W83772G
W83772G
    NUVOTON(新唐)
    TSSOP8
    SENSOR TEMPERATURE SST 8TSSOP
W83772G 数据手册
W83772G Nuvoton H/W Monitoring IC Date: 07/01/2008 Revision: 1.3 W83772G W83772G Data Sheet Revision History PAGES DATES VERSION VERSION ON WEB n.a. 07/26/05 0.1 NA 2 08/10/05 0.2 For Nuvoton internal use only 3 08/25/05 0.31 For Nuvoton internal use only 4 10/31/05 0.32 1. Change part number W83L772G to W83772G. 1 MAIN CONTENTS For Nuvoton internal use only from 2. Modify the top marking 5 03/01/06 0.5 Preliminary datasheet. 1. Update Chap 3. 2. Update Chap7.6 and Chap 7.7 description. 3. Add Chap 7.3 6 04/27/06 4. Add Chap 8: PCB Layout Guide 1.0 5. Update Chap 9 6. Update Chap 10.2: DC Characteristic Table for SST, ADDx and D+ pin 7. Add Chap 11: Order Information 7 8 9 07/20/06 10/05/06 07/01/08 1.1 1.2 1. Add Chap 9.1~9.5 “format of command”. 2. Modify Chap Characteristics 3. Modify the description 1. Fix typo and format. 2. Update top marking diagram from 772W to 772G 1. Change from Nuvoton 2. Fix typo 1.3 -I- 10.3 Top AC Marking Winbond to Publication Release Date: July, 2008 Version: 1.3 W83772G Table of Content1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 1 2.1 Monitoring Items - Temperature .................................................................................................1 2.2 General ........................................................................................................................................1 2.3 Package .......................................................................................................................................1 3. KEY SPECIFICATIONS .............................................................................................................. 1 4. BLOCK DIAGRAM ...................................................................................................................... 2 5. PIN CONFIGURATION ............................................................................................................... 2 6. PIN DESCRIPTION ..................................................................................................................... 3 7. FUNCTIONAL DESCRIPTION.................................................................................................... 3 7.1 General Description ....................................................................................................................3 7.2 Access Interface ..........................................................................................................................3 7.3 Power-On Reset ..........................................................................................................................4 7.4 Measured Temperature Data Format ........................................................................................4 7.5 Sensor Error Conditions..............................................................................................................5 7.6 Conversion Time .........................................................................................................................5 7.7 Address Selection .......................................................................................................................5 8. PCB LAYOUT GUIDE ................................................................................................................. 6 9. COMMAND SUMMARY .............................................................................................................. 7 10. 9.1 Format of PING() .........................................................................................................................7 9.2 Format of ResetDevice().............................................................................................................8 9.3 Format of GetIntTemp() ..............................................................................................................8 9.4 Format of GetExtTemp() .............................................................................................................9 9.5 Format of GetAllTemp() ........................................................................................................... 10 ELECTRICAL CHARACTERISTIC ........................................................................................... 11 10.1 Absolute Maximum Ratings ..................................................................................................... 11 10.2 DC Characteristics ................................................................................................................... 11 10.3 AC Characteristics.................................................................................................................... 12 11. ORDER INSTRUCTION ............................................................................................................ 13 12. TOP MARKING SPECIFICATION ............................................................................................ 13 13. PACKAGE SPECIFICATION .................................................................................................... 14 - II - Publication Release Date: July, 2008 Version: 1.3 W83772G 1. GENERAL DESCRIPTION W83772G is a 2-channel temperature sensor with Simple Serial Transport (SST) interface. W83772G has an on-chip thermal sensor and a remote temperature sensor. The remote temperature sensor input could be connected to thermal diode or transistor such as 2N3904. A 10-bit ADC (Analog-toDigital Converter) is built inside W83772G to convert the monitored temperature value with 0.125C resolution. W83772G is a high precision, low-power consumption IC supporting 1.5V SST interface. The package type is 8-pin, MSOP (TSSOP), and the operating voltage is 3.3 V ±10%. 2. FEATURES 2.1 Monitoring Items - Temperature    2.2 General     2.3 Measure temperature with high accuracy One on-chip thermal sensor One remote temperature sensor 3.3V±10% VCC operation 16-bit two’s complement data format, 0.125C resolution Two address selection pins Support Simple Serial Transport interface Package  8-pin MSOP (TSSOP) 3. KEY SPECIFICATIONS       On-chip temperature range and accuracy 0C to 70C  3C (over entire range)  1C (40C to 70C) Remote temperature range and accuracy -30C to +127.875C  3C (over entire range)  1C (40C to 90C) Supply voltage 3.3V ±10% Operating supply current 5.6 mA typ. ADC resolution 10 Bits Operating Temperature Range 0C to 70C -1- Publication Release Date: July, 2008 Version: 1.3 W83772G 4. BLOCK DIAGRAM VCC xI Command Control SST Coder / Decoder Logic SST Local / Remote BANK Temperature SW Registers ADD0 D+ Sensor D- ADC Circuit Configuration Address Selector ADD1 Registers Status Registers Internal Thermal Diode 5. PIN CONFIGURATION VCC 1 GND 2 D+ 3 D- 4 W83772G 8 SST 7 ADD0 6 RES 5 ADD1 -2- Publication Release Date: July, 2008 Version: 1.3 W83772G 6. PIN DESCRIPTION PIN NAME NO PIN TYPE DESCRIPTION VCC 1 POWER GND 2 GROUND D+ 3 AIN Connect to Thermal Diode Anode D- 4 AIN Connect to Thermal Diode Cathode ADD1 5 IO RES 6 ADD0 7 IO For Address select SST 8 IO Simple Serial Transport (SST) Interface DC Power Supply Voltage Input 3.3V10%. Power Supply Ground For Address select Reserved 7. FUNCTIONAL DESCRIPTION 7.1 General Description The W83772G provides one remote temperature sensor input which could be connected to 2N3904 transistor, or CPU/GPU thermal diode, and one local on-chip thermal sensor to detect ambient temperature. The data format of monitored temperature is 16-bit 2’s complement. The system interface is the 1-wire SST access interface. 7.2 Access Interface The W83772G provides SST interface to read/write internal registers, and the SST address is xxxxxxxxb, respectively. Please refer to 7.7 Address Selection. -3- Publication Release Date: July, 2008 Version: 1.3 W83772G 7.3 Power-On Reset The power-on reset threshold is 2.7V (typical). When Vcc crosses this threshold, the internal reset signal will be asserted for 4mS. During this time period, W83772G is in the reset state. When the internal reset signal is de-asserted, W83772G is in the operating state. In the operating state, if Vcc drops below 2.4V and then rises above 2.7V, the internal reset signal will be asserted immediately. Figure 1 illustrates the reset mechanism. . 3.3V VCC 2.7V 2.4V 0V 3.3V 2.7V Internal Reset Signal 4ms 4ms Figure 1. 7.4 Measured Temperature Data Format The W83772G temperature data format of both remote and local temperature is 16-bit two’s complement format. Table 1 shows some representative temperature data with 16-bit two’s complement data format. TEMPERATURE 16-BIT DIGITAL OUTPUT +80°C 0001 0100 00 00 0000 +79.875°C 0001 0011 11 11 1000 +1°C 0000 0000 01 00 0000 +0°C 0000 0000 00 00 0000 -1°C 1111 1111 11 00 0000 - 5°C 1111 1110 11 00 0000 Integer Value Fractional Value Table 1. Temperature Data Format -4- Publication Release Date: July, 2008 Version: 1.3 W83772G 7.5 Sensor Error Conditions When the external diode is opened or shorted, the W83772G will return 0x8001 in response to either the SST command GetExtTemp() or GetAllTemp() command. It will also return 0x8002/0x8003 when detecting temperature below -128°C /above +128°C. 7.6 Conversion Time W83772G provides 250mS conversion time for monitoring all temperature readings. The conversion time is related to the internal self-generated clock. The internal clock frequency is dependent on the temperature. There is 10% frequency deviation in the operating temperature range of 0°C and 70°C. 7.7 Address Selection W83772G has two address pins. These pins may be either tied to Vcc, ground or left open. After the internal reset ends, pin ADD0/ADD1 will start to drive and sink current to detect the pin status – HIGH, LOW or FLOATING and then decide the SST address of W83772G. The address will be retained as long as the VCC of W83772G is maintained. The recommended pull-up or pull-down resistor value is 330Ω. (Please refer to the DC specification for the source and sink current.) The pull-up power plane must be the same as the VCC power of W83772G. VCC VCC R=330Ω VCC VCC ADDx GND ADDx GND W83772G W83772G R=330Ω VCC VCC ADDx NC(Floating) GND W83772G Figure 2. -5- Publication Release Date: July, 2008 Version: 1.3 W83772G The address mapping is shown in the following table. ADD0 ADD1 ADDRESS Ground Ground 0x48h Floating Ground 0x49h Vcc Ground 0x4ah Ground Floating 0x4bh Floating Floating 0x4ch Vcc Floating 0x4dh Ground Vcc 0x4eh Floating Vcc 0x4fh Vcc Vcc 0x50h 8. PCB LAYOUT GUIDE Pin 3 & Pin 4 are typically connected to a thermal diode. Here are some recommendations for optimal operation: a) Place remote diode as close as possible to W83772G b) Route D+ and D- lines away from clock generators, memory buses, or any high frequency buses c) Place shield traces, which are connecting to board ground, flanking D+/D- to shield the noise d) It is recommended that the bypass capacitor with 2200pF should be placed close to W83772G to filter the noise from motherboard digital signals e) Place a 0.1uF bypass capacitor close to the VCC pin The connection diagram is shown as the following GND W83772G D+ 2200pf DGND Figure 3. -6- Publication Release Date: July, 2008 Version: 1.3 W83772G 9. COMMAND SUMMARY The following table shows the supported SST commands. COMMAND Ping() DESCRIPTION Return a non-zero FCS over the header ResetDevice() Perform a functional reset similar to power-on reset GetIntTemp() Return the temperature of W83772G internal thermal sensor GetExtTemp() Return the temperature of W83772G external thermal diode GetAllTemps() Return a 4-byte block of data (internal plus external temperatures) The following sections will show the format of each command. For more terminology and information, please refer to Simple Serial Transport Specification. 9.1 Format of PING() Target Address Write Length Read Length (0x00) (0x00) -7- FCS Publication Release Date: July, 2008 Version: 1.3 W83772G 9.2 Format of ResetDevice() Target Address Write Length Read Length (0x01) (0x00) Reset Device Command FCS (0xf6) 9.3 Format of GetIntTemp() Target Address Write Length Read Length (0x01) (0x02) GetIntTemp Command (0x00) … FCS LSB Data MSB Data -8- FCS Publication Release Date: July, 2008 Version: 1.3 W83772G 9.4 Format of GetExtTemp() Target Address Write Length Read Length (0x01) (0x02) GetExtTemp Command (0x01) … FCS LSB Data MSB Data -9- FCS Publication Release Date: July, 2008 Version: 1.3 W83772G 9.5 Format of GetAllTemp() Target Address Write Length Read Length (0x01) (0x04) GetAllTemp Command (0x00) … … FCS Int. LSB Data Int. MSB Data Ext. LSB Data Ext. MSB Data FCS - 10 - Publication Release Date: July, 2008 Version: 1.3 W83772G 10. ELECTRICAL CHARACTERISTIC 10.1 Absolute Maximum Ratings PARAMETER RATING UNIT Power Supply Voltage 3.63 V Operating Temperature 70 C Storage Temperature -30 to C +127.875 Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 10.2 DC Characteristics (Ta = 0 C to 70 C, Vcc = 3.3V  10%, GND = 0V) PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS This set of DC electrical specifications is used with devices normally operating from a +1.5V interface supply voltage. The following voltage and current requirements refer to the SST electrical model. For the purpose of bus capacitance, the electrical model is a two-node circuit. One node is counted for each client and one node for the system host. VSSTIO is the internally generated +1.5V supply voltage for the SST interface. SST - IO pad power supply VSSTIO 1.40 1.50 1.60 Input Voltage range Vin Input Low Threshold Voltage Vt- Input High Threshold Voltage Vt+ Hysteresis VTH 0.15 V Output source current Isource -6.0 mA Voh=1.1V, VSSTIO =1.4V Input High Leakage ILIH +10 A VSST = VSSTIO Input Low Leakage ILIL -10 A VSST = 0V VSSTIO +0.3 0.40 0.65 V VSSTIO = 1.4V (MIN) VSSTIO = 1.6V (MAX) 0.8 1.10 V VSSTIO = 1.4V (MIN) VSSTIO = 1.6V (MAX) - 11 - Publication Release Date: July, 2008 Version: 1.3 W83772G PARAMETER SYM. MIN. TYP. 3.30 MAX. UNIT CONDITIONS ADDx Power Supply Voltage Vcc 2.97 Input Voltage range Vin -0.3 Input High Voltage Vth 1.95 3.63 V Vcc+0.3 V V Input Low Voltage 1.35 V Output source current Isource -0.7 -3 mA Voh=2.4V, Vcc=2.97V Output sink current Isink 0.7 2 mA Vol=0.4V, Vcc=2.97V PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS D+ Ouput Current I1 I1 15 uA Vcc = 3.3 V Output Current I2 I2 165 uA Vcc = 3.3 V 10.3 AC Characteristics Bus Rate: 1MHz (typical) Refer to the specification of Simple Serial Transport (SST) specification. - 12 - Publication Release Date: July, 2008 Version: 1.3 W83772G 11. ORDER INSTRUCTION PART NO. PACKAGE REMARKS W83772G MSOP8 Pb-free Package 12. TOP MARKING SPECIFICATION The top marking of W83772G 772G LUA 625B 1st line: type number: 772G 2nd line: assembly house ID(L) + internal code(UA) L: Lingsen UA: internal code 3rd line: Tracking code 626 B 625: packages made in '06, week 25 B: IC revision; A means version A, B means version B - 13 - Publication Release Date: July, 2008 Version: 1.3 W83772G 13. PACKAGE SPECIFICATION MSOP 8L 3mm X 3mm - 14 - Publication Release Date: July, 2008 Version: 1.3 W83772G Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. - 15 - Publication Release Date: July, 2008 Version: 1.3
W83772G 价格&库存
很抱歉,暂时无法提供与“W83772G”相匹配的价格&库存,您可以联系我们找货
