C215
C215
    KLEINTOOLS
    BITPOWERCOMBINATION#21.00"
C215 数据手册
COMBO-TIP N R E A P P LICA TI FO TH T COMBI ON GH I R ION AT T HE D R I V E R S COMBO-TIP D R I V E R S FINALLY, A PERFECTLY SHAPED COMBO TIP. The Combination-Tip Drivers are designed for maximum contact with combination-head screws most commonly found on electrical devices and fittings. Available in: Fixed-Blade Screwdrivers Impact Rated Power Drivers 11-in-1 Screwdriver TCH SWI E DRIV • Custom heat-treated to withstand the torque needed to fasten all types of combination head screws. • Made with quality steel for long-lasting bit shape and strength. • Cushion-Grip handle for maximum comfort and torque. • Made in the USA. Cat. No. UPC# 0-92644+ 731-4 37375-1 732-4 Tips Description Length #1 Fixed-Blade Combo-Tip Screwdriver 4" (102 mm) 32376-8 #2 Fixed-Blade Combo-Tip Screwdriver 4" (102 mm) 32378 32378-2 #1 and #2 Fixed-Blade Combo-Tip Screwdriver 2 Piece Set 4" (102 mm) 32505* 32505-2 11-in-1 Screwdriver with Double-Ended Combo Bit 8" (203 mm) #1 #2 3/16" 1/4 #1 #2 #1 #2 1/4" 5/16" 3/8" 32752 32572-4 #1 and #2 Combo Replacement Bit for 32505 – 2 pack 1.26" (32 mm) C1-1-5 32746-9 #1 #1 Combo-Tip Power Driver Bits x 1" (25 mm) – 5 pack 1" (25 mm) C1-35-5 32748-3 #1 #1 Combo-Tip Power Driver Bits x 3.5" (89 mm) – 5 pack 3.5" (89 mm) C2-1-5 32747-6 #2 #2 Combo-Tip Power Driver Bits x 1" (25 mm) – 5 pack 1" (25 mm) C2-35-5 32749-0 #2 #2 Combo-Tip Power Driver Bits x 3.5” (89 mm) – 5 pack 3.5" (89 mm) *assembled in the USA with imported and domestic components See our complete line of Screwdrivers and Nut Drivers www.kleintools.com © 2014 Klein Tools, Inc. Lincolnshire, IL 60069-1418 96252
很抱歉,暂时无法提供与“C215”相匹配的价格&库存,您可以联系我们找货
