1524.000.01
    FEIGELECTRONIC
    手持式231x80x100mm,RS232
    ID ISC.PRH101-A HAND-HELD READER
1524.000.01 数据手册
 HF Handheld Reader ID ISC.PRH101-A / PRH102-B / PRH101-USB FEATURES  Variable interfaces (RS232, USB, Bluetooth)  Anti-collision function  Multi-tag reader for ISO15693 and ISO18000-3  2 operation modes: FEIG ISO Host Mode & Scan Mode  SHORT DESCRIPTION TECHNICAL DATA The handheld readers ID ISC.PRH101/102 are designed for contactless data exchange with common ISO 15693 transponders. They can be used for those applications, read ranges up to 13cm* (PRH102-B) resp. up to 20cm* (PRH101A/-USB) are required. Dimensions (W x H x D) Weight Housing Protection class Color Operating frequency Transmitting power Supply voltage - ID ISC.PRH101-A - ID ISC.PRH102-B - ID ISC.PRH101-USB Current consumption Power consumption Antenna Interfaces - ID ISC.PRH101-A - ID ISC.PRH102-B - ID ISC.PRH101-USB Due to different interfaces the handheld readers can be integrated in existing systems easily. So they are suitable for several applications in retail, logistics and industry. The anti-collision function allows the handheld readers identification of up to 30 transponders simultaneously. With a switchable voltage on the antenna line a LED located in the antenna can be operated. For programming host applications on mobile devices FEIG offers DLLs for different systems like Pocket PC, CE3.0, CE.NET, Windows-, Linux- and Java systems. Address setting for interface - ID ISC.PRH101-A - ID ISC.PRH102-B - ID ISC.PRH101-USB *Read range depends on the transponder size. Here made statements relate to an inlet size of 76 x 45 mm Signal generator, optical Signal generator, acoustic Supported transponders 230 mm x 100 mm x 80 mm 320 g (without batteries) Plastic ABS IP 30 RAL 9002 / RAL 7044 13.56 MHz 0.5 W ± 2 dB 5V DC +/- 0,2V regulated 4 Mignon cells 1,2-1,5V AA USB High Powered Interface maximum 0.5 A maximum 2.5 VA integrated RS232 Bluetooth (Serial port profile) USB (12 Mbit) Software (up to 254 addresses) Bluetooth MAC address Device-ID of the reader Protocol modes 1 LED (multicolored) buzzer ISO 15693 (ISO 18000-3 MODE 1)* ISO Host Mode, Scan Mode Temperature range Operation Storage Relative humidity 0 °C up to 50 °C –20 °C up to 70 °C 5…95 % (not condensing) * e.g. EM HF ISO Chips, Fujitsu HF ISO Chips, IDS Sensor Chips, Infineon my-d, KSW Sensor Chips, NXP I-Code, STM ISO Chips, TI Tag-it STANDARD CONFORMITY ORDER DESCRIPTIONS ID ISC.PRH101-A HF Handheld Reader; RS232 (with 2.5 m interface cable) ID ISC.PRH102-B HF Handheld Reader; Bluetooth ID ISC.PRH101-USB HF Handheld Reader; USB 2.0 (with 2.5 m USB cable) ID NET.5V-B 5V power supply for ID ISC.PRH101-A ID CHA.NiMH-A Battery Charger for ID ISC.PRH102-B Radio licence Europe USA Canada EMC Safety Low Voltage Human Exposure Vibration Shock EN 300 330 FCC 47 CFR Part 15 IC RSS-GEN, RSS-210 EN 301 489 EN 60950 EN 50364 EN 60068-2-6 10…150 Hz: 0,075 mm / 1 g EN 60068-2-27 acceleration: 30 g FEIG ELECTRONIC reserves the right to change specification without notice at any time. State of information: August 2016.
1524.000.01 价格&库存
很抱歉,暂时无法提供与“1524.000.01”相匹配的价格&库存,您可以联系我们找货
