Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L06P***S05 Series
Features:
Advantage:
Open Loop type
Printed circuit board mounting
Horizontal mounting
Unipolar power supply
Industrial temperature range
Mounting pins
Insulated plastic case according
to UL94V0
Excellent accuracy and linearity
Wide nominal current range
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
TA=25ºC, VCC=+5V, RL=10kΩ
Parameters
Symbol
L06P400S05
L06P600S05
L06P800S05
If
400AT
600AT
800AT
Primary nominal current
Saturation current
Ifmax
≥ ± If x 1.33
Rated output voltage
Vo
Vof +1.5V ± 0.035V (at If)
Offset voltage1
Vof
VREF1 ± 30mV (at If = 0A)
Output linearity2(0A~If)
εL
≤ ± 1% (at If)
Power supply voltage
VCC
+ 5V ± 0.1V
Consumption current
ICC
≤ 15mA
tr
≤ 5μs (at di/dt = 100A / μs)
Thermal drift of gain4
TcVo
≤ ± 1.5mV/ºC
Thermal drift of offset
TcVof
≤ ± 1.0 mV/ºC
Hysteresis error
VOH
≤ 10mV (at If = 0A→If →0A)
Insulation voltage
Vd
AC2500V for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ(at DC500V), inside of through hole terminal
TA
-40ºC~+85ºC
Response time3
Ambient operation temperature
Ambient storage temperature
-40ºC~+85ºC
TS
1
2
3
VREF = VCC / 2 (ratiometric) . After removal of core hysteresis— Without offset — Time between 90% input current full scale and 90% of sensor
output full scale— 4 Without Thermal drift of offset
Electrical Performances
Frequency characteristic(L06P400S05)
5.0
6
4.5
4
4.0
2
Output voltage (V)
Attenuation (dB)
Saturation characteristic(L06P400S05)
-4
-6
3.5
3.0
2.5
2.0
1.5
-8
1.0
-10
0.5
0.1
1
10
Frequency characteristic(kHz)
@ If=40AT(Arms)
L06PXXXS05revE, March 2012
100
0.0
-800
TA=25ºC Pulsed
-600
-400
-200
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
400
600
800
Mechanical dimensions
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
Terminal Number:
1: VOUT
2: GND
3: +VCC(+5V)
Electrical connection diagram
-If
+If
321
VOUT
+ VCC
RL = 10k
GND
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
65g
100
500
4800
很抱歉,暂时无法提供与“L06P600S05”相匹配的价格&库存,您可以联系我们找货
