DGS-SO2 968-038
March 2017
Digital Gas Sensor – Sulfur Dioxide
BENEFITS
SULFUR DIOXIDE APPLICATIONS
• Air Purification Control
• Air Quality Monitoring
• Industrial Safety Sensing
Low Power – 1 mW @ 1 minute sampling
Calibrated & Temp. Compensated Output
Fast Response < 30 seconds
Simple Digital UART Interface
Integrated T & RH Sensors
Robust 10-year Estimated Lifetime
ROHS Compliant
Small form Factor
UART to USB adapter provided
Lightweight (< 2 oz.)
DESCRIPTION
SPEC Sensors now offers an easy way to add gas sensing to the Internet of Things. Combining our Screen
Printed ElectroChemical sensor technology (SPEC Sensor™) with state-of-the-art electronics and
algorithms, enables easy integration of small, lightweight, high performance, ultra-low power consumption
gas sensing into wireless, portable, and networked solutions.
MEASUREMENT PERFORMANCE CHARACTERISTICS
Based on Standard Conditions 25 ºC, 50% RH and 1 atm
Measurement Range
0 to 20 ppm
Resolution
50 ppb (1)
Measurement Accuracy
15% of reading
Measurement Repeatability (2)
< ± 3% of reading
T90 Response Time (100 ppm step)
Expected Operating Life
< 30 seconds
1 mW for 1 minute triggered samples
12 mW for continuous sampling 5, 10 30, 60 second intervals
> 5 years (10 years @ 25± 10C; 60 ± 30% RH)
Operating Temperature Range
-20 to 40 °C (-30 to 55 °C intermittent)
Operating Humidity Range
15 to 95% (0 to 100% non-condensing intermittent)
Mechanical Dimensions
1.75 x 0.82 x 0.35 in. (44.5 x 20.8 x 8.9 mm)
Weight
< 2 Ounces
Power Consumption
NOTES:
1)
2)
3)
4)
Based on Standard Deviation of noise at zero, 1 Hz measurement 60 second averaging.
When zeroed after 60 minutes of power-on stabilization
Based on consecutive measurements of 100 ppm
Contact factory for custom calibration for improved measurement performance
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the SPEC
Sensors standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2011-2017, SPEC Sensors LLC
DGS-SO2 968-038
March 2017
ABSOLUTE MAXIMUM RATINGS
Parameter
Maximum Concentration
Supply Voltage
Storage Temperature
Storage Humidity
Storage Pressure
Storage Time
Operating Humidity
Operating Pressure
Operating Humidity
Operating Pressure
ESD Rating
Conditions
Short term exposure
Regulated
Vapor sealed @ 50% RH
Non-condensing, vapor sealed
Vapor sealed
Vapor sealed
< 10 hours
< 10 hours, Non-Condensing
Transient pulses
Continuous
Continuous, Non-Condensing
Continuous
Human Body Model
Min.
Rec.
5
-40
-30
10
0.8
2
1000
1
12
50
1
Max.
5000
3.6
30
80
1.2
50
100
.5
50
95
1.2
8
Units
ppm
V
̊C
% RH
atm
Months
̊C
% RH
atm
̊C
% RH
atm
kV
ELECTRICAL CHARACTERISTICS
Parameter
Supply Current
Power Consumption
Conditions
Min.
V+ = 3.0 V
V+ = 3.0 V
0.05
0.15
Typ.
Max.
4
12
Units
mA
mW
CROSS SENSITIVITY
The following table lists the relative response of common potential interfering gases, and the
concentration at which the data was gathered.
Gas/Vapor
Sulfur Dioxide
Hydrogen Sulfide
Nitric Oxide
Carbon Monoxide
Ozone
Chlorine
Nitrogen Dioxide
n-Heptane
Methane
Ammonia
Applied Concentration
(ppm)
50
400
5
10
10 ppm
500
500
100 ppm
Typical Response
ppm SO2
90.5
7.3
-3.3
-2.8
1.4
-0.7
0.7
40C) for more than 1 month
Low Humidity Operation (< 15% RH) for more than 3 months
Highly contaminated air over a prolonged period
High levels of particles or soot (unless proper filtering is provided)[2]
(1) Use of porous PTFE membrane or filter cap may address this concern)
(2) Use of replaceable filter recommended where dust and particulate is expected.
DGS-SO2 968-038
March 2017
SENSOR STORAGE, HANDLING AND SOLDERING
This information embodies various general recommendations concerning the storage, handling, and manual soldering
conditions for SPEC SENSORS CSPEC Modules. It is only applicable for modules guaranteed by SPEC SENSORS
stated in SPEC SENSORS Sensor Specification Sheet. Moreover, SPEC SENSORS' modules are NOT warranted
and should NOT be used in high temperature soldering (reflow) or pre-tinning baths.
Sensor & Module Handling
Handle sensors with care. Take precautions, including but not limited to the following:
A. DO NOT apply excessive pressure to the top or bottom of the sensor module.
B. Whenever possible, handle or make contact with the sensor module from the sides of the PCB or substrate.
C. Light vacuum pressure is possible during handling, DO NOT apply vacuum over gas sensor port.
D. If the sealed sensor package is opened, DO NOT re-seal using vacuum or nitrogen gas. DO NOT reseal with
desiccant.
E. DO NOT obstruct the gas sensor port by making direct contact with any tape, apparatus, weights, etc.
F. DO NOT use silicone or other conformal coatings around the sensor or gas port-holes.
G. Operators are requested to wear powder free antistatic gloves.
Manufacturing Assembly Floor Environment
SPEC SENSORS recommends that the manufacturing assembly floor environment be maintained at controlled
conditions:
A. Temperature: 18 - 26°C
B. Relative Humidity: 40 to 60%
C. Pressure: 1.0 ± 0.2 atm
Sensor & Module Storage Conditions
The shelf life for sealed, packaged components is 12 months from the pack seal date, when stored in the factorysealed bag under the following conditions:
A. Temperature: 5 to 25 °C
B. Relative Humidity: 20 to 80%
D. Storage Time: 12 months
When moving from Storage Conditions to the Manufacturing Assembly Floor Environment, the sensors should be
allowed to equilibrate at the new conditions for at least 24 hours prior to manufacturing.
Module Attach Soldering Process
Hand solder only. Keep the soldering iron or solder process tool away from the sensor. The sensor should not see
pre-heat temperatures above 70 °C. There have been suggested cases where a heat sink cover over the sensor may
be applicable to protect the sensor during processing. No Application notes to this approach available. Only to be
used as reference only.
A. DO NOT heat sensor above 70 °C
B. Hand or peripheral process type approach
C. Use solder wire alloy with the lowest possible eutectic temperature
D. Use lowest possible soldering iron temperature
E. Contact the host board with the soldering iron at a 45° angle on the solder pad
F. Keep the soldering iron away from the top and bottom of the sensor module
G. DO NOT place in reflow, wave or IR reflow type processes
H. DO NOT place mounted board In a wash
很抱歉,暂时无法提供与“968-038”相匹配的价格&库存,您可以联系我们找货
