TW3040/ TW3042 Permanent Mount GPS L1 Antenna
The TW3040/TW3042 is a professional grade,
permanent mount GPS L1 antenna, specially designed
for professional precision timing applications.
The TW3040/TW3042 features a custom high
performance, wide band patch element, a 40dB gain
LNA stage and a high rejection out-of-band SAW filter.
The TW3042 is equipped with a sharp SAW pre-filter
to provide strong protection from out-of-band signals.
It provides ±10MHz bandwidth centred on 1575.42
MHz and covers the GPS L1, Galileo E1 and SBAS
(WAAS/EGNOS/MSAS) signals, and it provides great
axial ratio, excellent circular polarized signal reception,
great multipath rejection and great out-of-band signal
rejection.
The TW3040/TW3042 is housed in a permanent
mount industrial-grade weather-proof enclosure and
two options for pole mounting are available an Lbracket (P/N#23-0040-0) or a pipe mount (P/N#230065-0).
TW3040/TW3042 Dimensions (mm)
Flat Radome shown. Conical Radome also available
Applications
Mission Critical GPS Tracking & Timing
Precision Agriculture, Mining & Construction
Military & Security
Avionics
Law Enforcement & Public Safety
Fleet Management & Asset Tracking
Features
Benefits
Great axial ratio
Low noise LNA: 1 dB
High rejection SAW filter
High gain: 40 dB typ.
Low current: 15 mA typ.
ESD circuit protection: 15 KV
Wide voltage input range: +2.5 to 16 VDC
Weather proof housing: IP67
Excellent multipath rejection
Increase system accuracy
Excellent signal to noise ratio
Great out of band signal rejection
Ideal for harsh environments
RoHS and REACH compliant
TW3040/TW3042 Permanent Mount GPS L1 Antenna
Specifications
Vcc = 3V, over full bandwidth, T=25°C
Antenna
Antenna Architecture
Antenna Element Gain (100mm ground plane)
Axial Ratio (over full bandwidth)
Electrical
Architecture
Frequency Bandwidth
Polarization
Gain
Out-of-Band Rejection
1600 MHz
>1620 MHz
VSWR (at LNA input)
Noise Figure
Supply Voltage Range
Supply Current
ESD Circuit Protection
Mechanicals & Environmental
Mechanical Size
Operating Temp. Range
Enclosure
Weight
Environmental
Shock
Vibration
Salt Spray
Single-feed RHCP ceramic patch
4 dBic at 90°
4 dB at 90°
3 stage LNA circuit + a mid section SAW filter.
(Pre-filter option available)
1575 MHz ± 10 MHz
RHCP
TW3040: 40 dB min. TW3042: 39 dB min
TW3040
TW3042
>42 dB
>50 dB
>31 dB
>50 dB
>45 dB
>70 dB
很抱歉,暂时无法提供与“33-3042-00-01-5000”相匹配的价格&库存,您可以联系我们找货
