10GbE SFP+ LRM Transceiver
PRODUCT NUMBER: TAS-A1NA1-111
Specification
Small Form Factor Pluggable
Duplex LC Receptacle – SFP+
Optical Transceivers
10 Gigabit Ethernet
10GBASE-LRM
Ordering Information
TAS–A1NA1–111
Model Name Voltage Category
TAS-A1NA1-111
3.3V
With DDMI
Device type
1310 nm FP
Formerica OptoElectronics Inc .
5F-11, No.38, Taiyuan St.,Zhubei City,
Hsinchu County 30265, Taiwan
Ph: +886-3-5600286 Fax: +886-3-5600239
Interface
AC / AC
Coupling
LOS Temperature
LVTTL
0C~+70C
Distance
220m
Latch Color
Coffee
(MM OM1 Fiber)
Version 04
1
Features
10Gb/s serial optical interface compliant to IEEE802.3aq 10GBASE-LRM
Electrical interface compliant to SFF-8431 specifications for enhanced 8.5 and 10
Gigabit small form factor pluggable module “SFP+”
1310nm FP transmitter, PIN photo-detector, Linear receiver module
2-wire interface for management specifications compliant with SFF 8472 digital
diagnostic monitoring interface for optical transceivers
Operating case temperature: 0 to 70 °C
All-metal housing for superior EMI performance
Low power consumption
Advanced firmware allow customer system encryption information to be stored in
transceiver
Cost effective SFP+ solution, enables higher port densities and greater bandwidth
RoHS Compliant
Applications
High-speed storage area networks
Computer cluster cross-connect
Custom high-speed data pipes
220 legacy OM1 MMF transmission
Version 04
2
General Description
This 1310 nm FP 10Gigabit SFP+ transceiver is designed to transmit and receive
optical data over legacy OM1 multimode fiber up to 220m link.
The SFP+ LRM module electrical interface is compliant to SFI electrical
specifications. The transmitter input and receiver output impedance is 100 Ohms
differential. Data lines are internally AC coupled. The module provides differential
termination and reduce differential to common mode conversion for quality signal
termination and low EMI. SFI typically operates over 200 mm of improved FR4
material or up to about 150mm of standard FR4 with one connector.
The transmitter converts 10Gbit/s serial PECL or CML electrical data into serial
optical data compliant with the 10GBASE-LRM standard. An open collector
compatible Transmit Disable (Tx_Dis) is provided. A logic “1,” or no connection
on this pin will disable the laser from transmitting. A logic “0” on this pin provides
normal operation. The transmitter has an internal automatic power control loop
(APC) to ensure constant optical power output across supply voltage and
temperature variations. An open collector compatible Transmit Fault (Tx_Fault) is
provided. TX_Fault is a module output contact that when high, indicates that the
module transmitter has detected a fault condition related to laser operation or
safety. The TX_Fault output contact is an open drain/collector and shall be pulled
up to the Vcc_Host in the host with a resistor in the range 4.7-10 kΩ.
TX_Disable is a module input contact. When TX_Disable is asserted high or left
open, the SFP+ module transmitter output shall be turned off. This contact shall
be pulled up to VccT with a 4.7 kΩ to 10 kΩ resistor.
The receiver converts 10Gbit/s serial optical data into serial PECL/CML electrical
data. An open collector compatible Loss of Signal is provided. Rx_LOS when
high indicates an optical signal level below that specified in the relevant standard.
The Rx_LOS contact is an open drain/collector output and shall be pulled up to
Vcc_Host in the host with a resistor in the range 4.7-10 kΩ, or with an active
termination. Power supply filtering is recommended for both the transmitter and
receiver. The Rx_LOS signal is intended as a preliminary indication to the system
in which the SFP+ is installed that the received signal strength is below the
specified range. Such an indication typically points to non-installed cables,
broken cables, or a disabled, failing or a powered off transmitter at the far end of
the cable.
Version 04
3
Transceiver Block Diagram
Version 04
4
Proposed Applications Schematics
Version 04
5
Pin Definition and Descriptions
The SFP+ modules are hot-pluggable. Hot pluggable refers to plugging in or
unplugging a module while the host board is powered. The SFP+ host connector
is a 0.8 mm pitch 20 position right angle improved connector specified by SFF8083, or stacked connector with equivalent with equivalent electrical performance.
Host PCB contact assignment is shown in below Figure and contact definitions
are given in the Pin description table. SFP+ module contacts mates with the host
in the order of ground, power, followed by signal as illustrated by below Figure
and the contact sequence order listed in the Pin description below table.
Version 04
6
PIN
Logic
1
Symbol
VeeT
Name / Description
Module Transmitter Ground
Note
1
2
LVTTL-O
TX_Fault
3
LVTTL-I
TX_Dis
4
LVTTL-I/O
SDA
2-Wire Serial Interface Data Line
2
5
LVTTL-I
SCL
2-Wire Serial Interface Clock
2
6
MOD_DEF0
Module Transmitter Fault
Transmitter Disable; Turns off transmitter laser
output
Module Definition, Grounded in the module
7
LVTTL-I
RS0
Receiver Rate Select
8
LVTTL-O
RX_LOS
9
LVTTL-I
RS1
Transmitter Rate Select
10
VeeR
Module Receiver Ground
1
11
VeeR
1
Receiver Loss of Signal Indication Active High
12
CML-O
RD-
Receiver Inverted Data Output
13
CML-O
RD+
Receiver Data Output
14
VeeR
15
VccR
Module Receiver 3.3 V Supply
16
VccT
Module Transmitter 3.3 V Supply
17
VeeT
18
CML-I
TD+
Transmitter Non-Inverted Data Input
19
CML-I
TD-
Transmitter Inverted Data Input
VeeT
1
1
1
Note:
1. Module ground pins GND are isolated from the module case.
2. Shall be pulled up with 4.7K-10Kohms to a voltage between 3.15V and 3.45V on the
host board.
Version 04
7
Absolute Maximum Ratings
These values represent the damage threshold of the module. Stress in excess of
any of the individual Absolute Maximum Ratings can cause immediate
catastrophic damage to the module even if all other parameters are within
Recommended Operating Conditions.
Parameters
Symbol
Min.
Max.
Unit
Power Supply Voltage
VCC
V
Storage Temperature
Ts
-40
85
C
Operating Case temperature
Tc
C
Relative Humidity
RH
5
95
Pmax
1
dBm
RX Input Average Power
Recommended Operating Environment
Recommended Operating Environment specifies parameters for which the
electrical and optical characteristics hold unless otherwise noted.
Parameters
Symbol
Min.
Typical
Max.
Unit
VCC
3.135
3.3
3.465
V
Power Supply Current
Icc
300
mA
TC
70
C
Version 04
8
Optical Characteristics
The following optical characteristics are defined over the Recommended
Operating Environment unless otherwise specified.
Parameter
Symbol
Min.
Typ.
Operating Reach, OM1 MMF
Max
Unit
220
m
1355
nm
4.0
nm
Notes
Transmitter
Center Wavelength
λt
RMS spectral width
Pm
1260
1310
Average Optical Power
Pavg
-6.5
0.5
dBm
Optical Modulation Amplitude (OMA)
Poma
-4.5
1.5
dBm
Transmitter and dispersion penalty (max)
TDP
4.7
dB
Average launch power of Off transmitter
Poff
-30
dBm
Extinction Ratio
ER
RIN12 OMA (max)
Rin
Optical Return Loss Tolerance (min)
3.5
Pf = -2.0
dBm
Note1
Note2
dB
-128
dB/Hz
dB
Receiver
Center Wavelength
λr
Receiver overload (max) in OMA
Stressed Receiver Sensitivity (OMA)
1260
1.5
Psens
Receiver Reflectance (max)
Stressed Receiver Sensitivity in OMA
(Symetrical)
Psens
Los Assert
LosA
Los Dessert
LosD
Los Hysteresis
LosH
0.5
Pin
1.5
Receiver power (damage, Max)
1355
nm
dBm
-6.5
dBm
-12
dBm
-6
dBm
-30
Note3
Note3
dBm
-12
dBm
6
dB
dBm
Note:
1. Average optical power shall be measured using the methods specified in TIA/EIA-455-95.
2. Path penalty is intended as the power penalty of the interface between back-to-back and the
maximum applied dispersion.
3. Receiver sensitivity is informative. Stressed receiver sensitivity shall be measured with
conformance test signal for BER =1x 10-12 .
Version 04
9
Digital Diagnostic Functions
The following digital diagnostic characteristics are defined over the
Recommended Operating Environment unless otherwise specified. It is compliant
to SFF8472 Rev10.2 with internal calibration mode. For external calibration mode
please contact our sales stuff.
Parameter
Symbol
Min.
Max
Unit
Notes
Temperature monitor
absolute error
DMI_Temp
-3
3
degC
Over operating
temp
Laser power monitor
absolute error
DMI_TX
-3
3
dB
RX power monitor absolute
error
DMI_RX
-3
3
dB
-1dBm to 14dBm range
Supply voltage monitor
absolute error
DMI_VCC
-0.1
0.1
V
Full operating
range
Bias current monitor
DMI_Ibias
-10%
10%
mA
Version 04
10
Electrical Characteristics
The following electrical characteristics are defined over the Recommended
Parameter
Symbol
Min.
Data Rate
Typ.
Max
10.3125
Power Consumption
800
Unit
Notes
Gbps
1000
mW
4
V
Transmitter
Single Ended Output Voltage
Tolerance
-0.3
C common mode voltage
tolerance
Tx Input Diff Voltage
Tx Fault
Data Dependent Input Jitter
Data Input Total Jitter
15
mV
VI
180
700
VOL
-0.3
0.4
VOH
2
Vcc
mV
V
DDJ
0.1
UI
TJ
0.28
UI
-0.3
4
V
Vo
180
600
mV
Tr/Tf
30
At 0.7mA
Receiver
Tolerance
Rx Output Diff Voltage
Rx Output Rise and Fall Time
ps
Total Jitter
TJ
0.7
UI
Deterministic Jitter
DJ
0.42
UI
20% to
80%
Version 04
11
Control and Status I/O Timing Characteristics
Timing characteristics of control and status I/O are included in Table 9, which is
also defined in SFF-8431.
Version 04
12
Content in 2-Wire Address A0H
Address
00
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
20 ~ 35
36
37 ~ 39
40 ~ 55
56 ~ 59
60 ~ 61
62
63
64
65
66
67
68 ~ 83
84 ~ 89
90 ~ 91
92
93
HEX
Name of Field
Identifier
Extended Identifier
Connector type
10G Ethernet Compliance Codes
SONET Compliance Codes
Fiber Channel link length
Fiber Channel transmitter technology
Fiber Channel transmission media
Fiber Channel speed
Encoding codes:
Nominal Bit Rate (units of 100Mbps)
Rate identifier
Link length supported for 9um fiber
Link length supported for 50um,OM2
Link length supported for 62.5um,OM1
Link length supported for copper
Link length supported for 50um,OM3
Description
SFP
SFP
LC
10G Base-LRM
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
64B/66B
10.3Gbps
Unspecified
N/A (units of km)
N/A (units of 100m)
220m (units of 10m)
220m (units of 10m)
N/A (units of 1m)
N/A (units of 10m)
Vendor Name
FORMERICAOE
Unallocated
Vendor IEEE company ID
Unspecified
Part Number
TAS-A1NA1-111
Unspecified
1310nm
00
1A
00
00
Serial Number
yy/mm/dd
20,20
68
Vendor Revision number
Laser Wavelength
Unallocated
CC_BASE:
Options
Options
Bit Rate, max.
Bit Rate, min.
Serial Number
Date Code
Vendor specific lot code
Diagnostic Monitoring Type
F0
Enhanced Options (soft)
03
04
07
40
00
00
00
00
00
00
00
06
67
00
00
00
16
16
00
00
46,4F,52,4D,45,52,49,43,
41,4F,45,20,20,20,20,20
00
00,00,00
54,41,53,2D,41,31,4E,41,
31,2D,31,31,31,20,20,20
00,00,00,00
05,1E
00
94
03
95
96~127
SFF-8472 Compliance
CC_EXT
Vendor specific
Check sum of byte 0 ~ 62
Not compliant
TX-DIS, TX_FAULT, RX-LOS
Unspecified
Unspecified
Unspecified
Internal calibration
Alarm/Warning flags, Soft
TxDisable, Soft TxFault,
Soft RxLOS implemented
Rev10.2
Check sum of byte 64 ~ 94
Version 04
13
Content in 2-Wire Address A2H
Add
Bytes
Name
Hex
Real Value
00-01
02-03
04-05
06-07
08-09
10-11
12-13
14-15
16-17
18-19
20-21
22-23
24-25
26-27
28-29
30-31
32-33
34-35
36-37
38-39
40-55
56-59
60-63
64-67
68-71
72-75
76-77
78-79
80-81
82-83
84-85
86-87
88-89
90-91
92-94
95
2
2
2
2
2
2
2
2
2
2
A
2
2
2
2
2
2
2
2
2
16
4
4
4
4
4
2
2
2
2
2
2
2
2
3
1
Temp High Alarm
Temp Low Alarm
Temp High Warning
Temp Low Warning
Voltage High Alarm
Voltage Low Alarm
Voltage High Warning
Voltage Low Warning
Bias High Alarm
Bias Low Alarm
Bias High Warning
Bias Low Warning
TX Power High Alarm
TX Power Low Alarm
TX Power High Warning
TX Power Low Warning
RX Power High Alarm
RX Power Low Alarm
RX Power High Warning
RX Power Low Warning
Reserved
RX_PWR(4)
RX_PWR(3)
RX_PWR(2)
RX_PWR(1)
RX_PWR(0)
TX_I(Slope)
TX_I(Offset)
TX_PWR(Slope)
TX_PWR(Offset)
T(Slope)
T(Offset)
V(Slope)
V(Offset)
Reserved
Checksum
5F00
E700
5A00
EC00
9470
6D60
9088
7148
AFC8
03E8
9C40
05DC
3E1C
0640
3138
07D0
3138
0064
2710
007E
FF
00000000
00000000
00000000
3F800000
00000000
0100
0000
0100
0000
0100
0000
0100
0000
00
95℃
-25℃
90℃
-20℃
3.8V
2.8V
3.7V
2.9V
90mA
2mA
80mA
3mA
2dBm
-8dBm
1dBm
-7dBm
1dBm
-20dBm
0dBm
-19dBm
Version 04
14
Mechanical
Comply to SFF-8432 rev. 5.0, the improved Pluggable form factor specification.
ESD
This transceiver is specified as ESD threshold 1kV for all electrical input pins,
tested per MIL-STD-883, Method 3015.4 /JESD22-A114-A (HBM). However,
normal ESD precautions are still required during the handling of this module. This
transceiver is shipped in ESD protective packaging. It should be removed from
the packaging and handled only in an ESD protected environment.
LASER Safety
This is a Class 1 Laser Product according to IEC 608251:1993:+A1:1997+A2:2001. This product complies with 21 CFR 1040.10 and
1040.11 except for deviations pursuant to Laser Notice No. 50, dated (July 24,
2007)
Version 04
15
