Hall Effect Current Sensors L03S***D15 Series
Features:
Advantage:
Open Loop type
Panel mounting
Molex connector
Insulated plastic case according to
UL94V0
Excellent accuracy and linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Current overload capability
Specifications
Parameters
TA=25ºC, VCC=±15V, RL=10kΩ
Symbol L03S050D15 L03S100D15 L03S200D15 L03S300D15 L03S400D15 L03S500D15 L03S600D15
If
50AT
100AT
200AT
Maximum Current
Ifmax
±150AT
±300AT
±600AT
Output Voltage
VOUT
Offset Voltage
VOE
Rated current
300AT
400AT
4V±40mV @ If
≤±40mV @ If
= 0A
≤±30mV @ If = 0A
X
±1% @ If
Output Linearity1
εL
≤±1% @ If
VCC
±15V±5%
Consumption Current
IC
< 12mA
Response Time2
tr
< 5µs (@ di/dt=50A / µs)
Output Temperature CharacTCVOUT
teristic1
Offset Temperature CharacTCVOE
teristic
Hysteresis error
600AT
>±700AT
Accuracy1
Power Supply
500AT
≤±2mV/ºC
< ± 2mV/ºC
< ± 1.0 mV/ºC
±30mV (@ 0A ⇔ If)
VOH
±20mV (@ 0A ⇔ If)
±10mV (@ 0A ⇔ If)
Withstand Voltage
Vd
AC2500V for 1minute (sensing current 0.5mA), inside of through hole ⇔ terminal
Insulation Resistance
RIS
> 500MΩ (500V DC), inside of through hole ⇔ terminal
Frequency Bandwidth3
f
DC .. 50kHz
Operating Temperature
TA
-20ºC~+80ºC
Storage Temperature
TS
-20ºC~+85ºC
1
Without offset — 2 Time between 10% input current full scale and 90% of sensor output full scale — 3 Small signal only to avoid excessive heating of
magnetic core
Electrical Performances
Frequency Characteristic (L03S600D15)
Saturation Characteristic (L03S600D15)
2,0
O utput Voltage (V)
6,0
Attenuation (dB)
0,0
- 2,0
- 4,0
- 6,0
- 8,0
4,0
2,0
0,0
-2,0
-4,0
-6,0
- 10,0
0,1
1
10
If frequency (kHz) @ If=6.0Arms
L03SXXXD15revC, March 2009
100
-1200 -1000
-800
- 600
-400
-200
400
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
600
800
1000
1200
Mechanical dimensions in mm
Ø4.5
D15
Ø2.5
Lot No.
Note 1: Unless otherwise specified, tolerances shall be ±0.5
L03S
Recommended
retainer holes
40.5 MAX
Terminal number:
1. +15V
2. -15V
3. VOUT
4. 0V
Connector
29.5 MAX
5045-04A (MOLEX)
Terminal number
19.5 MAX
39 MAX
4321
30.5 MAX
Ø4.5
3
15
10.5
4.5
20.5
Ø2
18.5 MAX
Electrical connection diagram
+VCC
-VCC
1
2
3
4
GND
VOUT
RL = 10kΩ
+If
-If
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
46g
50
200
2400
很抱歉,暂时无法提供与“L03S600D15”相匹配的价格&库存,您可以联系我们找货
