33-3372-01-01-0000
33-3372-01-01-0000
    TALLYSMANWIRELESS
    HIGH GAIN 40 DB W/ PREFILTER SMA
33-3372-01-01-0000 数据手册
TW3370/TW3372 40dB Wideband GPS/GLONASS Antenna The TW3370/TW3372 is a high Gain (40dB) GNSS antenna covering the GPS L1, GLONASS L1 and SBAS (WAAS, EGNOS & MSAS) frequency band (1575 to 1606 MHz). It features a patch element with 40% wider bandwidth than previously available in this format. Unlike its competitors, both GPS-L1 and GLONASS signals are included in the 1dB received power bandwidth. The TW3370/TW3372 has a three stage Low Noise Amplifier with a mid-section SAW. A tight pre-filter is available with the TW3372 to protect against saturation by high level sub-harmonics and L-Band signals making it particularly suitable for timing applications. TW3370 / TW3372 Shown with Conical Radome. Low Profile Radome also available The TW3370/TW3372 has a 19mm (3/4 Inch) though hole, permanent mount white-metal base, with an industrial-grade, IP67 compliant conical radome. Two options for pole mounting are available an L-bracket (P/N#23-0040-0) or a pipe mount (P/N#23-0065-0). Applications • • • • Timing applications Fixed installations Cost Sensitive Mission Critical Positioning Military & Security Features Benefits • • • • • • • • • • • • • 40dB LNA Gain 1 dB LNA Noise Figure (TW3370) Available Pre-filter (TW3372) Wide voltage input range: 2.5 to 16 VDC IP67 Compliant conical radome Low Power: 9mA typ. at 2.3Vcc min. Bandwidth fully Includes GPS-L1 & GLONASS Excellent multipath rejection Increased system accuracy Excellent signal to noise ratio Great out of band signal rejection Ideal for harsh environments RoHS, REACH, and CE compliant TW3370/TW3372 40dB Wideband GPS/GLONASS Antenna Specification Antenna Architecture 1 dB Bandwidth 10dB Return Loss Bandwidth Antenna Gain (with 100mm ground plane) Axial Ratio Electrical Architecture TW3370 TW3372 Filtered LNA Frequency Bandwidth Polarization Gain Gain flatness Out-of-Band Rejection LNA stage 2 SAW Pre-filter ->LNA stage 1 -> SAW filter-> LNA stage 2 1575 to 1606 MHz RHCP 41 dB min., TW3370 40dB min., TW3372 +/- 2 dB, 1575 to 1606 MHz >32 dB (TW3370) >50dB (TW3372) >25 dB >50dB >35 dB >70dB
33-3372-01-01-0000 价格&库存
很抱歉,暂时无法提供与“33-3372-01-01-0000”相匹配的价格&库存,您可以联系我们找货
