IMM43122C
IMM43122C
    CROUZET(高诺斯)
    IPD M12 SHLD 2W DC SPST 2M
IMM43122C 数据手册
Inductive Proximity Sensors M12 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM32122C IMM35124C IMN32122C IMN35124C IMN32122M12 PNP – Normally Closed (1) IMM33122C IMM36124C IMN33122C IMN36124C IMN33122M12 PNP – Selectable (4) IMM34122C IMM37124C IMN34122C IMN37124C IMN34122M12 NPN – Normally Open (2) IMM22122C IMM25124C IMN22122C IMN25124C IMN22122M12 NPN – Normally Closed (2) IMM23122C IMM26124C IMN23122C IMN26124C IMN23122M12 NPN – Selectable (5) IMM24122C IMM27124C IMN24122C IMN27124C IMN24122M12 - - - - - M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded 2mm 4mm 2mm 4mm 2mm 2.0 Meter Cable M12 Connector 1kHz 1.5kHz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 1.5kHz 1kHz 1.5kHz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN35124M12 IMN32122P IMN35124P IMC32122C IMC35124C IMC32122M12 IMC35124M12 PNP – NC IMN36124M12 IMN33122P IMN36124P IMC33122C IMC36124C IMC33122M12 IMC36124M12 PNP – NO/NC IMN37124M12 IMN34122P IMN37124P IMC34122C IMC36124C IMC34122M12 IMC37124M12 NPN – NO IMN25124M12 IMN22122P IMN25124P IMC22122C IMC25124C IMC22122M12 IMC25124M12 NPN – NC IMN26124M12 IMN23122P IMN26124P IMC23122C IMC26124C IMC23122M12 IMC26124M12 NPN – NO/NC IMN27124M12 IMN24122P IMN27124P IMC24122C IMC26124C IMC24122M12 IMC27124M12 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded 2mm 4mm 2mm 4mm 2mm 4mm 2.0 Meter Cable M12 Connector M12 Connector 1kHz 1.5kHz 1kHz Mates Form M12 Non-Shielded Sn 4mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 1kHz 1.5kHz 1kHz 1.5kHz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M12 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM32124C IMM35128C IMN32124C IMN35128C IMN32124M12 PNP – Normally Closed (1) IMM33124C IMM36128C IMN33124C IMN36128C IMN33124M12 PNP – Selectable (4) - - - - - NPN – Normally Open (2) IMM22124C IMM25128C IMN22124C IMN25128C IMN22124M12 NPN – Normally Closed (2) IMM23124C IMM26128C IMN23124C IMN26128C IMN23124M12 NPN – Selectable (5) - - - - - - - - - - M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded 4mm 8mm 4mm 8mm 4mm 2.0 Meter Cable M12 Connector 1kHz 1kHz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 1kHz 1kHz 1kHz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN35128M12 IMN32124P IMN35128P IMC32124C IMC35128C IMC32124M12 IMC35128M12 PNP – NC IMN36128M12 IMN33124P IMN36128P IMC33124C IMC36128C IMC33124M12 IMC36128M12 - - - - - - - NPN – NO IMN25128M12 IMN22124P IMN25128P IMC22124C IMC25128C IMC22124M12 IMC25128M12 NPN – NC PNP – NO/NC IMN26128M12 IMN23124P IMN26128P IMC23124C IMC26128C IMC23124M12 IMC26128M12 NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded 4mm 8mm 4mm 8mm 4mm 8mm 2.0 Meter Cable M12 Connector M12 Connector 1kHz 1kHz 1kHz Mates Form M12 Non-Shielded Sn 8mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 1kHz 1kHz 1kHz 1kHz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M12 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC 2 Wire AC PNP – Normally Open (1) - - - - - PNP – Normally Closed (1) - - - - - PNP – Selectable (4) - - - - - NPN – Normally Open (2) - - - - - NPN – Normally Closed (2) - - - - - NPN – Selectable (5) - - - - - (6) IMM42122C IMM45124C IMN42122M12 IMN45124M12 - Normally Closed (6) IMM43122C IMM46124C IMN43122M12 IMN46124M12 - Normally Open (7) - - - - IMM62122C Normally Closed (7) - - - - IMM63122C M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded 2mm 4mm 2mm 4mm 2mm M12 Connector 2.0 Meter Cable Normally Open Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage Max. Load Current (Ir) M12 Connector 10 to 30Vdc 20 to 220 Vac 100mA 400 mA Max ripple factor (Vr) ≤ 10% - Voltage Drop (Ud) ≤ 7 Vdc ≤ 4.5Vac Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis ≤ 0.7mA 1kHz 800 Hz 1kHz ≤ 2.5mA 800 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Circuit Protection Yes No Output LED Yes Yes Operating Temperature IP Rating -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO - - - - - - - PNP – NC - - - - - - - PNP – NO/NC - - - - - - - NPN – NO - - - - - - - - - - - - NPN – NC NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO IMM65124C IMN62122C IMN65124C IMN62122M12 IMN65124M12 IMN62122P IMN65124P 2W AC NC IMM66124C IMN63122C IMN66124C IMN63122M12 IMN66124M12 IMN63122P IMN66124P M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded M12 Shielded M12 Non-Shielded 2mm 4mm 2mm 4mm 2mm 4mm M12 Connector Sub-Base Plug Sub-Base Plug 20 Hz 20 Hz 20 Hz Mates Form M12 Non-Shielded Sn 4mm Nickel Plated Brass Housing Termination 2.0 Meter Cable 2.0 Meter Cable 2.0 Meter Cable 400mA Max Load - Max ripple ≤ 4.5Vac Ud ≤ 2.5mA Io Hz Repeatability Hysteresis M12 Connector 20 to 220Vac Supply Vdc 20 Hz 20 Hz 20 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Protection No LED Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
IMM43122C 价格&库存
很抱歉,暂时无法提供与“IMM43122C”相匹配的价格&库存,您可以联系我们找货
