Adafruit LED Backpacks
Created by Melissa LeBlanc-Williams
https://learn.adafruit.com/adafruit-led-backpack
Last updated on 2022-09-22 07:03:31 PM EDT
©Adafruit Industries
Page 1 of 149
Table of Contents
Overview
7
1.2" 8x8 Matrix
9
Assembly
9
Arduino Setup
13
• Mini 8x8 Matrix Software
CircuitPython Wiring and Setup
16
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Python Installation of HT16K33 Library
Pillow Library
CircuitPython and Python Usage
18
Initialization
Setting the Brightness
Setting the Blink Rate
Setting Individual Pixels
Filling the Entire Matrix
Shifting the Matrix
Displaying an Image (Pillow Only)
0.8" 8x8 Matrix
23
Assembly
24
Arduino Wiring and Setup
27
30
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Pillow Library
32
33
Initialization
Page 2 of 149
• Filling the Entire Matrix
• Shifting the Matrix
• Displaying an Image (Pillow Only)
1.2" 16x8 Matrix
37
Arduino Setup
38
• 16x8 Matrix Software
41
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Pillow Library
43
45
Initialization
Shifting the Matrix
0.54" Alphanumeric Backpack
48
Assembly
50
Attaching the Backpack
Attaching Header
Prepare the header strip:
Add the Backpack:
55
Downloading the Arduino Library
Wiring!
Load Demo
Library Reference
ASCII data
Writing Data
60
• Wiring
• Library Setup
• Bundle Install
62
Wiring
Setup
Pillow Library
Page 3 of 149
64
Initialization
Printing Text
Printing Numbers
Printing Hexidecimal Values
Setting Individual Characters
Setting Individual Segments
Filling all Segments
Scrolling Display Manually
Displaying an Automatic Scrolling Marquee
0.56" 7-Segment Backpack
68
Assembly and Arduino Wiring
70
Arduino Setup
73
• Seven-Segment Backpack Firmware
76
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Pillow Library
79
81
Initialization
Printing Text
Printing Numbers
Displaying the Colon
1.2" 7-segment Backpack
86
Assembly
87
91
Arduino Wiring - R3 and later
Arduino Due and Other 3.3v Processors
Arduino "Classic" Wiring
Page 4 of 149
95
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Pillow Library
98
100
Initialization
Printing Text
Printing Numbers
Setting the Left-Side Dots
Setting the AM/PM Indicator
Bi-Color 8x8 Matrix
105
Assembly
106
Arduino Setup
109
112
• Wiring
• Library Setup
• Bundle Install
Wiring
Setup
Pillow Library
114
116
Initialization
Shifting the Matrix
Bi-Color 24 Bargraph
119
Page 5 of 149
Assembly
120
• Soldering on breadboard pins
126
129
• Wiring
• Library Setup
• Bundle Install
131
• Wiring
• Setup
• Python Installation of HT16K33 Library
133
Initialization
Setting Individual Bars
Filling the Entire Bargraph
Connecting Multiple Backpacks
134
• Wire it Up
• Configure the Address
Changing I2C Address
136
• Changing Addresses
• Changing the address in your code
F.A.Q.
139
Downloads
140
Software
Files
HT16K33 8x16 LED Backpack Breakout
8x8 0.8" LED Backpack
8x8 1.2" LED Backpack
8x8 1.2" Bi-Color LED Backpack
16x8 1.2" LED Backpacks
0.56" 7-Segment LED Backpack STEMMA QT
Quad 0.56" 7-Segment Original
Quad 0.54" 14-segment Alphanumeric STEMMA QT Version
Quad 0.54" 14-segment Alphanumeric Original Version
Quad 1.2" 7-Segment
Bicolor 24-Bargraph
Page 6 of 149
Overview
What's better than a single LED? Lots of LEDs! A fun way to make a small display is to
use an 8x8 matrix (https://adafru.it/aLG) or a 4-digit 7-segment display (https://
adafru.it/aLH). Matrices like these are 'multiplexed' - so to control 64 LEDs you need
16 pins. That's a lot of pins, and there are driver chips like the MAX7219 (http://
adafru.it/453) that can control a matrix for you but there's a lot of wiring to set up and
they take up a ton of space. Here at Adafruit we feel your pain! After all, wouldn't it be
awesome if you could control a matrix without tons of wiring? That's where these
adorable LED matrix backpacks come in.
We have them in quite a few flavors!
• Adorable Mini 8x8 (https://adafru.it/ttf)
• Classic 1.2" 8x8 (round and square dots) (https://adafru.it/ttA)
• Mini 1.2" 16x8 (round and square dots) (https://adafru.it/JpF)
• 4-digit 0.56" 7-segment (https://adafru.it/ttB)
• 4-digit 1.2" 7-segment (https://adafru.it/ttC)
• 4-digit 0.54" 14-segment Alphanumeric (https://adafru.it/ttD)
• Bi-color 8x8 (http://adafru.it/902)
• Bi-color Bargraph (http://adafru.it/1721)
Page 7 of 149
The matrices use a driver chip that does all the heavy lifting for you: They have a built
in clock so they multiplex the display. They use constant-current drivers for ultrabright, consistent color (the images above are photographed at the dimmest setting
to avoid overloading our camera!), 1/16 step display dimming, all via a simple I2C
interface. The backpacks come with address-selection jumpers so you can connect
up to four mini 8x8's or eight 7-segments (or a combination, such as four mini 8x8's
and four 7-segments, etc) on a single I2C bus.
The product kit comes with a fully tested and assembled LED backpack, a 4-pin
header and the matrix of your choice. A bit of soldering is required to attach the
matrix onto the backpack but it's very easy to do and only takes about 5 minutes.
Page 8 of 149
Of course, in classic Adafruit fashion, we also have a detailed tutorial showing you
how to solder, wire and control the display. We even wrote a very nice library for the
backpacks so you can get running in under half an hour, displaying images on the
matrix or numbers on the 7-segment. If you've been eyeing matrix displays but
hesitated because of the complexity, his is the solution you've been looking for!
1.2" 8x8 Matrix
This version of the LED backpack is designed for the 1.2" 8x8 matrices. They measure
only 1.2"x1.2" so its a shame to use a massive array of chips to control it. This
backpack solves the annoyance of using 16 pins or a bunch of chips by having an I2C
constant-current matrix controller sit neatly on the back of the PCB. The controller
chip takes care of everything, drawing all 64 LEDs in the background. All you have to
do is write data to it using the 2-pin I2C interface. There are two address select pins
so you can select one of 8 addresses to control up to 8 of these on a single 2-pin I2C
bus (as well as whatever other I2C chips or sensors you like). The driver chip can 'dim'
the entire display from 1/16 brightness up to full brightness in 1/16th steps. It cannot
dim individual LEDs, only the entire display at once.
Assembly
These instruction apply to the 1.2" Matrix only! If you have a Bi-Color or 0.8"
square matrix, follow the links on the left side of the page.
Page 9 of 149
When you buy a pack from Adafruit, it
comes with the fully tested and assembled
backpack as well as a 8x8 matrix in one of
the colors we provide (say, red, yellow or
green). You'll need to solder the matrix
onto the backpack but its an easy task.
WATCH OUT! THE MATRIX MUST BE
INSTALLED THE RIGHT WAY!
First look for the line of text on the side of
the LED matrix
Find the corner of the backpack with a
filled in dot. Make sure that the text on the
side of the matrix is on the same side as
the filled dot
Page 10 of 149
Slide the matrix into the backpack and flip
it over. Triple check that the text is on the
same side as the From Adafruit text
Page 11 of 149
Solder in all 16 pins
Then clip the matrix leads short
Page 12 of 149
Now you're ready to wire it up to a
microcontroller. We'll assume you want to
use a 4pin header. You can also of course
solder wires directly. Place a 4-pin piece of
header with the LONG pins down into the
breadboard.
Place the soldered backpack on top of the
header.
Solder the four pins
That's it! now you're ready to run the firmware!
Arduino Setup
You can use these with a 3.3v or 5v microcontroller. Just connect the VCC+ pin is
the same voltage as the logic on your microcontroller.
Page 13 of 149
We wrote a basic library to help you work with the mini 8x8 matrix backpack. The
library is written for the Arduino and will work with any Arduino as it just uses the I2C
pins. The code is very portable and can be easily adapted to any I2C-capable micro.
Wiring to the matrix is really easy
• Connect CLK to the I2C clock - on Arduino UNO thats Analog #5 (or SCL), on the
Leonardo its Digital #3, on the Mega its digital #21
• Connect DAT to the I2C data - on Arduino UNO thats Analog #4 (or SDA), on the
Leonardo its Digital #2, on the Mega its digital #20
• Connect GND to common ground
• Connect VCC+ to power - 5V is best but 3V also seems to work for 3V
microcontrollers.
Next, download the Adafruit LED Backpack library and the Adafruit GFX library from
the Arduino library manager.
Open up the Arduino library manager:
Search for the Adafruit LED Backpack library and install it
Search for the Adafruit GFX library and install it
Page 14 of 149
If using an earlier version of the Arduino IDE (prior to 1.8.10), also locate and install Ad
afruit_BusIO (newer versions will install this dependency automatically).
You should now be able to select the
File→Examples→Adafruit_LEDBackpack→matrix88 example sketch. Upload it to your
Arduino as usual. You should see a basic test program that goes through a bunch of
different drawing routine
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
Once you're happy that the matrix works, you can write your own sketches. The 8x8
matrix supports everything the Adafruit GFX library - drawing pixels, lines, rectancles,
circles, triangles, roundrects, and small bitmaps. For more details check out the GFX
page which will detail all of the GFX routines (https://adafru.it/aPx).
All the drawing routines only change the display memory kept by the Arduino. Don't
forget to call writeDisplay() after drawing to 'save' the memory out to the matrix via
I2C.
Page 15 of 149
There are also a few small routines that are special to the matrix:
• setBrightness(brighness)- will let you change the overall brightness of the entire
display. 0 is least bright, 15 is brightest and is what is initialized by the display
when you start. You can call this function at any time to change the brightness of
the -entire- display
• blinkRate(rate) - You can blink the entire display. 0 is no blinking. 1, 2 or 3 is for
display blinking.You can call this function at any time to change the blink rate of
The default orientation for graphics
commands on this display places pixel
(0,0) at the top-left when the header is at
the left and Adafruit logo at the right. To
use the matrix as shown above (header at
top, logo at bottom), call
matrix.setRotation(3) before issuing
graphics commands.
Wiring
It's easy to use LED Matrices with CircuitPython and the Adafruit CircuitPython
HT16K33 (https://adafru.it/u1E) library. This module allows you to easily write
CircuitPython code to control the display.
You can use this sensor with any CircuitPython microcontroller board.
We'll cover how to wire the LED Matrix to your CircuitPython microcontroller board.
First assemble your LED Matrix.
Connect the LED Matrix to your microcontroller board as shown below.
Page 16 of 149
Microcontroller 3V to LED Matrix VIN
Microcontroller GND to LED Matrix GND
Microcontroller SCL to LED Matrix SCL
Microcontroller SDA to LED Matrix SDA
Download Fritzing Object
https://adafru.it/Ify
Library Setup
To use the LED backpack with your Adafruit CircuitPython (https://adafru.it/BlM) board
you'll need to install the Adafruit_CircuitPython_HT16K33 (https://adafru.it/u1E) library
on your board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/tBa) for your board. Next you'll need to install the necessary libraries to use
the hardware--read below and carefully follow the referenced steps to find and install
these libraries from Adafruit's CircuitPython library bundle (https://adafru.it/zdx).
Bundle Install
For express boards that have extra flash storage, like the Feather/Metro M0 express
and Circuit Playground express, you can easily install the necessary libraries with Ada
fruit's CircuitPython bundle (https://adafru.it/zdx). This is an all-in-one package that
includes the necessary libraries to use the LED backpack display with CircuitPython.
For details on installing the bundle, read about CircuitPython Libraries (https://
adafru.it/ABU).
Remember for non-express boards like the Trinket M0, Gemma M0, and Feather/
Metro M0 basic you'll need to manually install the necessary libraries (https://adafru.it/
ABU) from the bundle:
• adafruit_ht16k33
Page 17 of 149
• adafruit_bus_device
If your board supports USB mass storage, like the M0-based boards, then simply drag
the files to the board's file system. Note on boards without external SPI flash, like a
Feather M0 or Trinket/Gemma M0, you might run into issues on Mac OSX with hidden
files taking up too much space when drag and drop copying, see this page for a
workaround (https://adafru.it/u1d).
Before continuing make sure your board's lib folder or root filesystem has at least
the adafruit_ht16k33 and adafruit_bus_device folders/modules copied over.
Wiring
It's easy to use LED Matrices with Python and the Adafruit CircuitPython HT16K33 (htt
ps://adafru.it/u1E) library. This library allows you to easily write Python code to control
the display.
We'll cover how to wire the LED Matrix to your Raspberry Pi. First assemble your LED
Matrix.
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Connect the LED Matrix as shown below to your Raspberry Pi.
Page 18 of 149
Raspberry Pi 3.3V to LED Matrix VIN
Raspberry Pi GND to LED Matrix GND
Raspberry Pi SCL to LED Matrix SCL
Raspberry Pi SDA to LED Matrix SDA
https://adafru.it/Ifz
Setup
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling I2C on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https:
//adafru.it/BSN)!
Once that's done, from your command line run the following command:
• pip3 install adafruit-circuitpython-ht16k33
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
If that complains about pip3 not being installed, then run this first to install it:
• sudo apt-get install python3-pip
Page 19 of 149
Pillow Library
We also need PIL, the Python Imaging Library, to allow using text with custom fonts.
There are several system libraries that PIL relies on, so installing via a package
manager is the easiest way to bring in everything:
• sudo apt-get install python3-pil
That's it. You should be ready to go.
The following section will show how to control the LED backpack from the board's
Python prompt / REPL. You'll walk through how to control the LED display and learn
how to use the CircuitPython module built for the display.
First connect to the board's serial REPL (https://adafru.it/Awz)so you are at the
CircuitPython >>> prompt.
Initialization
First you'll need to initialize the I2C bus for your board. It's really easy, first import the
necessary modules. In this case, we'll use board and Matrix8x8 .
Then just use board.I2C() to create the I2C instance using the default SCL and
SDA pins (which will be marked on the boards pins if using a Feather or similar
Adafruit board).
Then to initialize the matrix, you just pass i2c in.
import board
from adafruit_ht16k33.matrix import Matrix8x8
i2c = board.I2C()
matrix = Matrix8x8(i2c)
If you bridged the address pads on the back of the display, you could pass in the
address. The addresses for the HT16K33 can range between 0x70 and 0x77
depending on which pads you have bridged, with 0x70 being used if you haven't
Page 20 of 149
bridged any of them. For instance, if you bridge only the A0 pad, you would use
0x71 like this:
matrix = Matrix8x8(i2c, address=0x71)
You can set the brightness of the display, but changing it will set the brightness of the
entire display and not individual segments. If can be adjusted in 1/16 increments betw
een 0 and 1.0 with 1.0 being the brightest. So to set the display to half brightness, you
would use the following:
matrix.brightness = 0.5
You can set the blink rate of the display, but changing it will set the brightness of the
entire display and not individual pixels. If can be adjusted in 1/4 increments between 0
and 3 with 3 being the fastest blinking. So to set the display to blink at full speed, you
matrix.blink_rate = 3
To set individual pixels to on, you simply treat the matrix object as a
multidimensional list and set it to 1.
matrix[0, 0] = 1
matrix[4, 4] = 1
matrix[7, 7] = 1
To fill the entire matrix, just use the fill() function and pass in either 0 or 1 depending
on whether you want all pixels off or on. For instance, if you wanted to set everything
to on, you would use:
matrix.fill(1)
Page 21 of 149
Shifting the Matrix
To shift the pixels on the matrix, there are 5 functions you can use. The main function,
called shift(), is used to shift the pixels, up, down, left, right, or even diagonally. By
passing a positive number, it will shift the pixels right/up and passing a negative
number will shift them left/down. For instance:
matrix.shift(2, 0)
matrix.shift(-1, 0)
matrix.shift(0, -3)
matrix.shift(-2, 2)
# shift pixels to the right by 2
# shift pixels to the left by 1
# shift pixels down by 3
# shift pixels left by 2 and up by 2
You can pass True as a third parameter to loop all the pixels that get shifted off over
to the other side.
matrix.shift(2, 0, True)
matrix.shift(-1, 0, True)
matrix.shift(0, -3, True)
matrix.shift(-2, 2, True)
# loop pixels to the right by 2
# loop pixels to the left by 1
# loop pixels down by 3
# loop pixels left by 2 and up by 2
Additionally, there are a few convenience functions that will shift the pixels by one.
These can also be passed a value of True to loop the pixels.
matrix.shift_up()
# Shift pixels up
matrix.shift_left()
# Shift pixels left
matrix.shift_down()
# Shift pixels down
matrix.shift_right()
# Shift pixels right
matrix.shift_up(True)
# Loop pixels up
matrix.shift_left(True)
# Loop pixels left
matrix.shift_down(True)
# Loop pixels down
matrix.shift_right(True)
# Loop pixels right
Additionally, when using with the Raspberry Pi, you can use the Pillow library to
display an image to the Matrix. The image will need to be the same exact size as the
Matrix. In this case, it should be 8x8 pixels. As an example, you can save the image
below as myimage.png.
Download Image
https://adafru.it/ICR
Page 22 of 149
Then if you want to display the image called myimage.png, you would use something
like this:
import board
from PIL import Image
from adafruit_ht16k33 import matrix
matrix = matrix.Matrix8x8(board.I2C())
image = Image.open("myimage.png")
matrix.image(image)
0.8" 8x8 Matrix
This version of the LED backpack is designed for these very cute miniature 8x8
matrices. They measure only 0.8"x0.8" so its a shame to use a massive array of chips
to control it. This backpack solves the annoyance of using 16 pins or a bunch of chips
by having an I2C constant-current matrix controller sit neatly on the back of the PCB.
The controller chip takes care of everything, drawing all 64 LEDs in the background.
All you have to do is write data to it using the 2-pin I2C interface. There are two
address select pins so you can select one of 4 addresses to control up to 4 of these
on a single 2-pin I2C bus (as well as whatever other I2C chips or sensors you like).
The driver chip can 'dim' the entire display from 1/16 brightness up to full brightness in
1/16th steps. It cannot dim individual LEDs, only the entire display at once.
Page 23 of 149
Assembly
These instruction apply to the 0.8" Matrix only! If you have a Bi-Color or 1.2"
Page 24 of 149
Remove the parts from packaging and
place the LED matrix OVER the silkscreen
side. It can go 'either way' - the matrix is
symmetric so as long as it goes onto the
front it will work in any orientation. Do not
solder the matrix over the chip on the back
of the backpack - it will not work then!
Turn the backpack over so its sitting flat on
the matrix.
Solder all 16 pins.
Page 25 of 149
Clip the long pins.
breadboard.
Page 26 of 149
header.
Solder 'em!
Page 27 of 149
microcontrollers.
Once you've restarted you should be able to select the
different drawing routines
Page 28 of 149
adafru.it/aYM)
I2C.
when you start
display blinking.
Page 29 of 149
Wiring
Library Setup
on your board.
Page 30 of 149
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 31 of 149
Wiring
the display.
Matrix.
Setup
//adafru.it/BSN)!
Page 32 of 149
Pillow Library
Initialization
Page 33 of 149
Adafruit board).
import board
i2c = board.I2C()
0x71 like this:
Page 34 of 149
matrix[0, 0] = 1
matrix[4, 4] = 1
matrix[7, 7] = 1
matrix.fill(1)
Shifting the Matrix
matrix.shift(2, 0)
matrix.shift(-1, 0)
matrix.shift(0, -3)
matrix.shift(-2, 2)
to the other side.
matrix.shift_up()
matrix.shift_left()
matrix.shift_down()
# Shift pixels up
# Shift pixels left
# Shift pixels down
Page 35 of 149
# Loop pixels up
# Loop pixels left
# Loop pixels down
# Loop pixels right
Download Image
like this:
import board
matrix.image(image)
Page 36 of 149
1.2" 16x8 Matrix
With the 16x8 LED Matrix we've doubled your project's matrix capacity by making it
super easy to get two separate 8x8 matrices onto one handy board! This version of
the LED backpack is designed for two of the 1.2" 8x8 matrices. They measure only
1.2"x1.2" so its a shame to use a massive array of chips to control it. This backpack
solves the annoyance of using 32 pins or a bunch of chips by having an I2C constantcurrent matrix controller sit neatly on the back of the PCB. The controller chip takes
care of everything, drawing all 128 LEDs in the background. All you have to do is write
data to it using the 2-pin I2C interface. There are two address select pins so you can
select one of 8 addresses to control up to 8 of these on a single 2-pin I2C bus (as
well as whatever other I2C chips or sensors you like). The driver chip can 'dim' the
entire display from 1/16 brightness up to full brightness in 1/16th steps. It cannot dim
Assembling the 1.2" 16x8 backpack is nearly the same as the 1.2" 8x8, so you can follo
w that page (https://adafru.it/LAT) for directions, only difference is there’s two matrices
to install now.
The printed-on edge of the matrices face the white dots on the PCB, and there’s a
single set of address selection pads; the pair is addressed as one larger unit, not set
independently.
Page 37 of 149
Arduino Setup
We wrote a basic library to help you work with the 16x8 matrix backpack. The library is
written for the Arduino and will work with any Arduino as it just uses the I2C pins. The
microcontrollers.
Page 38 of 149
adafru.it/aYM)
Page 39 of 149
I2C.
Page 40 of 149
graphics commands.
Wiring
https://adafru.it/IB5
Page 41 of 149
Library Setup
on your board.
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 42 of 149
Wiring
the display.
Matrix.
Page 43 of 149
https://adafru.it/IB6
Setup
//adafru.it/BSN)!
Pillow Library
Page 44 of 149
Initialization
necessary modules. In this case, we'll use board and MatrixBackpack16x8 .
Adafruit board).
import board
from adafruit_ht16k33.matrix import MatrixBackpack16x8
i2c = board.I2C()
matrix = MatrixBackpack16x8(i2c)
0x71 like this:
matrix = MatrixBackpack16x8(i2c, address=0x71)
Page 45 of 149
display.brightness = 0.5
display.blink_rate = 3
matrix[0, 0] = 1
matrix[4, 4] = 1
matrix[7, 7] = 1
matrix.fill(1)
Shifting the Matrix
matrix.shift(2, 0)
matrix.shift(-1, 0)
matrix.shift(0, -3)
matrix.shift(-2, 2)
Page 46 of 149
to the other side.
matrix.shift_up()
# Shift pixels up
matrix.shift_left()
# Shift pixels left
matrix.shift_down()
# Shift pixels down
# Loop pixels up
# Loop pixels left
# Loop pixels down
# Loop pixels right
Here's what shifting a smiley face to the right looks like:
Matrix. In this case, it should be 16x8 pixels. As an example, you can save the image
Download Image
https://adafru.it/ICS
Page 47 of 149
like this:
import board
matrix = matrix.MatrixBackpack16x8(board.I2C())
matrix.image(image)
This version of the LED backpack is designed for two dual 14-segment "Alphanumeric"
displays. These 14-segment displays normally require 18 pins (4 'characters' and 14
total segments each) This backpack solves the annoyance of using 18 pins or a bunch
of chips by having an I2C constant-current matrix controller sit neatly on the back of
the PCB. The controller chip takes care of everything, drawing all the LEDs in the
background. All you have to do is write data to it using the 2-pin I2C interface.
There are three address select pins so you can select one of 8 addresses to control
up to 8 of these on a single 2-pin I2C bus (as well as whatever other I2C chips or
sensors you like). The driver chip can 'dim' the entire display from 1/16 brightness up
to full brightness in 1/16th steps. It cannot dim individual LEDs, only the entire display
at once.
Page 48 of 149
To get you going fast, we have revised this popular board to be the same size and
pinout as before but now with two STEMMA QT connectors (https://adafru.it/JqB) on
either side that are compatible with the SparkFun Qwiic (https://adafru.it/Fpw) I2C
connectors. This allows you to make solderless connections between your
development board and the HT16K33 or to chain it with a wide range of other sensors
and accessories using a compatible cable (https://adafru.it/JnB).
There are two versions of this board - the STEMMA QT version shown above, and
the original header-only version shown below. Code works the same on both!
Page 49 of 149
Assembly
backpack as well as two dual 14-segment
display in one of the colors we provide
(say, red, yellow, blue or green). You'll
need to solder the matrix onto the
backpack but it's an easy task.
place the LED matrices OVER the
silkscreen side. DO NOT PUT THE
DISPLAY ON UPSIDE DOWN OR IT WONT
WORK!! Check the image below to make
sure the 'decimal point' dots are on the
bottom, matching the silkscreen.
Page 50 of 149
Turn the backpack over so it is sitting flat
on the matrix.
Page 51 of 149
Solder all of the pins!
Page 52 of 149
Clip the long pins.
Page 53 of 149
Check your work, making sure each pin is
nicely soldered, and there's no cold solder
joints or shorted pins
Attaching Header
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Add the Backpack:
Place the backpack board over the pins so
that the short pins poke through the
breakout pads
Page 54 of 149
Solder all 5 pins!
That's it! now you're ready to run the firmware on your Arduino!
We wrote a basic library to help you work with the alphanumeric backpack. The
Begin by downloading our Adafruit LED Backpack library (https://adafru.it/aLI)and the
Adafruit GFX library (https://adafru.it/aJa) from the Arduino library manager.
Page 55 of 149
adafru.it/aYM)
You can use these with a 3.3v or 5v microcontroller. Just make sure the Vi2c pin
is the same voltage as the logic on your microcontroller.
Wiring!
Nex up, let's wire it up to an Arduino. We'll be using an Arduino.
Leonardo it's Digital #3, on the Mega it's digital #21
Leonardo it's Digital #2, on the Mega it's digital #20
• Connect VCC+ to power - 5V is best but 3V will work if that's all you've got (it
will be dimmer)
• Connect Vi2c to your microcontroller's logic level (3-5V) - If you're using an
Arduino, this is almost certainly 5V. If its a 3V Arduino such as a Due, connect it
to 3V
Both Vi2c and Vcc MUST be connected to 3 to 5VDC! Vcc is for the LED driver power,
Vi2c is what sets the logic level for communication to the chip.
Page 56 of 149
Load Demo
Restart the Arduino IDE and load up the File→Adafruit_LEDBackpack→quadalphanum
demo
Upload to your Arduino, and open up the Serial console at 9600 baud speed. You'll
see each digit light up all the segments, then the display will scroll through the 'font
table' showing every character that it knows how to display. Finally, you'll get a notice
to start typing into the serial console. Type a message and hit return, you'll see it
Page 57 of 149
scroll onto the display!
Library Reference
For the quad displays, we have a special object that can handle ascii data for easy
printing.
You can create the object with
Adafruit_AlphaNum4 alpha4 = Adafruit_AlphaNum4();
There's no arguments or pins because the backpacks use the fixed I2C pins.
By default, the address is 0x70, but you can pass in the I2C address used when you
initialize the display with begin
Page 58 of 149
alpha4.begin(0x70);
// pass in the address
Next up, the segments can be turned on/off for each digit by writing the 'raw' bitmap
you want, for example, all the LEDs off on digit #3 is
alpha4.writeDigitRaw(3, 0x0);
All the segments on for digit #0 is
alpha4.writeDigitRaw(0, 0x3FFF);
This is the segment map:
the 16 bit digit you pass in for raw image has this mapping:
0 DP N M L K J H G2 G1 F E D C B A
The first bit isn't used, you can make it 0 or 1
To turn on just the A segment, use 0x0001
To turn on just the G1 segment, use 0x0040
ASCII data
If you're just looking to print 'text' you can use our font table, just pass in an ASCII
character!
For example, to set digit #0 to A call:
Page 59 of 149
alpha4.writeDigitAscii(0, 'A')
Writing Data
Don't forget to 'write' the data to the display with
alpha4.writeDisplay();
That's what actually 'sets' the data onto the LEDs!
Wiring
It's easy to use LED AlphaNumeric Displays with CircuitPython and the Adafruit
CircuitPython HT16K33 (https://adafru.it/u1E) library. This module allows you to easily
write CircuitPython code to control the display.
We'll cover how to wire the AlphaNumeric Display to your CircuitPython
microcontroller board. First assemble your AlphaNumeric Display.
Connect the AlphaNumeric Display to your microcontroller board as shown below.
Microcontroller 3V to AlphaNumeric
Display I2C VIN
Display VIN
Microcontroller GND to AlphaNumeric
Display GND
Microcontroller SCL to AlphaNumeric
Display SCL
Microcontroller SDA to AlphaNumeric
Display SDA
Page 60 of 149
https://adafru.it/IB7
Library Setup
on your board.
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 61 of 149
Wiring
It's easy to use AlphaNumeric Displays with Python and the Adafruit CircuitPython
HT16K33 (https://adafru.it/u1E) library. This library allows you to easily write Python
We'll cover how to wire the AlphaNumeric Display to your Raspberry Pi. First
Connect the AlphaNumeric Display as shown below to your Raspberry Pi.
Raspberry Pi 3.3V to AlphaNumeric
Display I2C VIN
Display VIN
Raspberry Pi GND to AlphaNumeric
Display GND
Raspberry Pi SCL to AlphaNumeric
Display SCL
Raspberry Pi SDA to AlphaNumeric
Display SDA
Page 62 of 149
https://adafru.it/IB8
Setup
//adafru.it/BSN)!
Pillow Library
Page 63 of 149
Initialization
necessary modules. In this case, we'll use board and Seg14x4 .
Adafruit board).
Then to initialize the display, you just pass i2c in.
import board
from adafruit_ht16k33.segments import Seg14x4
i2c = board.I2C()
display = Seg14x4(i2c)
0x71 like this:
display = Seg14x4(i2c, address=0x71)
Page 64 of 149
entire display and not individual segments. If can be adjusted in 1/4 increments betwe
en 0 and 3 with 3 being the fastest blinking. So to set the display to blink at full
speed, you would use the following:
Printing Text
To print text to the display, you just use the print function. So if we want to print ABCD,
we would use the following:
display.print("ABCD")
Printing Numbers
Printing numbers is done similar to printing text, except without the quotes, though
you can still print numbers in a string as well.
display.print(1234)
To print hexidecimal values, you use the print_hex function:
display.print_hex(0x1A2B)
To set individual characters, you simply treat the display object as a list and set it
to the value that you would like.
display[0] = '1'
display[1] = '2'
Page 65 of 149
display[2] = 'A'
display[3] = 'B'
To set individual segments to turn on or off, you would use the set_digit_raw function
to pass the digit that you want to change and the bitmask. This can be really useful
for creating your own characters. The bitmask corresponds to the following diagram.
The highest bit is not used, so an X represents that spot to indicate that.
The bitmask is a 16-bit number that can be passed in as a single Hexidecimal,
Decimal, or binary number. It can also be passed in as a list or tuple containing 2
separate 8-bit numbers. Here are some of the ways to set the digits. All of these
different methods create a box with an X in the center:
display.set_digit_raw(0,
display.set_digit_raw(1,
display.set_digit_raw(2,
display.set_digit_raw(3,
0x2D3F)
0b0010110100111111)
(0b00101101, 0b00111111))
[0x2D, 0x3F])
Page 66 of 149
To fill the entire display, just use the fill() function and pass in either 0 or 1 depending
on whether you want all segments off or on. For instance, if you wanted to set
everything to on, you would use:
display.fill(1)
If you want to scroll the displayed data to the left, you can use the scroll()
function. You can pass in the number of places that you want to scroll. The right-most
digit will remain unchanged and you will need to set that manually. After scrolling, you
will need to call the show function. For example if you wanted to print an A and then
scroll it over to spaces, you would do the following.
display.print("A")
display.scroll(2)
display[3] = " "
display.show()
Page 67 of 149
To make displaying long text easier, we've added a marquee function. You just pass it
the full string. Optionally, you can pass it the amount of delay between each
character:
display.marquee("This is a really long string ")
By default it is 0.25 seconds, but you can change this by providing a second
parameter. You can optionally pass False for a third parameter if you would not like
to have it loop. So if you wanted each character to display for half a second and didn't
want it to loop, you would use the following:
display.marquee('This is a really long string ', 0.5, False)
This version of the LED backpack is designed for these big bright 7-segment displays.
These 7-segment displays normally require 13 pins (5 'characters' and 8 total
segments each) This backpack solves the annoyance of using 13 pins or a bunch of
chips by having an I2C constant-current matrix controller sit neatly on the back of the
background. All you have to do is write data to it using the 2-pin I2C interface. There
are three address select pins so you can select one of 8 addresses to control up to 8
of these on a single 2-pin I2C bus (as well as whatever other I2C chips or sensors you
like). The driver chip can 'dim' the entire display from 1/16 brightness up to full
brightness in 1/16th steps. It cannot dim individual LEDs, only the entire display at
once.
Page 68 of 149
Page 69 of 149
For the STEMMA QT version, you can solder the headers on, or you can simply use a
STEMMA QT cable!
Backpack + (VCC) to microcontroller 5V (if
using a board with 5V logic, otherwise use
3V for boards with 3V logic) (red wire)
Backpack - (GND) to microcontroller GND
(black wire)
Backpack D (SDA) to microcontroller SDA
(blue wire)
Backpack C (SCL) to microcontroller SCL
(yellow wire)
To assemble the LED backpack, follow along below.
Soldering the 7-segment display is the same for the STEMMA QT version and the
original version.
Page 70 of 149
backpack as well as a 7-segment display in
one of the colors we provide (say, red,
yellow, blue or green). You'll need to
solder the matrix onto the backpack but
it's an easy task.
side. DO NOT PUT THE DISPLAY ON
UPSIDE DOWN OR IT WONT WORK!!
Check the image below to make sure the
'decimal point' dots are on the bottom,
on the matrix.
Page 71 of 149
Solder all 14 pins.
Clip the long pins.
Page 72 of 149
breadboard.
header and Solder 'em!
Arduino Setup
We wrote a basic library to help you work with the 7-segment backpack. The library is
Page 73 of 149
microcontrollers.
File→Examples→Adafruit_LEDBackpack→sevenseg example sketch. Upload it to your
different routines.
Page 74 of 149
adafru.it/aYM)
There's a few ways you can draw to the display. The easiest is to just call print - just
like you do with Serial
• print(variable,HEX) - this will print a hexidecimal number, from 0000 up to FFFF
• print(variable,DEC) or print(variable) - this will print a decimal integer, from 0000
up to 9999
If you need more control, you can call writeDigitNum(location, number) - this will write
the number (0-9) to a single location. Location #0 is all the way to the left, location #2
is the colon dots so you probably want to skip it, location #4 is all the way to the right.
If you want a decimal point, call writeDigitNum(location, number, true) which will paint
the decimal point. To draw the colon, usedrawColon(true or false)
If you want even more control, you can call writeDigitRaw(location,bitmask) to draw a
raw 8-bit mask (as stored in a uint8_t) to that location.
I2C.
Page 75 of 149
There are also a few small routines that are special to the backpack:
• setBrightness(brightness)- will let you change the overall brightness of the entire
when you start
display blinking.
Wiring
It's easy to use LED 7-Segment Displays with CircuitPython and the Adafruit
We'll cover how to wire the 7-Segment Display to your CircuitPython microcontroller
board. First assemble your 7-Segment Display.
Connect the 7-Segment Display to your microcontroller board as shown below.
Page 76 of 149
Microcontroller 3V to 7-Segment Display
VIN (red wire)
Microcontroller GND to 7-Segment Display
GND (black wire)
Microcontroller SCL to 7-Segment Display
SCL (yellow wire)
Microcontroller SDA to 7-Segment Display
SDA (blue wire)
https://adafru.it/ICk
Library Setup
on your board.
Page 77 of 149
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 78 of 149
Wiring
It's easy to use 7-Segment Displays with Python and the Adafruit CircuitPython
We'll cover how to wire the 7-Segment Display to your Raspberry Pi. First assemble
Connect the 7-Segment Display as shown below to your Raspberry Pi.
Page 79 of 149
Raspberry Pi 3.3V to 7-Segment Display
VIN (red wire)
Raspberry Pi GND to 7-Segment Display
GND (black wire)
Raspberry Pi SCL to 7-Segment Display
SCL (yellow wire)
Raspberry Pi SDA to 7-Segment Display
SDA (blue wire)
https://adafru.it/ICl
Setup
Page 80 of 149
//adafru.it/BSN)!
Pillow Library
Page 81 of 149
Initialization
necessary modules. In this case, we'll use board and Seg7x4 .
Adafruit board).
import board
from adafruit_ht16k33.segments import Seg7x4
i2c = board.I2C()
display = Seg7x4(i2c)
0x71 like this:
display = Seg7x4(i2c, address=0x71)
Page 82 of 149
Printing Text
To print text to the display, you just use the print function. For the 7-segment display,
valid characters are 0-9, letters A-F, a period, and a hyphen. So if we want to print
ABCD, we would use the following:
Printing Numbers
display.print(1234)
display[0]
display[1]
display[2]
display[3]
'1'
'2'
'A'
'B'
for creating your own characters. The bitmask corresponds to the following diagram:
Page 83 of 149
The bitmask is a single 8-bit number that can be passed in as a single Hexidecimal,
Decimal, or binary number. This will use a couple different methods to display
8.8.EE :
0xFF)
0b11111111)
0x79)
0b01111001)
Page 84 of 149
display.fill(1)
display.print("A")
display.scroll(2)
display[3] = " "
display.show()
There are a couple of different ways to display a colon on the 7-segment display. The
first and easiest way is to use the print function:
display.print("12:30")
The other way to control it is to access the colon with the colon property and set it to
True or False :
display.colon = False
character. This may be useful for displaying an IP address, a phone number, or other
numeric data:
Page 85 of 149
display.marquee('192.168.100.102... ')
display.marquee('192.168.100.102... ', 0.5, False)
These backpacks drive the massive 1.2" 7-segment modules. With 2 leds per segment
these make a gorgeous and impressive display. The 7-segment displays normally
require 16 pins to drive. This backpack uses an I2C constant-current matrix controller
on the back of the PCB, so you only need 2 pins to drive it!
The controller chip takes care of multiplexing all the LEDs in the background. All you
have to do is write data to it using the 2-pin I2C interface. There are three address
select pins so you can select one of 8 addresses to control up to 8 of these on a
single 2-pin I2C bus (as well as whatever other I2C chips or sensors you like). The
Page 86 of 149
Assembly
solder the matrix onto the backpack but its
an easy task.
'decimal point' dots are in the same
location as the ones on the silkscreen.
Page 87 of 149
the matrix and ready to solder.
Page 88 of 149
Then solder each pin. There are 8 on each
end for a total of 16.
That completes the basic assembly. For use on a breadboard, you will want to also
install a 5-pin header on the edge of the board.
Page 89 of 149
Clip the long pins close to the board.
Cut the header strip to length if necessary
and insert LONG pins down into the
breadboard.
Page 90 of 149
Then solder all 5 pins.
You can use these with a 3.3v or 5v microcontroller. Just make sure the IO pin is
Now you are ready to wire it to your microcontroller. The required connections are:
• "D" - I2C Data Pin (SDA)
• "C" - I2C Clock Pin (SCL)
• "+" - 5v. (Will not run on 3.3v!)
• "-" - GND
• "IO" - I2C bus voltage.
Due to the size of this display, there are 2 LEDs in series for each segment. Because
of this, the display requires 5v to run. It will not run on 3.3v.
For use with 3.3v processors, connect the IO pin to 3.3v. This will keep the I2C bus
signals at a safe level for your processor.
With 5v processors like the Arduino UNO, this pin can be connected to either 5v or
3.3v. (use 3.3v if there will be other 3.3v devices on the bus)
Page 91 of 149
Connect:
D → SDA
C → SCL
+ → 5v
- → GND
IO → jumper to + for 5v.
Processors
Connect:
D → SDA
C → SCL
+ → 5v
- → GND
IO → 3.3v
Connect:
D → Analog-4 or Digital 20 for the Mega
C → Analog-5 or Digital 21 for the Mega
+ → 5v
- → GND
OK, now on to the firmware!
Our 7-segment backpack library makes it easy to program these displays. The library
is written for the Arduino and will work with any Arduino as it just uses the I2C pins.
Download the Adafruit LED Backpack library and the Adafruit GFX library from the
Page 92 of 149
adafru.it/aYM)
Arduino as usual. You should see a "sevenseg" example sketch that will demonstrate
various capabilities of the library and the display.
Page 93 of 149
• print(variable,HEX) - this will print a hexadecimal number, from 0000 up to FFFF
up to 9999
To control the colon and decimal points, use the writeDigitRaw(location, bitmap)
function. (Note that both dots of the center colon are wired together internal to the
display, so it is not possible to address them separately.) Specify 2 for the location
and the bits are mapped as follows:
• 0x02 - center colon (both dots)
• 0x04 - left colon - lower dot
• 0x08 - left colon - upper dot
• 0x10 - decimal point (upper right)
the decimal point. To draw the colon, use drawColon(true or false)
Page 94 of 149
If you want full control of the segments in all digits, you can call writeDigitRaw(locatio
n, bitmask) to draw a raw 8-bit mask (as stored in a uint8_t) to any location.
I2C.
when you start
display blinking.
Wiring
In the latest CircuitPython, you will need to connect 1K resistor Pull-ups to the
SCL and SDA inputs.
Page 95 of 149
• Microcontroller 3.3V to 3.3v Bus
• 3.3v Bus to 7-Segment Display IO
• Microcontroller 5V to 7-Segment Display VIN
• Microcontroller GND to 7-Segment Display GND
• Microcontroller SCL to 7-Segment Display SCL
• Microcontroller SDA to 7-Segment Display SDA
• 1K Resistor between 3.3v Bus and 7-Segment Display SCL
• 1K Resistor between 3.3v Bus and 7-Segment Display SDA
https://adafru.it/-dR
Library Setup
on your board.
Page 96 of 149
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 97 of 149
Wiring
Raspberry Pi 3.3V to 7-Segment Display IO
Raspberry Pi 5V to 7-Segment Display VIN
Display GND
Display SCL
Display SDA
Page 98 of 149
https://adafru.it/ICn
Setup
//adafru.it/BSN)!
Pillow Library
Page 99 of 149
Initialization
necessary modules. In this case, we'll use board and BigSeg7x4 .
Adafruit board).
import board
from adafruit_ht16k33.segments import BigSeg7x4
i2c = board.I2C()
display = BigSeg7x4(i2c)
0x71 like this:
display = BigSeg7x4(i2c, address=0x71)
Page 100 of 149
Printing Text
valid characters are 0-9, letters A-F, and a hyphen. So if we want to print ABCD, we
Printing Numbers
display.print(1234)
Page 101 of 149
display[0]
display[1]
display[2]
display[3]
'1'
'2'
'A'
'B'
Decimal, or binary number. This will use a couple different methods to display 8E8E :
0xFF)
0b11111111)
0x79)
0b01111001)
Page 102 of 149
display.fill(1)
display.print("A")
display.scroll(2)
display[3] = " "
display.show()
Page 103 of 149
True or False :
display.colon[0] = False
There are a couple of different ways to set the left-side dots on the large 7-segment
display. The first way is to use the colon property like above:
display.colon[1] = False
If you would like to set the dots individually, you can do that using the top_left_dot
and bottom_left_dot properties and set them to True or False :
display.top_left_dot = True
display.bottom_left_dot = True
If you would like to set the upper-right dot, you can do this using the ampm property:
display.ampm = True
character. This may be useful for displaying a phone number, words using only letters
A-F, or other numeric data:
display.marquee('Deadbeef ')
Page 104 of 149
display.marquee('Deadbeef', 0.5, False)
Bi-Color 8x8 Matrix
This version of the LED backpack is designed for these bright and colorful
square=pixeled 8x8 matrices. They have 64 red and 64 green LEDs inside, for a total
of 128 LEDs controlled as a 8x16 matrix. This backpack solves the annoyance of using
24 pins or a bunch of chips by having an I2C constant-current matrix controller sit
neatly on the back of the PCB. The controller chip takes care of everything, drawing
all 128 LEDs in the background. All you have to do is write data to it using the 2-pin
I2C interface. There are three address select pins so you can select one of 8
addresses to control up to 8 of these on a single 2-pin I2C bus (as well as whatever
other I2C chips or sensors you like). The driver chip can 'dim' the entire display from
1/16 brightness up to full brightness in 1/16th steps. It cannot dim individual LEDs, only
Page 105 of 149
Assembly
Pay close attention to the instructions for positioning the matrix. It must be
oriented correctly to work and is almost impossible to remove it once it has been
soldered to the backpack!
backpack as well as a 8x8 matrix. You'll
Page 106 of 149
side.
The matrix must be soldered on the
correct orientation or it will not work!
Check for the side of the matrix that has
printing on it. Then look for the front of the
PCB that has a circle instead of a square in
the corner and line those up as shown on
the left
Do not solder the matrix over the chip on
the back of the backpack - it will not work
then!
the matrix.
Solder all 24 pins.
Page 107 of 149
Clip the long pins
breadboard.
Page 108 of 149
header.
Solder 'em!
Arduino Setup
We wrote a basic library to help you work with the bi-color 8x8 matrix backpack. The
Page 109 of 149
microcontrollers.
File→Examples→Adafruit_LEDBackpack→bicolor88 example sketch. Upload it to your
different drawing routines.
adafru.it/aYM)
Page 110 of 149
matrix supports everything the Adafruit GFX library - drawing pixels, lines, rectangles,
I2C.
when you start
display blinking.
Page 111 of 149
graphics commands.
Wiring
https://adafru.it/ICo
Page 112 of 149
Library Setup
on your board.
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 113 of 149
Wiring
the display.
Matrix.
Page 114 of 149
https://adafru.it/ICp
Setup
//adafru.it/BSN)!
Pillow Library
Page 115 of 149
Initialization
necessary modules. In this case, we'll use board and Matrix8x8x2 .
Adafruit board).
import board
from adafruit_ht16k33.matrix import Matrix8x8x2
i2c = board.I2C()
matrix = Matrix8x8x2(i2c)
0x71 like this:
matrix = Matrix8x8x2(i2c, address=0x71)
Page 116 of 149
To set individual pixels to specific colors, you simply treat the matrix object as a
multidimensional list and set it to matrix.LED_RED , matrix.LED_GREEN ,
matrix.LED_YELLOW or matrix.LED_OFF .
matrix[0,
matrix[4,
matrix[7,
matrix[7,
0]
4]
7]
0]
matrix.LED_RED
matrix.LED_GREEN
matrix.LED_YELLOW
matrix.LED_OFF
Page 117 of 149
To fill the entire matrix, just use the fill() function and pass in the color you want to set
it to. For instance, if you wanted to set everything to green, you would use:
matrix.fill(matrix.LED_GREEN)
Shifting the Matrix
matrix.shift(2, 0)
matrix.shift(-1, 0)
matrix.shift(0, -3)
matrix.shift(-2, 2)
to the other side.
matrix.shift_up()
# Shift pixels up
matrix.shift_left()
# Shift pixels left
matrix.shift_down()
# Shift pixels down
# Loop pixels up
# Loop pixels left
# Loop pixels down
# Loop pixels right
Matrix and should include pure Green, Red, or Yellow. Anything else will be
Page 118 of 149
considered to be off. In this case, it should be 8x8 pixels. As an example, you can
save the image below as myimage.png.
Download Image
https://adafru.it/ICQ
like this:
import board
matrix = matrix.Matrix8x8x2(board.I2C())
matrix.image(image)
This version of the LED backpack is designed for these bright and colorful bi-color
bargraph modules. Each module has 12 red and 12 green LEDs inside, for a total of 24
LEDs controlled as a 1x12 matrix. We put two modules on each backpack for a 24-bar
long bargraph (48 total LEDs).
This backpack solves the annoyance of using lots of pins or a bunch of chips by
having an I2C constant-current matrix controller sit neatly on the back of the PCB. The
Page 119 of 149
controller chip takes care of everything, drawing all 48 LEDs in the background. All
you have to do is write data to it using the 2-pin I2C interface. There are three
address select pins so you can select one of 8 addresses to control up to 8 of these
Assembly
Pay close attention to the instructions for positioning the bargraphs. They must
be oriented correctly to work and is almost impossible to remove them once
Remove the parts from packaging and place the LED bargraphs over the outlines on
the top of the PCB.
The bargraph must be soldered on the correct orientation or it will not work! Check
for the side of the bargraph that has printing on it. Then look for the outline on the
PCB that has "Text on this side" marked!
Do not solder the matrix onto the back of the PCB, it won't work either!
Page 120 of 149
To keep the two bargraphs lined up nicely, you can use a little masking or scotch tape
on the bargraph modules, tape them so they are in a straight line. There is a little play
during soldering so if you don't do this the two modules may not be in a perfect line.
Page 121 of 149
Turn over the PCB and bend oppositecorner pins of the modules out so that the
modules are fixed in place against the
PCB. Now is a good time to do a last
check that you oriented the modules the
right way!
Page 122 of 149
Solder all the module pins in!
Page 123 of 149
OK nice work!
Once soldered, clip each pin. They're quite
short and the pins are thicker than usual,
so do this over/inside a trash bin so that
the pins don't fly off and it you or your
pets.
Everything should be neat and clipped,
you're done!
This is an optional step - you only need to do this step if you're planning on using the
bargraph in a breadboard. Chances are you may want to solder wires directly to the
pads instead, so you can mount the bargraph elsewhere. Anyhow, skip this step if its
not for you!
Page 124 of 149
Break off a piece of male header, 4 pins
long. Plug the long ends into a solderless
breadboard.
Place the PCB on top. you may need to
support it a little since its quite long.
Page 125 of 149
Solder these 4 pins too, since you're good
at it now this should be easy.
We wrote a basic library to help you work with the bi-color bargraph backpack. The
Wiring to the bargraph is really easy
• Connect SCL to the I2C clock - on Arduino UNO thats Analog #5 (or SCL), on the
• Connect SDA to the I2C data - on Arduino UNO thats Analog #4 (or SDA), on the
microcontrollers.
Page 126 of 149
Page 127 of 149
File→Examples→Adafruit_LEDBackpack→bargraph24 example sketch. Upload it to
your Arduino as usual. You should see a basic test program that tests all the LEDs
with different colors.
adafru.it/aYM)
Using the library interface is very easy. Start by creating the object with
Adafruit_24bargraph bar = Adafruit_24bargraph();
you can name it whatever you want, not just bar
Then initialize it with
bar.begin(0x70); // pass in the address
You can init with any address from 0x70 to 0x77, just make sure you solder in the
matching solder jumpers!
Finally, write to the bargraph with
Page 128 of 149
bar.setBar(lednumber, ledcolor);
Where lednumber is 0 thru 23. ledcolor can be LED_RED, LED_YELLOW, LED_GREEN
or LED_OFF
The drawing routines only change the display memory kept by the Arduino. Don't
forget to call bar.writeDisplay() after drawing to 'save' the memory out to the matrix via
I2C.
when you start
display blinking.
Wiring
We'll cover how to wire the Bargraph to your CircuitPython microcontroller board.
First assemble your Bargraph.
Connect the Bargraph to your microcontroller board as shown below.
Page 129 of 149
Microcontroller 3V to Bargraph VIN
Microcontroller GND to Bargraph GND
Microcontroller SCL to Bargraph SCL
Microcontroller SDA to Bargraph SDA
https://adafru.it/IfA
Library Setup
on your board.
Bundle Install
adafru.it/ABU).
• adafruit_ht16k33
Page 130 of 149
Wiring
the display.
We'll cover how to wire the Bargraph to your Raspberry Pi. First assemble your
Bargraph.
Connect the Bargraph as shown below to your Raspberry Pi.
Page 131 of 149
Raspberry Pi 3.3V to Bargraph VIN
Raspberry Pi GND to Bargraph GND
Raspberry Pi SCL to Bargraph SCL
Raspberry Pi SDA to Bargraph SDA
https://adafru.it/IfB
Setup
//adafru.it/BSN)!
Page 132 of 149
Initialization
necessary modules. In this case, we'll use board and BiColor24 .
Adafruit board).
Then to initialize the bargraph, you just pass i2c in.
import board
from adafruit_ht16k33.bargraph import Bicolor24
i2c = board.I2C()
bc24 = Bicolor24(i2c)
bridged any of them. For instance, if you bridge only the a0 pad, you would use 0x71
like this:
bc24 = Bicolor24(i2c, address=0x71)
Page 133 of 149
To set individual bars to specific colors, you simply treat the bc24 object as a list and
set it to bc24.LED_RED , bc24.LED_GREEN , bc24.LED_YELLOW or bc24.LED_OFF .
bc24[0]
bc24[1]
bc24[2]
bc24[3]
bc24.LED_RED
bc24.LED_GREEN
bc24.LED_YELLOW
bc24.LED_OFF
To fill the entire bargraph, just use the fill() function and pass in the color you want to
set it to. For instance, if you wanted to set everything to green, you would use:
bc24.fill(bc24.LED_GREEN)
The coolest part about the I2C backpacks is that you can connect more than one
using just the same 2 pins. This opens possibilities for all kinds of multi-display
projects (https://adafru.it/aQt).
For a project that shows this is practice, check out this page (https://adafru.it/aQF) on
animating multiple LED backpacks
Page 134 of 149
Wire it Up
To connect another backpack to your project, just wire it in parallel with the first one
as in the diagram below.
If your backpack has 5 connectors, just wire all 5 in parallel.
Page 135 of 149
For each backpack you add, you need to configure a different I2C address. You can
keep adding backpacks in the same way until you run out of addresses. See the next
page for how to configure the address on your backpack.
The HT16K33 driver chip on these LED backpacks has a default I2C address of 0x70.
Since each device on an I2C bus must have a unique address, its important to avoid
collisions or you'll get a lot of strange responses from your electronic devices!
Luckily, the HT16K33 has 2 or 3 address adjust pins, so that the address can be
changed! The mini 0.8" 8x8 matrix backpack has 2 address adjust pins. The 1.2" 8x8,
bi-color 8x8, bi-color bargraph and 4 x 7-segment backpacks have 3 address adjust
pins.
That means that you can set the backpacks to these addresses:
• Mini 0.8" 8x8: 0x70, 0x71, 0x72, 0x73
• Small 1.2" 8x8: 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77
• 4 x 7-segment: 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77
Page 136 of 149
• Bi-color 1.2" 8x8: 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77
• Bi-color 24-bargraph: 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77
You can mix-and-match matrices, as long as each one has a unique address!
Changing Addresses
You can change the address of a backpack very easily. Look on the back to find the
two or three A0, A1 or A2 solder jumpers. Each one of these is used to hardcode in
the address. If a jumper is shorted with solder, that sets the address. A0 sets the
lowest bit with a value of 1, A1 sets the middle bit with a value of 2 and A2 sets the
high bit with a value of 4. The final address is 0x70 + A2 + A1 + A0. So for example if A
2 is shorted and A0 is shorted, the address is 0x70 + 4 + 1 = 0x75. If only A1 is
shorted, the address is 0x70 + 2 = 0x72
A2 does not appear on the mini 0.8" 8x8 matrix, so you cannot set the address higher
than 0x73
On the 1.2" 8x8 backpacks, the labels for A1 and A2 are swapped! Sorry about
that!
Page 137 of 149
Once you've adjusted the address on the backpack, you'll also want to adjust the
address in the code!
For the Arduino library we wrote, its simple. For example, lets say you want to have
two seven-segment matrices. One is set to address 0x70 and the other is set to 0x71.
Find this code in the example
Adafruit_7segment matrix = Adafruit_7segment();
void setup() {
Serial.begin(9600);
Serial.println("7 Segment Backpack Test");
matrix.begin(0x70);
And change it to this:
Adafruit_7segment matrix1 = Adafruit_7segment();
Adafruit_7segment matrix2 = Adafruit_7segment();
void setup() {
Serial.begin(9600);
Serial.println("Double 7 Segment Backpack Test");
matrix1.begin(0x70);
matrix2.begin(0x71);
Page 138 of 149
That is, instantiate two matrix objects. Then one is called with begin(0x70) and the
other is called with begin(0x71). Each one can be used individually. If you need more
matrices, just instantiate more objects at the top and begin() each one with the unique
i2c address.
F.A.Q.
I want to use these modules with other non-Arduino, how
can I port the code?
The best way to get up and running is to read the HT16K33 driver datasheet
available at http://learn.adafruit.com/adafruit-led-backpack/downloads (https://
adafru.it/aMx) - the backpacks all use this chip to do all the LED driving. You can
cross-reference this document with the Arduino library code to adapt it to your
platform. Any microcontroller that has I2C host support should be able to drive the
backpacks but we only provide Arduino example code at this time
I'd like to use these backpacks with Python / Linux (e.g. a
Raspberry Pi)
You're in luck! We have a full tutorial here that covers using the 7-segment and 8x8
matrices on a Pi with Python code -> http://learn.adafruit.com/matrix-7-segmentled-backpack-with-the-raspberry-pi (https://adafru.it/aPj)
I am having strange problems when combining Adafruit
Motor Shield/Servo Shield (PCA9685 based) with the
Adafruit LED Matrix/7Seg Backpacks
We are not sure why this occurs but there is an address collision even though the
address are different! Set the backpacks to address 0x71 or anything other than the
default 0x70 to make the issue go away
What is the current draw of the backpacks?
It depends on how many LEDs you have lit at once!
But a rough estimation is 20 milliamps per segment. Note that segments are
multiplexed per row so that means
• 8x8 Mono Matrix (8 rows)= 8 x 20mA = 160mA max
©Adafruit Industries
Page 139 of 149
• 7-segment backpacks (7 segments + 1 dot) = 8 x 20mA = 160 mA
• Alphanumeric (14 segments) = 14 x 20mA = 280mA
• Bi-color 8x8 and 8x16 matrix (16 rows) = 8 x 16 = 320mA
But again, this is maximum and assumes all digits and all segments are lit up! Your
average use may be 1/10 to 1/2 of this amount
Downloads
Software
You'll need to install the following libraries to use any of the LED backpacks.
adafru.it/aYM)
Page 140 of 149
Files
• Fritzing objects in Adafruit Fritzing library (https://adafru.it/aP3)
• EagleCAD PCB files for all backpacks in GitHub (https://adafru.it/aLJ)
• The backpacks all use the HT16K33 chip solely for LED driving (https://adafru.it/
aMy) - the mini 8x8's use the 24 pin version and the others use the 28 pin
vesion
Schematic & fabrication print
Page 141 of 149
Page 142 of 149
Page 143 of 149
Page 144 of 149
Page 145 of 149
QT
Page 146 of 149
STEMMA QT Version
Page 147 of 149
Original Version
Quad 1.2" 7-Segment
Page 148 of 149
Bicolor 24-Bargraph
Page 149 of 149
