SPZT-50
SPZT-50
    AVENTOOLS(艾文)
    STEREO ZOOM BODY 6.7X-50X
SPZT-50 数据手册
SPZT-50 - Trinocular Stereo Zoom Microscope Products  Aven's Complete Product Line : Microscopy and Inspection : Microscopes : Stereo Microscopes : Design Your Own Microscope System : SPZ-50 Stereo Zoom Body 6.7x to 50x SPZT-50 - Trinocular Stereo Zoom Microscope • Product # SPZT-50  Rating: Product # : SPZT-50 Overview : Provides crisp clear 3D images, long working distance and a wide field of view. 6.7x to 50x continuous zoom with 10x eyepieces. Photo eyepiece with adjustment ring allows mounting of cameras for viewing on a monitor. Create your customized system from the options below. Follow the step-by-step process to choose your stand, mount, illumination, auxiliary lenses and eyepieces for a complete custom solution tailored to your needs. After you have made your selections, add the item to the cart. Description Features Specs SPZT-50 Stereo Zoom Microscope Body Type Trinocular, 360° rotatable, 45° inclined eyepiece tube & C-mount camera port Eyepieces Two 10x(FN23)eyepieces supplied with microscope body. Optional 15x(FN15) and 20x(FN11.4) available to extend magnification range Auxiliary lens Working Distance 0.5x, 0.75x, 1.6x and 2x auxiliary lenses available to extended magnification range of microscope 108mm without auxiliary lens 240mm with 0.5x auxiliary lens 132mm with 0.75x auxiliary lens 50mm with 1.6x auxiliary lens 41mm with 2x auxiliary lens Zoom Ratio 7.46:1 Diopter Adjustment On both eye tubes: +5.6D-.72D Interpupillary Distance Adjustable from 52 to 75mm Optical System Greenough 1ea SPZT Trinocular Stereo Zoom Microscope Body with Photo tube 2 ea. 10x Eyepieces 2 ea. Rubber Eyeguards 1 ea. Dust Cover 1 ea. Instruction Manual Package Contents Weight 5lb Optical Data Eyepiece | DHW10X (F.N. 23) Auxiliary Lens Nil w/0.5x w/0.75x w/1.6x w/2x Magnifications 6.7x-50x 3.35x-25x 5x-37.5x 10.72x-80x 13.4x-100x Working Dist. 108mm 240mm 132mm 50mm 41mm Field of View 34.3-4.6mm 68.9-9.2mm 45.7-6.1mm 21.4-2.8mm 7.1-2.3mm Eyepiece | DHW15X (F.N.15) Auxiliary Lens Nil w/0.5x w/0.75x w/1.6x w/2x Magnifications 10.05x-75x 5.02x-37.5x 7.53x-56.25x 16.08x-120x 20.1x-150x Working Dist. 108mm 240mm 132mm 50mm 41mm Field of View 22.3-3mm 44.7-6mm 29.8-4mm 16-1.8mm 11.1-1.5mm Eyepiece | DHW20X (F.N. 11.4) Auxiliary Lens Nil w/0.5x w/0.75x w/1.6x w/2x Magnifications 13.4x-100x 6.7x-50x 10.05x-75x 21.44x-160x 26.8x-200x Working Dist. 108mm 240mm 132mm 50mm 41mm Field of View 17-2.2mm 34-4.5mm 22.6-3mm 10.6-1.4mm 8.5-1.1mm http://www.aveninc.com/...-inspection/microscopes/stereo-microscopes/design-your-own-microscope-system/spz-50-stereo-zoom-body/spzt-50-trinocular-stereo-zoom-microscope[9/5/2014 2:05:16 PM]
SPZT-50 价格&库存
很抱歉,暂时无法提供与“SPZT-50”相匹配的价格&库存,您可以联系我们找货
