Page 1 of 3
SENSORS / PROXIMITY
Maxbotix Ultrasonic Rangefinder - LV-EZ4 LV-EZ4
PRODUCT ID: 982
Page 2 of 3
DESCRIPTION
LV-EZ4 Maxbotix Ultrasonic Rangefinder provides very short to long-range
detection and ranging, in an incredibly small package. It can detect objects from
0-inches to 254-inches (6.45-meters) and provides sonar range information from
6-inches out to 254-inches with 1-inch resolution. (Objects from 0 inches to
6-inches range as 6-inches.) The interface output formats included are pulse width
output (PWM), analog voltage output (Vcc/512 volts per inch), and serial digital
output (9600 baud).
A good sensor for when a Sharp IR distance sensor won't cut it. For example of
using this with an Arduino, see the Halloween Pumpkin project.
Many applications require a narrower beam or lower sensitivity than the LV
MaxSonar EZ1. Consequently, MaxBotix is offering the EZ2, EZ3, & EZ4 with
progressively narrower beam angles allowing the sensor to match the application.
LV-EZ4 Data Sheet / Product Information Guide is available here.
Page 3 of 3
The different LV models have different beam width patterns, check this image for a
comparison of all the LV model beam patterns.For higher sensitivity, check out the
HR-LV models - they have up to 1mm sensitivity and 5 meter range!
http://www.adafruit.com/products/982
7/24/2015
很抱歉,暂时无法提供与“982”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+282.178651+34.15605
