IMU280ZA-209
IMU280ZA-209
    MEMSIC(美新)
    IMU ACCEL/GYRO/MAG 3-AXIS SPI
IMU280ZA-209 数据手册
Power Sensing Solutions for a Better Life IMU280ZA INERTIAL MEASUREMENT SYSTEM The MEMSIC IMU280ZA is a low cost miniature fullycalibrated inertial measurement system designed for demanding embedded applications that require a complete dynamic measurement solution in a robust low-profile package. The IMU280ZA provides a standard SPI bus for cost-effective board-to-board communications. Features Complete 6DOF Inertial System Optional 3-Axis Magnetometer Standard and High Range Options SPI (or UART) Interface Cabin Leveling Antenna Stabilization The MEMSIC IMU280ZA integrates highly-reliable MEMS 6DOF inertial sensors (optional 3-axis magnetic sensors) in a miniature factory-calibrated module to provide consistent performance through the extreme operating environments in a wide variety of dynamic control and navigation applications. Update Rate, 1Hz to 200Hz 1KHz Clock Sync Input Miniature Package, 24 x 37 x 9.5 mm Lightweight < 17 g Low Power Consumption < 250 mW Wide Temp Range, -40C to +85C High Reliability, MTBF > 50k hours Applications  Cabin Leveling  Platform Stabilization  Unmanned Vehicle Control  Robotics Control Phone: 669.266.7441 Fax: 408.428.9428 E-mail: infoca@memsic.com Document P/N: 6020-2810-01 www.memsic.com IMU280ZA INERTIAL MEASUREMENT SYSTEM Performance IMU280ZA (-200,-209,-400,-409) Angular Rate Range: Roll, Pitch, Yaw (º/sec) Bias Instability (º/hr) 1,2 Bias Stability Over Temp (º/sec) 2 Resolution (º/sec) Scale Factor Accuracy (%) Non-Linearity (%FS) Angle Random Walk (º/√hr) 2 Bandwidth (Hz) ± 200 (± 400 High Range Model) < 20 < 2.0 < 0.02 < 0.2 < 0.2 < 1.5 5-50 (user-configurable) NAV-VIEW Configuration and Display Software Acceleration Range: X, Y, Z (g) Bias Instability (mg) 1,2 Bias Stability Over Temp (mg) 2 Resolution (mg) Scale Factor Accuracy (%) Non-Linearity (%FS) Velocity Random Walk (m/s/√hr) 2 Bandwidth (Hz) ± 4 (± 8 High Range Model) < 0.05 < 15 < 0.5 < 0.2 < 0.2 < 0.1 5-50 (user-configurable) Magnetic Field Range: X, Y, Z (Gauss) Resolution (mGauss) Noise Density (mGauss /√Hz) 2 Bandwidth (Hz) ±4
IMU280ZA-209 价格&库存
很抱歉,暂时无法提供与“IMU280ZA-209”相匹配的价格&库存,您可以联系我们找货
