Economical Laser
VLM-650-04 Series
Lead Wire Type
Spring Type
FEATURES:
Economical Red Dot Laser.
Ideal Laser module if cost is a very important consideration.
This module has integrated optic, laser diode, and APC driver circuit.
APC Driver Circuit enables the Laser output power safe and constant.
Aspherical plastic lens provides Dot Laser.
Dimensions : Ø 6.55 x 21.1 mm (Ø 0.258" x 0.831").
Wavelength : 650 nm
Output power : LPT - Class II – less than 1mW
LPA - Class IIIa – less than 2.5mW.
Beam Divergence (Half Angle) : 0.6 mRad
2.6~6 VDC operation.
Connection type : Lead wire / Spring.
APPLICATIONS:
Economical Red Dot Laser - Low cost solution for consumer grade positioning,
measuring, pointing and laser sighting device.
Wood processing.
Metal processing.
Stone processing.
Textile industry.
Food industry.
Automotive industry.
Medical science.
@Copyright 2021 Quarton inc.All Rights Reserved.
www.quarton.com
VLM-650-04 Series
OUTLINE DIMENSIONS (UNITS: mm)
Outline (Lead Wire type)
Outline (Spring type)
SPECIFICATIONS
VLM-650-04
SPECIFICATIONS
LPT
1 Dimensions
LPA
SPT
SPA
2 Operating voltage (Vop)
2.6~6 VDC
3 Operating current (Iop)
Less than 35mA Less than 50mA Less than 35mA Less than 50mA
4 Laser power output
Less than 1mW Less than 2.5mW Less than 1mW Less than 2.5mW
5 Laser class
Class II
6 Wavelength at peak emission (λp)
Class IIIa
Class II
645~665nm
7 Collimating lens
8 Output aperture
3mm
9 Beam shape
10 Spot size at 5M
11 Divergence (Half Angle)
12 Beam alignment
13 Operating temp. range*
14 Storage temp. range
Ellipse
6±1 mm
0.6 mRad
Less than 3°
+15°C ~+30°C (Room Temperature)
-20°C ~+65°C
www.quarton.com
Class IIIa
VLM-650-04 Series
15 Housing
Zinc alloy
16 Potential of housing**
VDD(+)
17 Electrostatic discharge (ESD)
18 Moisture sensitivity level (MSL)
19 Connection type
20 Cable length
20KV
Level 1 - acc to JEDEC J-STD-020E.
1007-26 AWG
Spring
115±15mm
4±1mm
21 Mean time to failure (MTTF) 25°C
5000hrs
22 Application
Economic type
23 Suggestion work distance
1~10 meters / 3~40 feet
* Operation temperature: it means within this temperature range, the laser spot/line will not be affected to change the spot size/line
width. It can still work over this range, but the laser spot size or laser line width will be larger.
** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the machine be
avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to the laser module is
strongly recommended.
ORDER CODE
Order Code
Wavelength
Laser Power Output
Laser Class
Connection Type
VLM-650-04 LPA
650 nm
Less than 2.5mW
Class IIIa
Lead Wire
VLM-650-04 LPT
650 nm
Less than 1mW
Class II
Lead Wire
VLM-650-04 SPA
650 nm
Less than 2.5mW
Class IIIa
Spring
VLM-650-04 SPT
650 nm
Less than 1mW
Class II
Spring
SAFETY LABEL
www.quarton.com
很抱歉,暂时无法提供与“VLM-650-04-SPA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+206.301071+25.59156
- 10+161.5184910+20.03630
- 100+141.08483100+17.50151
- 500+129.40909500+16.05314
