KFM
KFK025822
Old item no.: 17115WT
KFM-1/AH 5D 3C Wh
KFM has a sturdy all-metal construction with a sleek design, flexible
arm and excellent light output suitable for a variety of industrial,
laboratory, cosmetology and low-vision application. The flexibility of the
neck assembly and patented internal spring 45" K-arm makes exact
positioning easy. 5-diopter (2.25X) optical-quality glass lens. Edge
clamp mount. Color: white.
Optic
Color of reflector
Material of diffuser
Primary Lens (D)
Working distance (mm)
Material of reflector
Magnification (X)
Lightsource
White
Polycarbonate
5
200
PC
Number of lamps
Lamp power (W)
Lamp base
CRI and/or Color Temperature
Lightsource
1
22
G10Q
4100K
T9
2.25
Dimensions
Electrical data
Maximum frequency (Hz)
Minimum frequency (Hz)
Net weight (kg)
60
Gross weight (lb.)
11
50
Arm length (in.)
45
Maximum voltage (V)
120
Voltage from (V)
100
Termination
Cord length (ft)
Body
Body color
Body material
3,4
Mounting
6
Edge clamp
White
Aluminum
Ballast
Type of Ballast
High frequency
Technical data
IP classification
glamox.com/luxous
The Company reserves the right to change any product specifications without prior notification.
11/11/2016
很抱歉,暂时无法提供与“KFK025822”相匹配的价格&库存,您可以联系我们找货
