UR-1640K-TT-2-R
UR-1640K-TT-2-R
    PUIAUDIO
    ULTRASONIC RECEIVER 20VRMS 2100P
UR-1640K-TT-2-R 数据手册
SPECIFICATIONS PARAMETERS MAXIMUM INPUT VOLTAGE CAPACITANCE SENSITIVITY (0 dB=1V/ BAR) CENTER FREQUENCY BANDWIDTH OPERATING TEMPERATURE STORAGE TEMPERATURE DIRECTIVITY (-6 dB) TERMINAL MATERIAL WEIGHT 16.2 VALUES UNIT 20 2100 20% -60 40,000 1,000 2500 -20 ~ +70 -30 ~ +80 80 Sn PLATED COPPER 4.8 VRMS pF dB Hz Hz C C grams THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING ADD BANDWITH, PIN LENGTH TOLERANCE CHANGE TO 1mm 6/1/2016 1/6/2020 ML 12.2 0.3 0.3 POSITIVE (+) 1 0.05 (2) 10 1 (2) NOTES: 10 0.3 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. DESIGNED FOR USE WITH THE UT-1640K-TT-2-R. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 UR-1640K-TT-2-R.idw Designed by Date Checked by Date Approved by Date Drawn Date M.V. 6/1/2016 M.V. 6/1/2016 B.R. 6/1/2016 6/1/2016 UR-1640K-TT-2-R Ultrasonic Receiver Edition Sheet - 1/1
UR-1640K-TT-2-R 价格&库存
很抱歉,暂时无法提供与“UR-1640K-TT-2-R”相匹配的价格&库存,您可以联系我们找货
