engineered to light up your design
www.vcclite.com
1.800.522.5546
5600 Series T-1 Right Angle LED Assembly
Description and Features
3. 00/2. 30
4. 10
5. 30
HOUS IN G :
B L A C K T H E R MO P L A S T IC
UL 94-V 0
0. 50 S T A N D - O F F
6. 40
3. 00
4. 80/4. 10
C A T H O DE ( - )
0. 50
1. 30
LE D T-1 S IZ E
S E E S P E C . T AB L E
2. 50
All dimens ions in mm.
Features
• Small T-1 size lamp preassembled into Nylon plastic block.
• Height and spacing alignment, saves assembly cost.
• Super Brite and High Brite LEDs.
• High light output - diffused lens.
• High contrast ratio.
• Low current - only 2 mA.
• Built -in resistor chip operates off 5 volt supply without external resistor.
• Standoffs prevent flux entrapment.
• RoHS Compliant
Housing: Black Nylon,UL94V-O
Note: Alternate LEDs are also available in this package as a standard variation.
Electro-Optical Characteristics and Ratings
Part
Number
Color
Typ.
Intensity
(mcd)
Rated
Current
(mA)
5600F1
Red
10
10
5600F3
Amber
7
10
Continuous
Reverse
Forward
Forward
Forward
Break-down
Current Max. Voltage Typ. Voltag e Max. Voltag e Min.
(V)
(V)
(mA)
(V)
30
2.0
5
3.0
30
2.2
5
3.0
Peak
Wave length
(nm)
650
603
5600F5
Green
16
10
30
2.2
3.0
5
562
5600F7
Yellow
6.3
10
30
2.1
3.0
5
585
5600F1LC
Red
2.5
2.0
7
1.8
2.2
5
635
5600F5LC
Green
2.1
2.0
7
1.8
2.2
5
565
5600F7LC
Yellow
1.8
2.0
7
1.9
2.7
5
583
5602F1-5V
Red
8.0
10
7.5
5
655
5602F3-5V
Amber
8.0
10
15
5
7.5
5
583
5602F5-5V
Green
8.0
10
15
5
7.5
5
565
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5600F5LC”相匹配的价格&库存,您可以联系我们找货
