KXTJ2 Accelerometer
2x2x0.9mm Low-Power Accelerometer
FEATURES
APPLICATIONS
Ultra-small Package - 2x2x0.9mm LGA
User-selectable g Range and Output Data Rate
8-bit, 12-bit, and 14-bit Resolution
Low Power Consumption
Internal voltage regulator
User-configurable wake-up function
Digital I2C
Lead-free Solderability
Excellent Temperature Performance
High Shock Survivability
Factory Programmable Offset and Sensitivity
Self-test Function
User Interface
Power Management
Active/Inactive Monitoring
Device Orientation
Inclination and Tilt Sensing
Gesture Recognition
Pedometer/Activity Monitoring
PRODUCT OVERVIEW
The KXTJ2 is one of our smallest tri-axis accelerometers,
designed for mobile applications. It offers excellent power
performance along with an embedded motion wake-up feature,
Fast-mode I2C and up to 14-bit resolution. The KXTJ2 is
delivered in a 2 x 2 x 0.9 mm, 12-pin, LGA package with an
operating temperature range of -40°C to +85°C.
The KXTJ2 sensor offers improved shock, reflow, and
temperature performance, and the ASIC has internal voltage
regulators that allow operation from 1.8 V to 3.6 V within the
specified product performance.
FOR
Smartphones and Mobile Devices
Laptops
Gaming and Virtual Reality
Health and Fitness
KXTJ2 Accelerometer
The performance parameters below are programmed and tested at 2.6 volts and T = 25°C. The device can accept supply voltages from 1.8V to
3.6V. Due to internal voltage regulators, there should be minimal change with supply voltage variations.
PERFORMANCE SPECIFICATIONS
PARAMETERS
Range
Sensitivity
1
KXTJ2-1009
CONDITION
g
±2.0, ±4.0, ±8.0
User-selectable full-scale output range
64, 32, 16
8-bit
counts/g
0g Offset vs. Temp
Sensitivity vs. Temp
Mechanical Resonance
3
Output Data Rate (ODR)
4
Bandwidth (-3dB)5
1024, 512, 256
12-bit
1024 typical
14-bit2
mg/°C
0.2
-40°C to +85°C
%/°C
±0.01 (xy) ±0.03 (z) typical
-40°C to +85°C
Hz
3500 (xy) 1800 (z) typical
-3dB
Hz
0.781 min; 50 typical; 1600 max
800
RES = 0
ODR/2
RES = 1
% of FS
1.0 typical
% of full scale output
2.0 typical
MHz
3.4 max
V
2.6 typical
1.8V – 3.6V
135 typical
High resolution (RES = 1)
10 typical
Low resolution (RES = 0)
2 typical
Standby
Hz
Non-Linearity
Cross-axis Sensitivity
2
I C Communication Rate
Power Supply
Current Consumption
UNITS
6
µA
ENVIRONMENTAL SPECIFICATIONS
PARAMETERS
UNITS
KXTJ2-1009
CONDITION
Operating Temperature
°C
-40 to 85
Powered
Storage Temperature
°C
-55 to 150
Un-powered
Mechanical Shock
g
5,000, 0.5 ms
10,000, 0.2 ms
Powered or un-powered,
halversine
ESD
V
2,000
Human body model
NOTES
1
Resolution and acceleration ranges are user selectable via I2C.
14-bit Resolution is only available for registers 0x06h – 0x0Bh in the 8g Full Power mode.
3
Resonance as defined by the dampened mechanical sensor.
4
User selectable through I2C.
5
User selectable; dependent on ODR and RES.
6
Current varies with Output Data Rate (ODR).
2
很抱歉,暂时无法提供与“KXTJ2-1009-FR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+6.1123710000+0.73972
