SEN-11050
SEN-11050
    SPARKFUNELECTRONICS
    TEMP SENSOR WTRPRF DS18B20 11050
SEN-11050 数据手册
Temperature Sensor Waterproof (DS18B20) SEN-11050 ROHS This sealed digital temperature probe lets you precisely measure temperatures in wet environments with a simple 1-Wire interface. The DS18B20 provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface, so that only one wire (and ground) needs to be connected from a central microprocessor. Note: The pinout for this sensor is as follows: RED=Vcc BLACK=GND WHITE=SIG FEATURES • • • • • • 3.0-5.5V input voltage Waterproof -55°C to+125°C temperature range ±0.5°C accuracy from -10°C to +85°C 1 Wire interface Probe is 7mm in diameter and roughly 26mm long. Overall length (including wire) is 6 feet. DOCUMENTS • • • Datasheet (DS18B20) Simple Sketch Code mbed Example https://www.sparkfun.com/products/11050/9-9-21
SEN-11050 价格&库存
很抱歉,暂时无法提供与“SEN-11050”相匹配的价格&库存,您可以联系我们找货
