S22P015S05M2
S22P015S05M2
    TAMURA
    Module
    SENSOR CURRENT HALL 15A AC/DC
S22P015S05M2 数据手册
Hall Effect Current Sensors S22P***S05M2 Series Features: Advantages:              Closed Loop type Voltage output Unipolar power supply Configurable integrated primary Printed circuit board mounting UL recognised - plastic case material UL94V0  Improved dv/dt Immunity Specifications Parameters Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability TA=25ºC, VCC=+5V, RL=10kΩ Symbol S22P006S05M2 S22P015S05M2 S22P025S05M2 If 6A 15A 25A Saturation Current Ifmax ±18A ±45A ±75A Output Voltage VOUT Offset Voltage @ If=0 VOE Rated Current VOE ±0.625V @ If 2.5V±50mV 2.5V±20mV 2.5V±15mV Output Voltage Accuracy X 0.625V±10mV @ If Output Linearity εL ±0.2% @ If Supply Voltage VCC +5V±5% Current Consumption ICC Typ. 12.5mA (If=0)+37.5mA(If=max) tr ≤ 1.0μs @ di/dt = If / μs Output Temperature Characteristic TCVOUT < ±0.05mV/ºC Offset Temperature Characteristic TCVOE Response Time1 -10ºC~25ºC : ±1.6mV/ºC 25ºC~85ºC : ±0.8mV/ºC -10ºC~25ºC : ±0.6mV/ºC 25ºC~85ºC : ±0.3mV/ºC -10ºC~25ºC : ±0.4mV/ºC 25ºC~85ºC : ±0.2mV/ºC Hysteresis allowance VOH ≤0.5mV (0A  If) Insulation Withstanding Vd AC 3kV for 1minute (Sensing current 0.5mA) Primary  Secondary Insulation Resistance RIS > 500MΩ (@ DC500V) Primary  Secondary Frequency Bandwidth f DC … 200 kHz Operating Temperature TA -10ºC~+85ºC Storage Temperature TS -25ºC~+85ºC 1 Time between 10% input current full scale and 90% of sensor output full scale Electrical Performances Frequency Characteristic Saturation Characteristic 5,0 2,0 4,5 Output Voltage (V) Attenuation (dB) 0,0 -2,0 -4,0 -6,0 -8,0 4,0 3,5 3,0 2,5 2,0 1,5 1,0 0,5 0,0 -10,0 0,1 1 10 100 If frequency (kHz) @ If = 1.0Arms 1000 -100 -75 -50 -25 0 Tamura reserve the right to modify its products in order to improve them without prior notice S22P***S05M2 RevC, July 2013 25 Input current (A) 50 75 100 Hall Effect Current Sensors S22P***S05M2 Series Mechanical dimensions in mm +5V S22P G TAM S05 VOUT Lot N° Electrical connection diagram -If +If 3 2 1 4 5 6 Connection diagram 6 7 8 +If / 3 9 +If / 2 RL = 10kΩ OUT 1 2 3 6 5 4 OUT IN GND +If 1 2 3 6 5 4 OUT IN 1 2 Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 8g 100 400 9600 Tamura reserve the right to modify its products in order to improve them without prior notice S22P***S05M2 RevC, July 2013 4 IN +VCC VOUT 5 3
S22P015S05M2 价格&库存
很抱歉,暂时无法提供与“S22P015S05M2”相匹配的价格&库存,您可以联系我们找货
