Illumination
The Klein Tools Illumination line
provides you the tools to make
your life easier and more efficient
on and off the jobsite. From
hands-free lighting solutions such
as headlamps and worklights to
handheld flashlights and penlights,
you can find the right tool to light
your way. And as with all Klein
products, you can be assured they
offer the durability and reliability
you know and trust.
Illumination
150
150
Lumens
Lumens
6h
6h
Headlamp
50
50
• Anti-slip silicone strap keeps headlamp securely fastened to hard hat
10h
10h
Lumens
Lumens
• Strap comes pre-adjusted for quick fit to hard hat
• 45-degree tilt for varied beam direction to point light where it is needed most
• Two modes: High (spotlight) and Low (floodlight)
66ftft
• 3 x AAA batteries included
FL 1 STANDARD
Two Modes:
150
Lumens
Spotlight
Floodlight
Cat. No.
56220
50
Lumens
6h
Lumens
Run Time
50
Spotlight - 150,
6
Lumens hrs 10h
Floodlight - 50
10 hrs.
56220
FL
1 STANDARD
69408
FL 1 STANDARD
150
Lumens
6h
Drop Height
6 ft. (1.8 m)
Batteries
6 ft
3 x AAA
10h
Weight
5.6 oz. (159 g)
6 ft
Inspection Penlight with Laser
NEW!
• LED penlight for up-close lighting in dim areas
• Laser pointer aids in pinpointing objects in out-of-reach locations
• Glow ring tip charges while the light is on and allows for easy retrieval in the dark
• 10 ft. drop rating
• Pocket clip for easy, convenient access
• Aluminum body with cushion-grip handle
• 2 x AAA batteries included
10 ft
45
Cat. No.
Lumens
56026 NEW! 45
Run Time
10 hrs.
Drop Protection
10 ft. (3 m)
56026
Batteries
2 x AAA
Weight
2.8 oz. (79 g)
Penlight
• Aluminum body with durable cushion grip handle offers a safe and comfortable hold
36
• Sturdy clip attaches to pocket or shirt for hands-free access and availabilityLumens
Rubberized
power
button
provides
non-slip
touch
10 ft
36 usage
• Soft-on feature for quick reference lighting; click to stay on for extended
Lumens
• Impact and water resistant
10 ft
36
Lumens
FL 1 STANDARD
FL 1 STANDARD
FL 1 STANDARD
FL 1 STANDARD
36
Lumens
FL 1 STANDARD
10 ft
10h
5h
10 ft
Cat. No.
56222
Lumens
36
Run Time
5 hrs.
Drop Height
10 ft. (3 m)
Batteries 10hWeight
2 x AAA
2.4 oz. (68 g)
10h
226
10h
www.kleintools.com
56222
Illumination
Flashlight with Worklight
• Bright, focused flashlight and broadcasting work light in one tool
• Strong magnet for secure, hands-free illumination
• Durable; IP67 waterproof and dust proof with 10 ft. drop rating
235
100
NEW!
56028
FL 1 STANDARD
6h
12h
10 ft
Cat. No.
56028 NEW!
Lumens
Flashlight 235;
Worklight 100
Run Time
Flashlight 6 hrs.;
Worklight 12 hrs.
Drop Height
10 ft. (3 m)
Batteries
3 x AAA
Slide Focus Flashlight
flashlight with adjustable focus; slide head forward
• Aluminum
for spotlight, back for floodlight
• Durable cushion grip handle for safe and comfortable hold
• Rubberized power button provides non-slip touch
36
Lumens
FL 1 STANDARD
FL 1 STANDARD
215
Lumens
Weight
5.5 oz.
(156 g)
FL 1 STANDARD
FL 1 STANDARD
36
Lumens
36
Lumens
10 ft
56223
10 ft
FL 1 STANDARD
10 ft
10h
6h
10ft
Cat. No.
56223
Lumens
215
Run Time
6 hrs.
Drop Height
10 ft. (3 m)
Batteries
3 x AAA
Weight
10h
5.6 oz. (159 g)
10h
6.5 h
Clip Light
• Rugged, durable rubber overmold for safe and comfortable grip 150
150
options: magnetized clip for mounting to magnetic Lumens
• Hands-free
Lumens
surface or clip for shirt or pocket
10ft
150
• Two modes: High/Low
Lumens
10ft
150
150
50
Lumens
6h
Lumens
Lumens
FL 1 STANDARD
FL 1 STANDARD
10ft
6h
FL 1 STANDARD FL 1 STANDARD
Cat. No.
56221
Lumens
High: 150,
Low: 50
Run Time
High: 6 hrs.
Low: 10 hrs.
Drop Height
10 ft. (3 m)
Work Light
• Swivel hook and magnet for hands free use
• Three AAA batteries included
Cat. No.
55437
Lumens
50
Run Time Diameter
5 hrs.
2-51/64"
(71.0 mm)
50
Lumens
10h
6h
Batteries 6hWeight
3 x AAA 6 ft 4.9 lbs. (2.22
kg)
10h
6h
56221
6 ft
Depth
1-1/2"
(38.1 mm)
Batteries
3 x AAA
Weight
3.2 oz.
(91 g)
55437
227
www.kleintools.com
很抱歉,暂时无法提供与“56221”相匹配的价格&库存,您可以联系我们找货
