AS500106
AS500106
    ZF
    CARRIER MAGNET ACTUATOR
AS500106 数据手册
Angle Position Sensors AS500106 Magnet carrier for use with Angle Position Sensors Features    PPS housing Samarium Cobalt 28 magnet RoHS compliant Environmental Specifications Vibration Operation Temperature Storage Temperature Salt Spray Immersion 15g sinusoidal, 9.26g RMS axial; 40 Hz – 2 kHz all 3 axes -40 °C to 125 °C (-40 °F to 257 °F) -40 °C to 150 °C (-40 °F to 302 °F) SAEJ1455, Section 4.3.3 Tested per SAE J 1455, Section 4.4.1: Engine oil and additives, Transmission oils, Water, Power steering fluid, Brake fluids, Washer solvent, Gasoline, Diesel fuel, Alcohol, Antifreeze water mixture, Battery acid, Salt water, Kerosene, Ammonia Mechanical Specifications Recommended Fastener Recommended Torque M4 Cap Screw 3 Nm (26.5 in lbs) Products Part Number AS500106 CU103601 CU103602 CU103603 Description Magnet only Kit with AN820001 sensor Kit with AN820002 sensor Kit with AN820003 sensor Dimensions mm (inches) www.cherryswitches.com Page 1 of 1, last update 2014-10-29, Specifications subject to change without notice. Sensing Range N/A 180° 360° 45°
AS500106
1. 物料型号:AS500106,这是一款用于角位置传感器的磁体载体。 2. 器件简介:文档中提到了PPS外壳和钐钴28磁铁,并且符合RoHS标准。 3. 引脚分配:文档中没有明确提供引脚分配信息。 4. 参数特性: - 振动:15g正弦波,9.26g RMS轴向;40 Hz - 2 kHz所有三个轴 - 工作温度:-40°C至125°C(-40°F至257°F) - 存储温度:-40°C至150°C(-40°F至302°F) - 盐雾测试:符合SAEJ1455第4.3.3节 - 浸泡测试:根据SAE J 1455第4.4.1节测试,包括多种液体和化学物质。 5. 功能详解:文档中没有提供详细的功能解释。 6. 应用信息:文档列出了与AN820001、AN820002和AN820003传感器配套的套件,覆盖了180°、360°和45°的感应范围。 7. 封装信息:提供了磁体载体的尺寸和安装表面规格。
AS500106 价格&库存
很抱歉,暂时无法提供与“AS500106”相匹配的价格&库存,您可以联系我们找货
