BZT52C27S
BZT52C27S
    BLUECOLOUR(蓝彩电子)
    SOD323
    稳压二极管 Vz=27V 25.1V~28.9V Izt=2mA P=200mW SOD323
BZT52C27S 数据手册
SOD-323 Plastic-Encapsulate Diodes BZT52C2V4S-BZT52C75S ZENER DIODE FEATURES z Planar die construction z 200mW power dissipation on ceramic PCB z General purpose, medium current z Ideally suited for automated assembly processes z Available in lead free version ur PINNING DESCRIPTION 1 Cathode 2 Anode lo PIN 2 Top View Simplified outline SOD-323 and symbol bl ue co 1 Maximum Ratings (Ta=25℃ unless otherwise specified ) Characteristic Forward Voltage (Note 2) @ IF = 10mA Power Dissipation(Note 1) Symbol Value Unit VF 0.9 V PD 200 mW Thermal Resistance from Junction to Ambient RθJA 625 Junction Temperature Tj Tstg ℃/W ℃ -55~+150 Storage Temperature Range Page 1 of 5 150 ℃ REV02: 11/2021 Electrical Characteristics(Ta = 25℃ unless otherwise specified ) Maximum Zener Impedance (Note 3) Zener Voltage Range (Note 2) TYPE Marking VZ@IZT Nom(V) Min(V) IZT Max(V) ZZT@IZT (mA) ZZK@IZK Ω IZK (mA) Maximum Reverse Current (Note 2) IR μA Typical Temperature Coefficient @IZTC mV/℃ Test Current IZTC VR V Min Max mA 0W 2.0 1.80 2.15 5 100 600 1.0 90 1.0 -3.5 0 5 W0 2.4 2.20 2.60 5 100 600 1.0 50 1.0 -3.5 0 5 BZT52C2V7S W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 BZT52C3V0S W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 BZT52C3V3S W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 BZT52C3V6S W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 BZT52C3V9S W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V3S W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V7S W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 BZT52C5V1S W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 BZT52C5V6S W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2 2.5 5 BZT52C6V2S WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 BZT52C6V8S WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 BZT52C7V5S WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 BZT52C8V2S WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52C9V1S WE 9.1 8.5 BZT52C10S WF 10 9.4 BZT52C11S WG 11 10.4 BZT52C12S WH 12 11.4 BZT52C13S WI 13 12.4 15 16 WJ BZT52C16S WK 15 100 1.0 0.5 6.0 3.8 7.0 5 5 20 150 1.0 0.2 7.0 4.5 8.0 5 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13 5 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14 5 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16 5 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 co l 5 10.6 ue BZT52C15S 9.6 ou r BZT52C2V0S BZT52C2V4S WL BZT52C20S WM BZT52C22S WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52C24S WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52C27S WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52C30S WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52C33S WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52C36S WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52C39S WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52C43S WU 43 40.0 46.0 2.5 130 500 1.0 2.0 33.0 10.0 12.0 2.5 BZT52C47S WV 47 44.0 50.0 2.5 150 500 1.0 2.0 36.0 10.0 12.0 2.5 BZT52C51S WW 51 48.0 54.0 2.5 180 500 1.0 1.0 39.0 10.0 12.0 2.5 BZT52C56S WX 56 52.0 60.0 2.5 180 500 1.0 1.0 43.0 10.0 12.0 2.5 BZT52C62S WY 62 58.0 66.0 2.5 200 500 1.0 0.2 47.0 10.0 12.0 2.5 BZT52C68S WZ 68 64.0 72.0 2.5 250 500 1.0 0.2 52.0 10.0 12.0 2.5 BZT52C75S ZA 75 70.0 79.0 2.5 300 500 1.0 0.2 57.0 10.0 12.0 2.5 bl BZT52C18S Notes: 1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2 . 2. Short duration test pulse used to minimize self-heating effect. 3. f = 1kHz. Page 2 of 5 REV02: 11/2021 Typical Characteristics 50 250 200 150 100 C3V3 C5V6 C4V7 C6V8 C6V2 C8V2 20 Test Current IZ 5.0mA 10 25 75 50 100 125 150 co C12 C15 ue C18 Test current IZ 2mA C22 10 C27 Test current IZ 5mA bl C33 C36 30 10 20 VZ, ZENER VOLTAGE (V) Fig. 3 Zener Breakdown Characteristics IZ, ZENER CURRENT (mA) 0 2 3 4 5 6 8 9 7 VZ, ZENER VOLTAGE (V) Fig. 2 Zener Breakdown Characteristics ur 10 C10 20 1 Tj = 25°C C39 8 6 4 Test Current IZ 2mA 2 0 40 C43 30 40 50 60 70 80 90 100 VZ, ZENER VOLTAGE (V) Fig. 4 Zener Breakdown Characteristics 10 20 C47 C51 C56 C62 Test Current IZ 2.5mA C68 C75 VZ, ZENER VOLTAGE (V) Fig. 5 Zener Breakdown Characteristics Page 3 of 5 10 lo Tj = 25°C 0 IZ, ZENER CURRENT (mA) 30 IZ, ZENER CURRENT (mA) C3V9 0 0 TA, AMBIENT TEMPERATURE (°C) Fig. 1 Power Dissipation vs Ambient Temperature 0 C2V7 30 50 0 Tj = 25°C 40 IZ, ZENER CURRENT (mA) PD, P OWERDISSIPATION(mW) 300 REV02: 11/2021 PACKAGE OUTLINE Plastic surface mounted package; 2 leads bl ue co lo ur SOD-323 Page 4 of 5 REV02: 11/2021 DISCLAIMER ● Before you use our Products, you are requested to carefully read this document and fully understand its contents. BLUECOLOUR shall not be in any way responsible or liable for failure, malfunction or accident arising from the use of any BLUECOLOUR's Products against warning, caution or note contained in this document. ● All information contained in this document is current as of the issuing date and subject to change without any prior notice. Before purchasing or using BLUECOLOUR's Products,please confirm the latest information with a BLUECOLOUR sales representative. Page 5 of 5 REV02: 11/2021
BZT52C27S 价格&库存
很抱歉,暂时无法提供与“BZT52C27S”相匹配的价格&库存,您可以联系我们找货
