PHOTONIC
Silicon Photodiode, Filter Combination Photovoltaic
(center wavelength 550 nm) Type PDG-V455
DETECTORS INC.
EPOXY COVERING
EYELET
PACKAGE DIMENSIONS INCH [mm]
WIRE
BONDS
EPOXY MARKING INK (WAVE LENGTH NO.)
ACTIVE AREA SURFACE
+- 0.005 [0.13]
0.080 [2.03]
0.200 [5.08] DIA
PIN CIRCLE
0.365 [9.27]
0.355 [9.02] DIA
0.345 [8.76]
0.335 [8.51]
0.245 [6.22]
0.235 [5.97] DIA
0.500 [12.70]
CHIP
0.330 [8.38]
0.320 [8.13] DIA
45°
0.020 [0.51] DIA
2 PLACES
0.035 [0.89]
0.030 [0.76]
FILTER CAP
SUBASSEMBLY
ANODE
CATHODE
(CASE GROUND)
HEADER
0.425 [10.80]
0.415 [10.54]
ACTIVE AREA
0.223 [5.66]
0.123 [3.12]
0.135 [3.43]
ACTIVE AREA
TO-5 CAN PACKAGE
0.235 [5.97]
ACTIVE AREA = 17.74 mm2
FEATURES
High transmission
10-4 rejection
+/- 2nm CWL
DESCRIPTION
The PDG-V455 is a silicon, PIN planar
diffused, photodiode with a narrow band
interferance filter. The detector filter combination has a narrow 10 nm half bandwidth
designed for low noise photovoltaic applications. Packaged in a TO-5 metal can.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
C
+240
O
C
TS
Soldering Temperature*
IL
Light Current
0.5
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
FWHM = 10 nm
@ 50% Tx MIN
1200
O
1100
+70
900
-15
1000
C
Operating Temperature Range
0%
10
800
O
700
+85
QE
0.4
600
-20
0.5
500
Storage Temperature
0.6
400
V
SPECTRAL RESPONSE
0.7
300
TO
100
Liquid chromatography
190
TSTG
Reverse Voltage
Chemistry instrumentation
RESPONSIVITY (A/W)
V BR
APPLICATIONS
Spectrophotometry
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
O
ISC
Short Circuit Current***
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 mV
150
MAX
mA
200
10
UNITS
50
pA
Shunt Resistance
H = 0, V R = 10 mV
2
GΩ
TC RSH
RSH Temp. Coefficient
H = 0, V R = 10 mV
-8
% / oC
CJ
RSH
.20
Junction Capacitance
H = 0, V R = 10 V**
1700
pF
CWL
Center Wavelength
(CWL, lo) +/- 2 nm
550
nm
HBW
Half Bandwidth
(FWHM)
10
nm
V BR
Breakdown Voltage
I = 10 m A
N EP
tr
50
75
Noise Equivalent Power
V R = 10 mV @ Peak
9x10
Response Time
RL = 1 KΩ V R = 10 V
1.0
V
-15
W/
Hz
µS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.**f = 1 MHz, ***without filter
[FORM NO. 100-PDG-V455 REV A]
很抱歉,暂时无法提供与“PDG-V455”相匹配的价格&库存,您可以联系我们找货
