engineered to light up your design
www.vcclite.com
1.800.522.5546
6321F Series T-1 Circuit Board Indicator
Description and Features
.100
TYP.
.200
TYP.
All dimensions in inches.
OR IE NT AT ION NOT C H
DE NOT E S
C AT HODE (-)
.200
.100
TYP.
LE D T -1 S IZE
C OLOR AS S P E C IF IE D
.100±.015
TYP.
HOUS ING :
B LAC K T HE R MOP LAS T IC
(UL94-V Ø)
.420
.150±.015
Features
• T-1 LED block mounting design assures height and side-by-side spacing alignment saves assembly costs.
• Blocks have interlock feature which allows for multi LED arrays.
• Black plastic mounting block provides high contrast ratio.
• High Brite and Super Brite light output.
• Standoffs prevent flux entrapment.
• Meets UL 94V-O and Bellcore flammability specifications.
• RoHS Compliant
Available options:
• Low current, 5 Volt and 12 Volt built-in resistors.
• Bicolor and blue LEDs also offered.
Call factory for ordering information.
Refer to “Mounting Hole Pattern 2.pdf”
Electro-Optical Characteristics and Ratings
Part Number
Emitted
Colo r
Typical
Intensity
(mcd)
Rated
Current
(mA )
Continuous
Forward
Current Max.
(mA)
Forward Voltage
Typ.
(V)
Max.
(V)
Reverse
Breakdown
Voltage Min.
(V)
Peak
Wavelength
(nm)
6321F1
Red
10
10
25
6.5
10
25
3.0
3.0
635
Amber
1.9
2.2
5
6321F3
5
602
6321F5
Green
8.5
10
25
2.1
3.0
5
565
6321F7
Yellow
10
10
25
2.0
3.0
5
583
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“6321F5”相匹配的价格&库存,您可以联系我们找货
