Marking
Table 4.
Marking codes
Type number
Marking code
PMEG4020EPK
0001 0000
VENDOR CODE
CATHODE BAR
READING DIRECTION
READING EXAMPLE:
0111
1011
MARKING CODE
(EXAMPLE)
READING DIRECTION
006aac909
Fig. 1.
SOD1608 binary marking code description
PMEG4020EPK
Product data sheet
11 February 2014
3 / 15
PMEG4020EPK
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VR
reverse voltage
Tj = 25 °C
40
V
IF
forward current
Tsp ≤ 125 °C
2.83
A
IF(AV)
average forward current
2
A
2
A
square wave
[1]
square wave
IFRM
repetitive peak forward current
tp ≤ 1 ms; δ ≤ 0.25
4
A
IFSM
non-repetitive peak forward
current
tp = 8 ms; Tj(init) = 25 °C; square wave
5
A
Ptot
total power dissipation
Tamb ≤ 25 °C
[2]
415
mW
[3]
895
mW
[1]
1565
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
thermal resistance
from junction to solder
point
[1]
[2]
[3]
[4]
[5]
PMEG4020EPK
Product data sheet
Min
Typ
Max
Unit
[1][2]
300
K/W
[1][3]
140
K/W
[1][4]
80
K/W
[5]
K/W
For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse
power losses PR are a significant part of the total power losses.
2
Device mounted on a ceramic PCB, Al2O3, standard footprint.
Soldering point of cathode tab.
11 February 2014
4 / 15
PMEG4020EPK
Nexperia
006aad035
103
Zth(j-a)
(K/W)
duty cycle =
0.75
1
0.5
102
0.33
0.2
0.25
0.1
0.05
0.02
0.01
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
006aad036
103
Zth(j-a)
(K/W)
duty cycle =
102
0.75
1
0.5
0.33
0.2
0.25
0.1
0.05
10
10-3
0.01
10-2
10-1
FR4 PCB, mounting pad for cathode 1 cm
Fig. 3.
1
10
102
tp (s)
103
2
PMEG4020EPK
Product data sheet
11 February 2014
5 / 15
PMEG4020EPK
Nexperia
006aad037
102
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
0.25
0.2
0.1
0.05
0.02
0.01
10-3
10-2
10-1
1
102
10
103
tp (s)
Ceramic PCB, Al2O3, standard footprint
Fig. 4.
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VF
forward voltage
IF = 100 mA; pulsed; tp ≤ 300 µs;
330
380
mV
415
480
mV
490
550
mV
585
660
mV
1
5
µA
VR = 40 V; Tj = 25 °C
8
30
µA
VR = 1 V; f = 1 MHz; Tj = 25 °C
75
90
pF
VR = 10 V; f = 1 MHz; Tj = 25 °C
30
40
pF
IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A;
4
ns
440
mV
δ ≤ 0.02; Tj = 25 °C
IF = 500 mA; pulsed; tp ≤ 300 µs;
IF = 1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02;
Tj = 25 °C
Tj = 25 °C
IR
Cd
trr
reverse current
diode capacitance
Tj = 25 °C
VFRM
peak forward recovery
voltage
PMEG4020EPK
Product data sheet
IF = 0.5 A; dIF/dt = 20 A/µs; Tj = 25 °C
11 February 2014
6 / 15
PMEG4020EPK
Nexperia
006aad038
10
IR
(A)
IF
(A)
1
(1)
10-3
(2)
(1)
10-4
(2)
10-1
006aad039
10-2
(3)
(4)
10-5
(5)
(3)
10-6
10-2
10-7
10-8
10-3
(4)
10-9
10-4
0.0
0.3
0.6
VF (V)
10-10
0.9
10
(1) Tj = 150 °C
(1) Tj = 125 °C
(2) Tj = 125 °C
(2) Tj = 85 °C
(3) Tj = 85 °C
(3) Tj = 25 °C
(4) Tj = 25 °C
(4) Tj = −40 °C
(5) Tj = −40 °C
Fig. 5.
Fig. 6.
006aad040
006aad063
2.0
Cd
(pF)
(4)
PF(AV)
(W)
120
40
VR (V)
Reverse current as a function of reverse
voltage; typical values
Forward current as a function of forward
150
30
1.5
(3)
90
(2)
1.0
(1)
60
0.5
30
Fig. 7.
VR (V)
f = 1 MHz; Tamb = 25 °C
Tj = 150 °C
Diode capacitance as a function of reverse
(1) δ = 0.1
(2) δ = 0.2
(3) δ = 0.5
(4) δ = 1
Fig. 8.
PMEG4020EPK
Product data sheet
1.5
IF(AV) (A)
2.25
Average forward power dissipation as a
function of average forward current; typical
values
11 February 2014
0.75
7 / 15
PMEG4020EPK
Nexperia
006aad042
0.20
006aad064
2.25
PR(AV)
(W)
IF(AV)
(A)
0.15
1.50
(1)
(2)
0.10
(3)
(1)
0.75
0.00
(4)
(4)
VR (V)
Tj = 125 °C
50
75
100
125
150
175
Tamb (°C)
Tj = 150 °C
(1) δ = 1
(2) δ = 0.9
(3) δ = 0.8
(4) δ = 0.5
Fig. 9.
(2)
(3)
0.05
Average reverse power dissipation as a
function of reverse voltage; typical values
(1) δ = 1 (DC)
(2) δ = 0.5; f = 20 kHz
(3) δ = 0.2; f = 20 kHz
(4) δ = 0.1; f = 20 kHz
Fig. 10. Average forward current as a function of
ambient temperature; typical values
006aad065
3
006aad066
3
IF(AV)
(A)
(1)
IF(AV)
(A)
(1)
2
2
(2)
(2)
(3)
(4)
1
(3)
1
(4)
50
75
100
125
175
Tamb (°C)
Tj = 150 °C
Product data sheet
50
75
100
125
150
175
Tamb (°C)
Tj = 150 °C
(1) δ = 1 (DC)
(1) δ = 1 (DC)
PMEG4020EPK
25
2
Fig. 11. Average forward current as a function of
Fig. 12. Average forward current as a function of
11 February 2014
8 / 15
PMEG4020EPK
Nexperia
006aad067
3
(1)
IF(AV)
(A)
2
(2)
(3)
1
(4)
50
75
100
125
150
175
Tamb (°C)
Tj = 150 °C
(1) δ = 1 (DC)
Fig. 13. Average forward current as a function of solder point temperature; typical values
11. Test information
IF
IR(meas)
time
IR
trr
006aad022
Fig. 14. Reverse recovery definition
PMEG4020EPK
Product data sheet
11 February 2014
9 / 15
PMEG4020EPK
Nexperia
IF
time
VF
VFRM
VF
time
001aab912
Fig. 15. Forward recovery definition
P
tcy
duty cycle δ =
tp
tcy
tp
t
006aac658
Fig. 16. Duty cycle definition
The current ratings for the typical waveforms are calculated according to the equations:
IF(AV) = IM × δ with IM defined as peak current, IRMS = IF(AV) at DC, and IRMS = IM × √δ with
IRMS defined as RMS current.
11.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PMEG4020EPK
Product data sheet
11 February 2014
10 / 15
PMEG4020EPK
Nexperia
12. Package outline
0.85
0.75
1
0.40
0.34
0.80
0.72
1.65
1.55
0.40
0.32
2
0.75
0.67
0.04
Dimensions in mm
11-11-21
Fig. 17. Package outline DFN1608D-2 (SOD1608)
13. Soldering
Footprint information for reflow soldering of DFN1608D-2 package
SOD1608
1.15
0.75
1.05
0.65
0.95
0.55
0.9 0.8 0.7
0.7 0.8 0.9
1
2
0.1
1.8
0.2
1.9
2.0
solder land
solder land plus solder paste
solder paste deposit
solder resist
Dimensions in mm
sod1608_fr
Fig. 18. Reflow soldering footprint for DFN1608D-2 (SOD1608)
PMEG4020EPK
Product data sheet
11 February 2014
11 / 15
PMEG4020EPK
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMEG4020EPK v.2
20140211
Product data sheet
PMEG4020EPK v.1
Modifications:
PMEG4020EPK v.1
20120425
PMEG4020EPK
Product data sheet
Marking code corrected
Product data sheet
11 February 2014
12 / 15
PMEG4020EPK
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PMEG4020EPK
Product data sheet
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
11 February 2014
13 / 15
PMEG4020EPK
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PMEG4020EPK
Product data sheet
11 February 2014
14 / 15
PMEG4020EPK
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 3
8
Limiting values .......................................................4
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 6
11
11.1
Test information ..................................................... 9
Quality information ............................................. 10
12
Package outline ................................................... 11
13
Soldering .............................................................. 11
14
Revision history ................................................... 12
15
15.1
15.2
15.3
15.4
Legal information .................................................13
Data sheet status ............................................... 13
Definitions ...........................................................13
Disclaimers .........................................................13
Trademarks ........................................................ 14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 February 2014
PMEG4020EPK
Product data sheet
11 February 2014
15 / 15
