26700-202
    AVENTOOLS(艾文)
    MIGHTY SCOPE ANLG 200X 250MA
26700-202 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address: www.aventools.com All Categories > Optical Inspection Tools > Digital Hand Held and Shop Microscopes > Digital Microscopes > Mighty Scope Hand-Held Digital Microscopes > Item # 26700-202 Item # 26700-202, Mighty Scope Analog - 10-200x z z z z larger image z z z z z Easy to use, 6-LED hand-held digital microscope with a USB interface. Detailed examination of any area you choose. Resolution 510 x 496 NTSC and 628 x 586 PAL Active Pixel Technology produces sharp images and accurate color reproduction. The LED's can be turned on or off , brightness can be adjusted using control wheel on body Adjustable magnification from 10x - 200x, all in one compact lens. No PC Required. Plugs into your TV Monitor with supplied RCA plugs. TV must have RCA inputs Metal Stand with height and angle adjustment included. Optional stands available Can be used for science and engineering work, dermatology, detailed repair, assembly and quality control (i.e. electronics, mechanical, etc), hobbies & collecting (coin, stamp, watch, jewelry, etc.), law enforcement (counterfeit ID, crime lab, etc), entertainment and much more. Specifications · Options Specifications Image Sensor 1/3" Color CMOS Effective Pixels (HxV) 0.3M Signal Output NTSC PAL Video Output 1 Vpp analog Video @ 75 ohm, RCA Jack Magnification 10x to 200x Gain Control Auto Gain Control White Balance Automatic Power Source 5 VDC Power Consumption 250 mA (AVG) LED Light Type 6 White LEDs Frame Rate 30 fps Working Distance At 10x, 112 mm At 20x, 42 mm At 30x, 19 mm At 40x, 8.5 mm Weight 1.55 lb Options Stands 26700-210, Mighty Scope Boom Stand 26700-213, Cradle Stand 26700-212, Mighty Scope Flex Stand
26700-202 价格&库存
很抱歉,暂时无法提供与“26700-202”相匹配的价格&库存,您可以联系我们找货
