engineered to light up your design
www.vcclite.com
1.800.522.5546
5331H Series Vertical LED Assembly
Description and Features
All dimensions in inches.
.220 MIN.
Features
• Block mounting design assures height
and side-by-side spacing-alignment
saves assembly costs.
• UltraBriteT-1 3/4 LED lamp, non-diffused
narrow beam high intensity light.
• Press-in mounting pin secures assembly
to PC board for soldering.
• Stand offs prevent flux entrapment.
• RoHS Compliant
OV E R LAY
.130 MAX.
T OP P ANE L
.260
.750
.720 ± .020
.020 S T AND-OF F
F OR P OS T C LE ANING
.100
Housing: Black Nylon, UL94V-O
Note: Alternate LEDs are also available
in this package as a standard variation.
.150 MIN.
P C B OAR D
ANODE (+)
.100
Ø.290
.142 REF.
Ø.063±.002
.100
Mounting Hole Pattern.
ANODE (+)
Electro-Optical Characteristics and Ratings
Part Number
5331H1
5331H5
5331H7
Emitted
Color
Red
Green
Yellow
Typical
Intensity
(mcd)
68
100
160
Rated
Current
(mA )
Continuous
Forward
Current Max.
(mA)
60
60
60
Forward Voltage
Typ.
(V)
Max.
(V)
2.1
2.2
2.2
3.0
3.0
3.0
Reverse
Breakdown
Voltage Min.
(V)
5
5
5
Peak
Wavelength
(nm)
650
563
585
Peak Forward
Current at
1MS-300PPS
(A)
.1
.09
.1
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
02/15 Rev 1.
很抱歉,暂时无法提供与“5331H5”相匹配的价格&库存,您可以联系我们找货
