SFP Gigabit Ethernet Transceiver
PRODUCT NUMBER: TSD-SxCH1-C11
Specification
Small Form Factor Pluggable
Duplex LC Receptacle – SFP
Optical Transceivers
1000BASE-SX
1250Mbit/s
Ordering Information
T S D - S x C H 1 - C 1 1
Category
SD : DDMI Product
Model Name
TSD-S1CH1-C11
TSD-S2CH1-C11
Media
Multi-Mode Fiber
Voltage / Temperature
1 : 3.3V / +0℃~ +70℃
2 : 3.3V / -40 ℃~ +85℃
Voltage Category Device type Interface
3.3V
With DDMI VCSEL / PIN
Wavelength
SD/LOS
AC / AC
Coupling
LVTTL
Temperature Distance Latch Color
+0C~+70C
550m
Black
-40C~+85C ( Table 1 )
Fiber Core Dimension
Modal Bandwidth
Fiber Type
Distance
50 μ m
500 MHz*km
OM2
550m
850nm
50 μ m
400 MHz*km
62.5 μ m
200 MHz*km
62.5 μ m
160 MHz*km
500m
OM1
275m
220m
Table 1
Formerica OptoElectronics Inc .
5F-11, No.38, Taiyuan St.,Zhubei City,
Hsinchu County 30265, Taiwan
Ph: +886-3-5600286 Fax: +886-3-56002398
Version 02
Page
1
Features
ROHS Compliant
Standard Small Form Factor Pluggable Package – SFP MSA Compliant
Digital Diagnostic SFF-8472 Rev.10.2 Compliant
Gigabit Ethernet Standard ( IEEE802.3Z 1000BASE-SX ) Compliant
Fibre Channel Standard ( 100-M5-SN-I and 100-M6-SN-I ) Compliant
Laser Class 1 Product – IEC60825-1 Compliant
Standard Duplex LC Receptacle Optical Interface
Single + 3.3 V Power Supply
Differential LVPECL Data Input and Output
LVTTL Loss of Signal
Serial ID through I2C Interface
Low Power Consumption
Absolute Maximum Ratings
Parameter
Symbol
Min
Typ
Max
Unit
Storage temperature
TS
-40
85
C
Supply voltage
VCC
V
5
95
VIN
VCC
V
Symbol
Min
Typ
Max
Unit
VCC
3.1
3.3
3.5
V
-40
85
250
Operating Relative Humidity
Input voltage
Operating Conditions
Parameter
Supply Voltage
Operating Case temperature ( TSD-S1CH1-C11 )
Operating Case temperature ( TSD-S2CH1-C11 )
Total Current ( Transmitter + Receiver )
Tc
Icc
ºC
mA
Version 02
Page
2
Transmitter Specifications ( VCC=3.1V~3.5V;Tc= 0oC~70oC / Tc= -40oC~85oC )
Parameter
Symbol
Min
Typ
Max
Unit
Output Optical Power
Pout
-9
-3
dBm
Extinction Ratio
ER
9
dB
Center Wavelength
λC
830
860
nm
Spectral Width (RMS)
σ
0.85
nm
Rise/Fall time (20-80%)
Tr,f
260
ps
Relative Intensity Noise
RIN
-117
dB/Hz
Optical Characteristics
Compliant with IEEE 802.3z
Output Eye
POFF
-45
dBm
Differential Input Voltage
VDIFF
0.4
2.0
V
Tx_Disable_Input_High
VDISH
2.0
VCC+0.3
V
Tx_Disable_Input_Low
VDISL
V
Tx_Fault_Output_High
VFH
2.0
VCC+0.3
V
Tx_Fault_Output_Low
VFL
V
Max. Pout TX-DISABLE Asserted
Electrical Characteristics
Receiver Specifications ( VCC=3.1V~3.5V;Tc= 0oC~70oC / Tc= -40oC~85oC )
Parameter
Symbol
Min
Typ
Max
Unit
PSATIN
dBm
PSEN
-18
dBm
Operating Center Wavelength
λc
770
860
nm
Loss of Signal – De-asserted
PLD
-18
dBm
Loss of Signal - Asserted
PLA
-35
dBm
Loss of Signal - Hysteresis
PLH
0.5
6
dB
Differential Output Voltage
VDIFF
0.4
2.0
V
Receiver Loss of Signal Output Voltage -Low
VLOSL
V
Receiver Loss of Signal Output Voltage -High
VLOSH
2
VCC+0.3
V
Optical Input Power-maximum
7
Receiver Sensitivity ( PRBS=2 -1;BER≦10
-12
Version 02
Page
3
Pin Definition and Descriptions
Pin
Name
Input/Output
Level
1
VeeT
Input
2
TXFault
Output/LVTTL
3
TXDisable
Input/LVTTL
Description
Transmitter ground
Laser failure indication. High level indicates “laser failure”. Externally
pulled up
Transmitter disable, High signal/open disables TX laser output. Low
level enables TX output, internally pulled up.
Module definition 2, SDA, Data line for I2C bus. Externally pulled up
4
MOD-DEF(2) Input/output
5
MOD-DEF(1) Input
Module definition 1, SCL, Clock for I2C bus. Externally pulled up
6
MOD-DEF(0) Output
Module definition 0, Module present. Ground inside module.
7
Rate Select
No connection.
8
LOS
Output/LVTTL
Receiver loss of signal indication. Low signal indicates optical signal is
present at RX input. Should be Externally pulled up.
9
VeeR
Input
Receiver ground
10
VeeR
Input
Receiver ground
11
VeeR
Input
Receiver ground
12
RD -
Output/CML
Inverted receiver data output (AC coupled)
13
RD +
Output/CML
Non-inverted receiver data output (AC coupled)
14
VeeR
Input
Receiver ground
15
VccR
Input
Receiver power supply
16
VccT
Input
Transmitter power supply
17
VeeT
Input
Transmitter ground
18
TD +
Input/LVPECL
non-inverted transmitter data input (AC coupled)
19
TD -
Input/LVPECL
Inverted transmitter data input (AC coupled)
VeeT
Input
Transmitter ground
Version 02
Page
4
Recommended Circuit Diagram
Version 02
Page
5
Content in 2-Wire Address A0H
Address
00
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
HEX
03
04
07
00
00
00
01
0C
01
01
0D
00
00
00
37
1B
00
00
Name of Field
Identifier
Extended Identifier
Connector type
Infiniband Compliance Codes
SONET Compliance Codes
Ethernet Compliance Codes
Fiber Channel link length
Fiber Channel transmitter technology
Fiber Channel transmission media
Fiber Channel speed
Encoding codes:
Nominal Bit Rate (units of 100Mbps)
Rate identifier
Link length supported for 9um fiber
Link length supported for 50um,OM2
Link length supported for 62.5um,OM1
Link length supported for copper
Link length supported for 50um,OM3
20 ~ 35 46,4F,52,4D,45,52,49,43,
Vendor Name
41,4F,45,20,20,20,20,20
36
00
Unallocated
37 ~ 39 00,00,00
Vendor OUI
54,53,44,2D,53,31(32),43,48,
Part Number
40 ~ 55
31,2D,43,31,31,20,20,20
56 ~ 59 00,00,00,00
Vendor Revision number
60 ~ 61 03,52
Laser Wavelength
62
00
Unallocated
63
CC_BASE:
64
00
Options
65
1A
Options
66
00
Bit Rate, max.
67
00
Bit Rate, min.
68 ~ 83 Serial Number
Serial Number
84 ~ 89 yy/mm/dd
Date Code
90 ~ 91 20,20
Vendor specific lot code
92
68
Diagnostic Monitoring Type
93
B0
Enhanced Options (soft)
94
03
SFF-8472 Compliance
95
CC_EXT
96~127
Vendor specific
Description
SFP
SFP
LC
Not compliant
Not compliant
Not compliant
1000BASE-SX
Intermediate distance
Shortwave laser w/o OFC (SN)
Multimode M5/M6
100 MBytes/sec
8B/10B
1300Mbps
Unspecified
N/A (units of km)
N/A (units of 100m)
550m (units of 10m)
275m (units of 10m)
N/A (units of 1m)
N/A (units of 10m)
FORMERICAOE
Unspecified
TSD-S1(2)CH1-C11
Unspecified
850nm
Check sum of byte 0 ~ 62
TX-DIS, TX_FAULT, RX-LOS
Unspecified
Unspecified
Unspecified
Internal calibration
All flags, TX_FAULT, RX-LOS
Rev10.2
Check sum of byte 64 ~ 94
Version 02
Page
6
Content in 2-Wire Address A2H
Add
Bytes
Name
Hex
Real Value
00-01
02-03
04-05
06-07
08-09
10-11
12-13
14-15
16-17
18-19
20-21
22-23
24-25
26-27
28-29
30-31
32-33
34-35
36-37
38-39
40-55
56-59
60-63
64-67
68-71
72-75
76-77
78-79
80-81
82-83
84-85
86-87
88-89
90-91
92-94
95
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
16
4
4
4
4
4
2
2
2
2
2
2
2
2
3
1
Temp High Alarm*
Temp Low Alarm*
Temp High Warning*
Temp Low Warning*
Voltage High Alarm
Voltage Low Alarm
Voltage High Warning
Voltage Low Warning
Bias High Alarm
Bias Low Alarm
Bias High Warning
Bias Low Warning
TX Power High Alarm
TX Power Low Alarm
TX Power High Warning
TX Power Low Warning
RX Power High Alarm
RX Power Low Alarm
RX Power High Warning
RX Power Low Warning
Reserved
RX_PWR(4)
RX_PWR(3)
RX_PWR(2)
RX_PWR(1)
RX_PWR(0)
TX_I(Slope)
TX_I(Offset)
TX_PWR(Slope)
TX_PWR(Offset)
T(Slope)
T(Offset)
V(Slope)
V(Offset)
Reserved
Checksum
6400 (6400)
F600 (D800)
5F00 (5F00)
0000 (E200)
8CA0
7530
88B8
7918
2710
0000
2328
0000
1393
0630
0F8D
07CB
2710
007E
1F07
009E
00
00000000
00000000
00000000
3F800000
00000000
0100
0000
0100
0000
0100
0000
0100
0000
00
100℃ (100℃)
-10℃ (-40℃)
95℃ (95℃)
0℃ (-30℃)
3.6V
3.0V
3.5V
3.1V
20mA
0mA
18mA
0mA
-3dBm
-8dBm
-4dBm
-7dBm
0dBm
-19dBm
-1dBm
-18dBm
Note *: ( ) for TSD-S2CH1-C11.
Version 02
Page
7
Mechanical Outlines
( Unit : mm)
Version 02
Page
8
