KXRB5-2050-FR
KXRB5-2050-FR
    KIONIX(Kionix传感器)
    VFLGA14
    IC ACCELEROMETER TRI-AXIS 14-LGA
KXRB5-2050-FR 数据手册
KXRB5 Series Accelerometers and Inclinometers FEATURES MARKETS APPLICATIONS Very Small Package - 3x5x0.9mm LGA Personal Navigation Devices Low Power Consumption Multiplexed Analog or Digital SPI Interface Inertial Navigation and Dead Reckoning Cell Phones and Handheld PDAs Internal 1KHz Low Pass Filter Ultra Low Noise Density Gesture Recognition Game Controllers & Computer Peripherals Lead-free Solderability Excellent Temperature Performance Inclination and Tilt Sensing Ultra-Mobile PCs/Laptops/Hard Disk Free-fall Detection High Shock Survivability User Definable Bandwidth Cameras and Video Equipment Image Stabilization Factory Programmable Offset and Sensitivity A/D Converter and Auxiliary Input to Multiplexer Sports Diagnostic Equipment/Pedometers Self-test Function Static or Dynamic Acceleration PROPRIETARY TECHNOLOGY These high-performance silicon micromachined linear accelerometers and inclinometers consist of a sensor element and an ASIC packaged in a 3x5x0.9 mm Land Grid Array (LGA). The sensor element is fabricated from single-crystal silicon with proprietary Deep Reactive Ion Etching (DRIE) processes, and is protected from the environment by a hermetically-sealed silicon cap at the wafer level. The KXRB5 series is designed to provide a high signal-to-noise ratio with excellent performance over temperature. These sensors can accept supply voltages between 2.5V and 5.25V. Sensitivity is factory programmable allowing customization for applications requiring from 1.5g to 6.0g ranges. Sensor bandwidth is user-definable. The auxiliary input to the A/D converter and multiplexer minimizes the need for external A/D converters. The sensor element functions on the principle of differential capacitance. Acceleration causes displacement of a silicon structure resulting in a change in capacitance. An ASIC, using a standard CMOS manufacturing process, detects and transforms changes in capacitance into an analog output voltage, which is proportional to acceleration. 36 Thornwood Dr. - Ithaca, NY 14850 USA tel: 607-257-1080 - fax: 607-257-1146 - www.kionix.com - info@kionix.com “Kionix” is a registered trademark of Kionix, Inc. Products described herein are protected by patents issued or pending. Information provided in this document is believed to be accurate and reliable but is not guaranteed. Kionix does not assume responsibility for its use or distribution. No license is granted by implication or otherwise under any patent or other rights of Kionix. Kionix reserves the right to change product specifications or discontinue this product at any time without prior notice. © Kionix 2010 All Rights Reserved September 8, 2010 Rev. 1.2 Page 1 of 2 KXRB5 Series Accelerometers and Inclinometers PERFORMANCE SPECIFICATIONS The performance parameters below are programmed and tested at 3.0 and 3.3 volts respectively. However, the device can be factory programmed to accept supply voltages from 2.5 V to 5.25 V. Performance parameters will change with supply voltage variations. PERFORMANCE SPECIFICATIONS PARAMETERS Range UNITS 1 KXRB5-2042 CONDITION ±2.0 g Sensitivity KXRB5-2050 mV/g 600 typical (618 max) Factory programmable 660 typical (680 max) 0g Offset vs. Temp. mg/°C ±0.2 typical Sensitivity vs. Temp %/°C ±0.01 (xy) typical ±0.02 (z) typical Noise 45 typical µ g /HzHz 1000 typical -3dB % of FS 0.1 typical % of full scale output Ratiometric Error % 0.2 typical Vdd ± 5% Cross-axis Sensitivity % 2.0 typical Power Supply V Bandwidth 2 Non-Linearity 3.0 3.3 Standard µA 500 typical (700 max) Operating µA 1 typical Standby Current Consumption ENVIRONMENTAL SPECIFICATIONS PARAMETERS UNITS KXRB5-2050 KXRB5-2042 CONDITION Operating Temperature °C -40 to 85 Powered Storage Temperature °C -55 to 150 Un-powered Mechanical Shock g 5000 Powered or un-powered, 0.5 msec halversine ESD V 3000 Human body model NOTES 1 Custom ranges from 1.5g to 6.0g available. 2 Internal low pass filter. Lower frequencies are user definable with external capacitors. ORDERING GUIDE Output Axis(es) of Sensitivity Range (g) Sensitivity mV/g Offset (V) Operating Voltage (V) Temperature (°C) Package KXRB5-2042 Multiplexed Analog XYZ 2 600 1.5 3.0 -40 to +85 3x5x0.9 LGA KXRB5-2050 Multiplexed Analog XYZ 2 660 1.65 3.3 -40 to +85 3x5x0.9 LGA Product Contact Kionix for part number assignments with SPI output. © Kionix 2010 All Rights Reserved September 8, 2010 Rev. 1.2 Page 2 of 2
KXRB5-2050-FR 价格&库存
很抱歉,暂时无法提供与“KXRB5-2050-FR”相匹配的价格&库存,您可以联系我们找货
