PHOTONIC
Silicon Photodiode, Blue Enhanced Photoconductive
DETECTORS INC. Type PDB-C138 , with daylight filter Type PDB-C138F
PACKAGE DIMENSIONS INCH [mm]
0.220 [5.60]
Ø0.197 [5.00]
0.020 [0.51] SQ
2 PLACES
ACTIVE
AREA
SURFACE
1.043 [26.5]
0.059 [1.50] MAX
C
L
0.100 [2.54]
C
L
40°
VIEWING
ANGLE
CATHODE
ANODE
0.984 [25.0]
CLEAR PLASTIC (PDB-C138)
BLACK PLASTIC (PDB-C138F)
0.177 [4.50]
CHIP POSITION
0.038 [0.97]
0.342 [8.70]
0.070 [1.78]
0.059 [1.50] SQ
ACTIVE AREA
T 1 3/4 PLASTIC PACKAGE
ACTIVE AREA = 1.55 mm2
DESCRIPTION: The PDB-C138 detector is
a 1.55 mm2 planar pin photodiode packaged
in a T 1 3/4, water clear plastic housing.
Designed for high speed, low capacitance,
photoconductive applications. The
PDB-C138F includes a daylight filter.
-40
+80
O
TS
Soldering Temperature*
+260
O
IL
Light Current
C
C
mA
0 .3
0 .2
0 .1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 10 V
RSH
Shunt Resistance
H = 0, VR = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
λrange
MAX
UNITS
mA
80
90
.5
2
GΩ
H = 0, VR = 10 mV
-8
% / oC
H = 0, VR = 10 V*
6
Spectral Application Range (without daylight filter)**
λp
Spectral Response - Peak
VBR
Breakdown Voltage
I = 10 mA
N EP
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 50 V
tr
1 20 0
Operating Temperature Range
0 .4
1 10 0
TO
C
9 00
O
1 00 0
+100
8 00
-40
00
=1
QE
0 .5
7 00
Storage Temperature
0 .6
6 00
TSTG
0.5
V
5 00
100
4 00
Reverse Voltage
3 00
VBR
SPECTRAL RESPONSE
0 .7
1 90
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Smoke detectors
Light dimmers
TV & VCR remotes
RESPONSIVITY (A/W)
FEATURES
Large active area
High speed
Low cost
2
400
10
1100
950
50
30
nA
pF
nm
nm
100
1.8x10-13
10
V
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. *f = 1 MHz, ** daylight filter= 700 - 1100 nm
[FORM NO. 100-PDB-C138 REV A]
很抱歉,暂时无法提供与“PDB-C138F”相匹配的价格&库存,您可以联系我们找货
