Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L18P***D15 Series
Features:
Advantage:
Open Loop type
Printed circuit board mounting
Integrated primary
Voltage output
Busbar version from 40A to 60A
Insulated plastic case according
to UL94V0
UL Recognition
Excellent accuracy and linearity
Wide nominal current range
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
TA=25ºC, VCC=±15V, RL=10kΩ
L18P003 L18P005 L18P010 L18P015 L18P020 L18P025 L18P030 L18P040 L18P050 L18P060
Symbol
D15
D15
D15
D15
D15
D15
D15
D15
D15
D15
Parameters
3A
If
Primary nominal current
5A
10A
15A
20A
30A
40A
50A
60A
≥ ± If x 3
Ifmax
Saturation current
25A
Rated output voltage
Vo
4V ±0.040V (at If)
4V ±0.050V (at If)
Offset voltage1
Vof
≤ ±0.040V (at If=0A)
≤ ±0.050V (at If=0A)
Output linearity2(0A~If)
εL
≤ ±1% (at If)
Power supply voltage
VCC
±15V ±5%
Consumption current
Icc
≤ ±15mA
Response time3
tr
≤ 5μs (at di/dt = If / μs)
Thermal drift of gain4
TcVo
≤ ±0.1%/ ºC
Thermal drift of offset
TcVof
≤ ±1.5mV/ ºC
Hysteresis error
(at If=0A→If→0A)
VOH
Insulation voltage
Vd
AC3000V for 1minute (sensing current 0.5mA), primary secondary
Insulation resistance
RIS
≥ 500MΩ (at DC500V), primary secondary
TA
-30ºC~+80ºC
TS
-40ºC~+85ºC
Ambient operation temperature
Ambient storage temperature
≤ 25mV
≤ 40mV
1
After removal of core hysteresis— 2 Without offset —3 Time between 10% input current full scale and 90% of sensor output full scale —
4
Without
Electrical Performances
Frequency characteristic(L18P050D15)
6
15
10
2
Output voltage (V)
Attenuation (dB)
4
Saturation characteristic(L18P050D15)
-4
-6
5
TA=25ºC Pulsed
-8
-10
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=3Arms
L18PXXXD15revD, March 2012
100
-15
-200
-150
-100
-50
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
100
150
200
Mechanical dimensions
The following,
table references
Terminal Number:
1: -VCC(-15V)
2: GND
3: +VCC(+15V)
4: VOUT
5: Primary input current (+)
6: Primary input current (-)
Current XXX
3A
003
5A
005
10A
010
15A
015
20A
020
25A
025
30A
030
The following,
table references
φA
φ0.6
φ0.8
φ1.1
φ1.4
φ1.6
φ1.6
φ1.6
Current XXX
40A
040
50A
050
60A
060
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
3. Cover is optional parts.
Primary :Busbar
Electrical connection diagram
-VCC
+If
+VCC
-If
RL = 10kΩ
GND
VOUT
UL Standard
UL 508 , CSA C22.2 No.14
(UL FILE No.E243511)
• For use in Pollution Degree 2 Environment.
• Maximum Surrounding air temperature rating, 80˚C.
Package & Weight Information
nominal current
Weight
Pcs/box
Pcs/carton
Pcs/pallet
10A..60A
8g
100
600
12000
3A , 5A
8g
50
1200
28800
很抱歉,暂时无法提供与“L18P020D15”相匹配的价格&库存,您可以联系我们找货
