TSL1410R
1280 × 1 LINEAR SENSOR ARRAY WITH HOLD
r
r
D
D
D
D
D
D
D
D
D
D
D
TAOS043E − APRIL 2007
1280 × 1 Sensor-Element Organization
400 Dot-Per-Inch (DPI) Sensor Pitch
High Linearity and Uniformity
Wide Dynamic Range . . . 4000:1 (72 dB)
Output Referenced to Ground
Low Image Lag . . . 0.5% Typ
Operation to 8 MHz
Single 3-V to 5-V Supply
Rail-to-Rail Output Swing (AO)
No External Load Resistor Required
Replacement for TSL1410
(TOP VIEW)
1
2
3
4
5
6
7
8
9
10
11
12
13
Description
The TSL1410R linear sensor array consists of two
sections of 640 photodiodes, each with
associated charge amplifier circuitry, aligned to
form a contiguous 1280 × 1 pixel array. The device
incorporates a pixel data-hold function that
provides simultaneous-integration start and stop
times for all pixels. The pixels measure 63.5 μm by
55.5 μm with 63.5-μm center-to-center spacing
and 8-μm spacing between pixels. Operation is
simplified by internal logic that requires only a
serial-input (SI) pulse and a clock.
VPP
SI1
HOLD1
CLK1
GND
AO1
SO1
SI2
HOLD2
CLK2
SO2
AO2
VDD
The device is intended for use in a wide variety of applications including mark and code reading, OCR and
contact imaging, edge detection and positioning, and optical encoding.
Functional Block Diagram (each section)
Pixel 1
(641)
Pixel
2
(642)
1 Integrator
Reset
2
S1
_
2
1
Pixel
3
(643)
Pixel
640
(1280)
13
Analog
Bus
3
Output
Buffer
6, 12
VDD
AO
S2
Sample/Hold/
Output
5
Gain
Trim
Switch Control Logic
7, 11
Hold
CLK
SI
3, 9
Hold
Q1
4, 10
Q2
GND
Q3
SO
Q640 (Q1280)
640-Bit Shift Register (2 each)
2, 8
The LUMENOLOGY r Company
Copyright E 2007, TAOS Inc.
r
Texas Advanced Optoelectronic Solutions Inc.
1001 Klein Road S Suite 300 S Plano, TX 75074 S (972)
r 673-0759
www.taosinc.com
1
TSL1410R
Terminal Functions
TERMINAL
NAME
NO.
I/O
DESCRIPTION
AO1
6
O
Analog output, section 1.
AO2
12
O
Analog output, section 2.
CLK1
4
I
Clock, section 1. CLK1 controls charge transfer, pixel output, and reset.
CLK2
10
I
Clock, section 2. CLK2 controls charge transfer, pixel output, and reset.
GND
5
HOLD1
3
I
Hold signal. HOLD1 shifts pixel data to parallel buffer. HOLD1 is normally connected to SI1 and HOLD2 in
serial mode and to SI1 in parallel mode.
HOLD2
9
I
Hold signal. HOLD2 shifts pixel data to parallel buffer. HOLD2 is normally connected to SI2 in parallel mode.
SI1
2
I
Serial input (section 1). SI1 defines the start of the data-out sequence.
SI2
8
I
Serial input (section 2). SI2 defines the start of the data-out sequence.
SO1
7
O
Serial output (section 1). SO1 provides a signal to drive the SI2 input in serial mode.
SO2
11
O
Serial output (section 2). SO2 provides a signal to drive the SI input of another device for cascading or as an
end-of-data indication.
VDD
13
Supply voltage for both analog and digital circuitry.
VPP
1
Normally grounded.
Ground (substrate). All voltages are referenced to GND.
Detailed Description
The sensor consists of 1280 photodiodes, called pixels, arranged in a linear array. Light energy impinging on a pixel
generates photocurrent that is then integrated by the active integration circuitry associated with that pixel.
During the integration period, a sampling capacitor connects to the output of the integrator through an analog switch. The
amount of charge accumulated at each pixel is directly proportional to the light intensity on that pixel and the integration time.
The output and reset of the integrators are controlled by a 640-bit shift register and reset logic. An output cycle is initiated
by clocking in a logic 1 on SI. Another signal, called HOLD, is generated from the rising edge of SI1 when SI1 and HOLD1
are connected together. This causes all 640 sampling capacitors to be disconnected from their respective integrators and
starts an integrator reset period. As the SI pulse is clocked through the shift register, the charge stored on the sampling
capacitors is sequentially connected to a charge-coupled output amplifier that generates a voltage on analog output AO.
The integrator reset period ends 18 clock cycles after the SI pulse is clocked in. Then the next integration period begins.
On the 640th clock rising edge, the SI pulse is clocked out on the SO1 pin (section 1) and becomes the SI pulse for section
2 (when SO1 is connected to SI2). The rising edge of the 641st clock cycle terminates the SO1 pulse, and returns the analog
output AO of section 1 to high-impedance state. Similarly, SO2 is clocked out on the 1280th clock pulse. Note that a 1281st
clock pulse is needed to terminate the SO2 pulse and return AO of Section 2 to the high-impedance state. If a minimum
integration time is desired, the next SI pulse may be presented after a minimum delay of tqt (pixel charge transfer
time) after the 1281st clock pulse. Sections 1 and 2 may be operated in parallel or in serial fashion.
AO is an op amp-type output that does not require an external pull-down resistor. This design allows a rail-to-rail
output voltage swing. With VDD = 5 V, the output is nominally 0 V for no light input, 2 V for normal white level, and 4.8 V
for saturation light level. When the device is not in the output phase, AO is in a high-impedance state.
The voltage developed at analog output (AO) is given by:
Vout = Vdrk + (Re) (Ee)(tint)
where:
Vout
Vdrk
Re
Ee
tint
is the analog output voltage for white condition
is the analog output voltage for dark condition
is the device responsivity for a given wavelength of light given in V/(μJ/cm2)
is the incident irradiance in μW/cm2
is integration time in seconds
A 0.1 μF bypass capacitor should be connected between VDD and ground as close as possible to the device.
2
r
www.taosinc.com
r
TSL1410R
Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted)†
Supply voltage range, VDD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 V to 6 V
Input voltage range, VI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 V to VDD + 0.3V
Input clamp current, IIK (VI < 0) or (VI > VDD) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −20 mA to 20 mA
Output clamp current, IOK (VO < 0 or VO > VDD) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −25 mA to 25 mA
Voltage range applied to any output in the high impedance or power-off state, VO . . . −0.3 V to VDD + 0.3 V
Continuous output current, IO (VO = 0 to VDD) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −25 mA to 25 mA
Continuous current through VDD or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −40 mA to 40 mA
Analog output current range, IO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −25 mA to 25 mA
Maximum light exposure at 638 nm . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 mJ/cm2
Operating free-air temperature range, TA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −25°C to 85°C
Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −25°C to 85°C
Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260°C
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “Recommended Operating Conditions” is not
implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
MIN
NOM
Supply voltage, VDD
3
5
Input voltage, VI
High-level input voltage, VIH
Low-level input voltage, VIL
VDD × 0.7
Wavelength of light source, λ
400
Clock frequency, fclock
5
MAX
UNIT
5.5
V
VDD
V
VDD
V
VDD × 0.3
V
1100
nm
8000
kHz
Sensor integration time, Serial, tint (see Note 1)
0.17775
100
ms
Sensor integration time, Parallel, tint (see Note 1)
Setup time, serial input, tsu(SI)
0.09775
100
ms
Hold time, serial input, th(SI) (see Note 2)
Operating free-air temperature, TA
Load capacitance, CL
Load resistance, RL
300
ns
ns
70
°C
330
pF
Ω
NOTES: 1. Integration time is calculated as follows:
tint(min) = (1280 − 18) y clock period + 20 ms
where 1280 is the number of pixels in series, 18 is the required logic setup clocks, and 20 ms is the pixel charge transfer time (tqt)
2. SI must go low before the rising edge of the next clock pulse.
r
www.taosinc.com
r
3
TSL1410R
Electrical Characteristics at fclock = 1 MHz, VDD = 5 V, TA = 25°C, λp = 640 nm, tint = 5 ms,
RL = 330 Ω, Ee = 12.5 μW/cm2 (unless otherwise noted) (see Note 3)
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
1.6
2
2.4
UNIT
V
0.3
V
Vout
Analog output voltage (white, average over 1280 pixels)
See Note 4
Vdrk
Analog output voltage (dark, average over 1280 pixels)
Ee = 0
PRNU
Pixel response nonuniformity
See Note 5
Nonlinearity of analog output voltage
See Note 6
±0.4%
Output noise voltage
See Note 7
1
Re
Responsivity
See Note 8
Vsat
Analog output saturation voltage
VDD = 5 V, RL = 330 Ω
4.5
4.8
VDD = 3 V, RL = 330 Ω
2.5
2.8
SE
Saturation exposure
DSNU
Dark signal nonuniformity
All pixels, Ee = 0, See Note 10
IL
Image lag
See Note 11
IDD
Supply current
IIH
High-level input current
VI = VDD
IIL
Low-level input current
VI = 0
Ci
Input capacitance, SI
25
pF
Ci
Input capacitance, CLK
25
pF
±20%
VDD = 5 V, See Note 9
155
VDD = 3 V, See Note 9
90
0.05
mVrms
38
V/
(μJ/cm 2)
V
nJ/cm 2
0.15
V
0.5%
VDD = 5 V, Ee = 0
30
45
VDD = 3 V, Ee = 0
25
40
mA
10
μA
10
μA
NOTES: 3. All measurements made with a 0.1 μF capacitor connected between VDD and ground.
4. The array is uniformly illuminated with a diffused LED source having a peak wavelength of 640 nm.
5. PRNU is the maximum difference between the voltage from any single pixel and the average output voltage from all pixels of the
device under test when the array is uniformly illuminated at the white irradiance level. PRNU includes DSNU.
6. Nonlinearity is defined as the maximum deviation from a best-fit straight line over the dark-to-white irradiance levels, as a percent
of analog output voltage (white).
7. RMS noise is the standard deviation of a single-pixel output under constant illumination as observed over a 5-second period.
8. Re(min) = [Vout(min) − Vdrk(max)] ÷ (Ee × tint)
9. SE(min) = [Vsat(min) − Vdrk(min)] × 〈Ee × tint) ÷ [Vout(max) − Vdrk(min)]
10. DSNU is the difference between the maximum and minimum output voltage for all pixels in the absence of illumination.
11. Image lag is a residual signal left in a pixel from a previous exposure. It is defined as a percent of white-level signal remaining after
a pixel is exposed to a white condition followed by a dark condition:
IL +
V out (IL) * V drk
V out (white) * V drk
100
Timing Requirements (see Figure 1 and Figure 2)
MIN
tsu(SI)
Setup time, serial input (see Note 12)
th(SI)
Hold time, serial input (see Note 12 and Note 13)
tpd(SO)
Propagation delay time, SO
tw
Pulse duration, clock high or low
50
tr, tf
Input transition (rise and fall) time
tqt
Pixel charge transfer time
NOM
MAX
ns
ns
50
UNIT
ns
ns
500
ns
μs
NOTES: 12. Input pulses have the following characteristics: tr = 6 ns, tf = 6 ns.
13. SI must go low before the rising edge of the next clock pulse.
4
r
www.taosinc.com
r
TSL1410R
Dynamic Characteristics over recommended ranges of supply voltage and operating free-air
temperature (see Figures 7 and 8)
PARAMETER
ts
Analog output settling time to ± 1%
tpd(SO)
Propagation delay time, SO1, SO2
TEST CONDITIONS
RL = 330 Ω,
MIN
CL = 50 pF
TYP
MAX
UNIT
120
ns
50
ns
TYPICAL CHARACTERISTICS
CLK
tqt
SI1
Internal
Reset
Integration
18 Clock Cycles
tint
Not Integrating
Integrating
ÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏ
ÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏÏ
ÏÏÏÏÏÏÏ
1281 Clock Cycles
AO
Hi-Z
Hi-Z
Figure 1. Timing Waveforms (serial connection)
tw
1
2
640
641
2.5 V
CLK
5V
0V
tsu(SI)
SI
5V
50%
0V
th(SI)
tpd(SO)
tpd(SO)
SO
ts
AO
Pixel 1
Pixel 640
Figure 2. Operational Waveforms (Each Section)
r
www.taosinc.com
r
5
TSL1410R
NORMALIZED IDLE SUPPLY CURRENT
vs
FREE-AIR TEMPERATURE
PHOTODIODE SPECTRAL RESPONSIVITY
1
2
IDD — Normalized Idle Supply Current
TA = 25°C
Relative Responsivity
0.8
0.6
0.4
0.2
1.5
1
0.5
500
600
700
800
900
1000 1100
Figure 3
50
60
70
Figure 4
DARK OUTPUT VOLTAGE
vs
WHITE OUTPUT VOLTAGE
vs
2
0.10
VDD = 5 V
tint = 0.5 ms to 15 ms
tint = 0.5 ms
tint = 1 ms
VDD = 5 V
0.09
1.5
Vout — Output Voltage
Vout — Output Voltage — V
40
TA − Free-Air Temperature − °C
λ − Wavelength − nm
1
0.5
tint = 15 ms
tint = 5 ms
tint = 2.5 ms
0.07
0.06
40
60
50
70
40
60
50
70
Figure 6
Figure 5
6
30
r
www.taosinc.com
r
TSL1410R
SETTLING TIME
vs.
LOAD
600
SETTLING TIME
vs.
LOAD
600
VDD = 3 V
Vout = 1 V
500
470 pF
Settling Time to 1% — ns
500
400
220 pF
300
200
100 pF
100
VDD = 5 V
Vout = 1 V
400
220 pF
300
200
100 pF
100
10 pF
470 pF
200
400
600
800
RL — Load Resistance − W
1000
10 pF
400
600
800
Figure 7
1000
Figure 8
APPLICATION INFORMATION
1
1
2
3
4
2
3
4
SI1/HOLD1/HOLD2
CLK1 and CLK2
5
6
CLK1 and CLK2
5
6
7
SO1
SI2
8
9
10
11
12
13
SI1/HOLD1
7
AO1
SO1
8
SI2/HOLD2
9
10
11
12
SO2
AO1/AO2
13
VDD
SERIAL
SO2
AO2
VDD
PARALLEL
Figure 9. Operational Connections
r
www.taosinc.com
r
7
TSL1410R
Integration Time
The integration time of the linear array is the period during which light is sampled and charge accumulates on
each pixel’s integrating capacitor. The flexibility to adjust the integration period is a powerful and useful feature
of the TAOS TSL14xx linear array family. By changing the integration time, a desired output voltage can be
obtained on the output pin while avoiding saturation for a wide range of light levels.
The integration time is the time between the SI (Start Integration) positive pulse and the HOLD positive pulse
minus the 18 setup clocks. The TSL14xx linear array is normally configured with the SI and HOLD pins tied
together. This configuration will be assumed unless otherwise noted. Sending a high pulse to SI (observing
timing rules for setup and hold to clock edge) starts a new cycle of pixel output and integration setup. However,
a minimum of (n+1) clocks, where n is the number of pixels, must occur before the next high pulse is applied
to SI. It is not necessary to send SI immediately on/after the (n+1) clocks. A wait time adding up to a maximum
total of 100 ms between SI pulses can be added to increase the integration time creating a higher output voltage
in low light applications.
Each pixel of the linear array consists of a light-sensitive photodiode. The photodiode converts light intensity
to a voltage. The voltage is sampled on the Sampling Capacitor by closing switch S2 (position 1) (see the
Functional Block Diagram on page 1). Logic controls the resetting of the Integrating Capacitor to zero by closing
switch S1 (position 2).
At SI input, all of the pixel voltages are simultaneously scanned and held by moving S2 to position 2 for all pixels.
During this event, S2 for pixel 1 is in position 3. This makes the voltage of pixel 1 available on the analog output.
On the next clock, S2 for pixel 1 is put into position 2 and S2 for pixel 2 is put into position 3 so that the voltage
of pixel 2 is available on the output.
Following the SI pulse and the next 17 clocks after the SI pulse is applied, the S1 switch for all pixels remains
in position 2 to reset (zero out) the integrating capacitor so that it is ready to begin the next integration cycle.
On the rising edge of the 19th clock, the S1 switch for all the pixels is put into position 1 and all of the pixels begin
a new integration cycle.
The first 18 pixel voltages are output during the time the integrating capacitor is being reset. On the 19th clock
following an SI pulse, pixels 1 through 18 have switch S2 in position 1 so that the sampling capacitor can begin
storing charge. For the period from the 19th clock through the nth clock, S2 is put into position 3 to read the output
voltage during the nth clock. On the next clock the previous pixel S2 switch is put into position 1 to start sampling
the integrating capacitor voltage. For example, S2 for pixel 19 moves to position 1 on the 20th clock. On the n+1
clock, the S2 switch for the last (nth) pixel is put into position 1 and the output goes to a high-impedance state.
If a SI was initiated on the n+1 clock, there would be no time for the sampling capacitor of pixel n to charge to
the voltage level of the integrating capacitor. The minimum time needed to guarantee the sampling capacitor
for pixel n will charge to the voltage level of the integrating capacitor is the charge transfer time of 20 μs.
Therefore, after n+1 clocks, an extra 20 μs wait must occur before the next SI pulse to start a new integration
and output cycle.
The minimum integration time for any given array is determined by time required to clock out all the pixels
in the array and the time to discharge the pixels. The time required to discharge the pixels is a constant.
Therefore, the minimum integration period is simply a function of the clock frequency and the number of pixels
in the array. A slower clock speed increases the minimum integration time and reduces the maximum light level
for saturation on the output. The minimum integration time shown in this data sheet is based on the maximum
clock frequency of 8 MHz.
8
r
www.taosinc.com
r
TSL1410R
The minimum integration time can be calculated from the equation:
T int(min) +
1
ǒmaximum clock
Ǔ
frequency
(n * 18)pixels ) 20ms
where:
n
In the case of the TSL1410R with the maximum clock frequency of 8 MHz, the minimum integration time would
be:
T int(min) + 0.125 ms
(640 * 18) ) 20 ms + 97.75 ms
It is good practice on initial power up to run the clock (n+1) times after the first SI pulse to clock out indeterminate
data from power up. After that, the SI pulse is valid from the time following (n+1) clocks. The output will go into
a high-impedance state after the n+1 high clock edge. It is good practice to leave the clock in a low state when
inactive because the SI pulse required to start a new cycle is a low-to-high transition.
The integration time chosen is valid as long as it falls in the range between the minimum and maximum limits
for integration time. If the amount of light incident on the array during a given integration period produces a
saturated output (Max Voltage output), then the data is not accurate. If this occurs, the integration period should
be reduced until the analog output voltage for each pixel falls below the saturation level. The goal of reducing
the period of time the light sampling window is active is to lower the output voltage level to prevent saturation.
However, the integration time must still be greater than or equal to the minimum integration period.
If the light intensity produces an output below desired signal levels, the output voltage level can be increased
by increasing the integration period provided that the maximum integration time is not exceeded. The maximum
integration time is limited by the length of time the integrating capacitors on the pixels can hold their accumulated
charge. The maximum integration time should not exceed 100 ms for accurate measurements.
It should be noted that the data from the light sampled during one integration period is made available on the
analog output during the next integration period and is clocked out sequentially at a rate of one pixel per clock
period. In other words, at any given time, two groups of data are being handled by the linear array: the previous
measured light data is clocked out as the next light sample is being integrated.
Although the linear array is capable of running over a wide range of operating frequencies up to a maximum
of 8 MHz, the speed of the A/D converter used in the application is likely to be the limiter for the maximum clock
frequency. The voltage output is available for the whole period of the clock, so the setup and hold times required
for the analog-to-digital conversion must be less than the clock period.
r
www.taosinc.com
r
9
TSL1410R
MECHANICAL INFORMATION
TOP VIEW
1.180 (29,97)
1.170 (29,72)
0.100 (2,54) x 12 = 1.2 (30,48)
(Tolerance Noncumulative)
0.175 (4,24)
0.165 (4,19)
To Pixel 1
0.021 (0,533) DIA
13 Places
0.095 (2,21)
0.080 (2,03)
0.100 (2,54)
BSC
1
0.510 (12,95)
0.490 (12,45)
13
0.242 (6,15)
0.222 (5,64)
0.091 (2,31)
0.087 (2,21)
DIA (2 Places)
Centerline of Pixels is on the
Centerline of Mounting Holes
DETAIL A
3.548 (90,120)
3.528 (89,611)
0.228 (5,79)
0.208 (5,28)
0.086 (2,184)
0.076 (1,930)
3.705 (94,11)
3.695 (93,85)
0.130 (3,30)
0.120 (3,05)
Cover Glass
(Index of Refraction = 1.52)
0.015 (0,38) Typical Free Area
ÈÈÈÈÈÈÈÈÈÈÈÈÈÈÈÈÈÈÈ
0.027 (0,690)
Linear Array
0.048 (1,22)
0.038 (0,97)
ÌÌÌÌÌÌ
ÌÌÌÌÌÌ
Cover Glass
Bonded Chip
Bypass Cap
DETAIL A
NOTES: A.
B.
C.
D.
All linear dimensions are in inches (millimeters).
Pixel centers are in line with center line of mounting holes.
The gap between the individual sensor dies in the array is 57 μm typical (51 μm minimum and 75 μm maximum).
This drawing is subject to change without notice.
Figure 10. TSL1410R Mechanical Specifications
10
r
www.taosinc.com
r
TSL1410R
THEORETICAL PIXEL LAYOUT FOR IDEAL CONTINUOUS DIE
8.00
63.50
55.50
N−2
N−1
N
1
2
3
ACTUAL MULTI-DIE PIXEL LAYOUT FOR DIE-TO-DIE EDGE JOINING
N−2
N−1
95.50
76.50
64.00
Note B
N
1
2
3
46.00
154.50
37.00
11.00
25.50
14.50
13.00
Note C
NOTES: A.
B.
C.
D.
All linear dimensions are in micrometers.
Spacing between outside pixels of adjacent die is typical.
Die-to-die spacing.
Figure 11. Edge Pixel Layout Dimensions
r
www.taosinc.com
r
11
TSL1410R
PRODUCTION DATA — information in this document is current at publication date. Products conform to
specifications in accordance with the terms of Texas Advanced Optoelectronic Solutions, Inc. standard
warranty. Production processing does not necessarily include testing of all parameters.
NOTICE
Texas Advanced Optoelectronic Solutions, Inc. (TAOS) reserves the right to make changes to the products contained in this
document to improve performance or for any other purpose, or to discontinue them without notice. Customers are advised
to contact TAOS to obtain the latest product information before placing orders or designing TAOS products into systems.
TAOS assumes no responsibility for the use of any products or circuits described in this document or customer product
design, conveys no license, either expressed or implied, under any patent or other right, and makes no representation that
the circuits are free of patent infringement. TAOS further makes no claim as to the suitability of its products for any particular
purpose, nor does TAOS assume any liability arising out of the use of any product or circuit, and specifically disclaims any
and all liability, including without limitation consequential or incidental damages.
TEXAS ADVANCED OPTOELECTRONIC SOLUTIONS, INC. PRODUCTS ARE NOT DESIGNED OR INTENDED FOR
USE IN CRITICAL APPLICATIONS IN WHICH THE FAILURE OR MALFUNCTION OF THE TAOS PRODUCT MAY
RESULT IN PERSONAL INJURY OR DEATH. USE OF TAOS PRODUCTS IN LIFE SUPPORT SYSTEMS IS EXPRESSLY
UNAUTHORIZED AND ANY SUCH USE BY A CUSTOMER IS COMPLETELY AT THE CUSTOMER’S RISK.
LUMENOLOGY, TAOS, the TAOS logo, and Texas Advanced Optoelectronic Solutions are registered trademarks of Texas Advanced
Optoelectronic Solutions Incorporated.
12
r
www.taosinc.com
r
