5320F1
5320F1
    VCC
    LED RED T1 .35" HI RT ANG ASSY
5320F1 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5320 & 5322 Series T-1 Right Angle LED Assembly Description and Features .180 MAX. .130±.020 .190 MAX. .090 .130 MAX. .020 F LUX WAS H S T AND-OF F T -1 LE D S UP E R -B R IT E DIM A .100 .150 MIN. Note: Alternate LEDs are also available ANODE in this package as a standard variation. .040 All dimensions in inches. 5320 5322 Features • T-1 LED lamp right angle mounted, preassembled and tested. • Black Nylon block, high contrast ratio, height and spacing alignment - saves assembly cost. • High Brite and Super Brite LEDs-diffused lens. • Mounting pins secure block to PC board while soldering. • 2 different board heights to select from. • RoHS Compliant Refer to “Mounting Hole Pattern 1.pdf” DIM A .35 (8.9) .25 (6.4) Electro-Optical Characteristics and Ratings P art Number 5322F 1 5322F 5 5322F 7 5320F 1 5320F 5 5320F 7 E mitted C olor R ed G reen Y ellow R ed G reen Y ellow T ypical Intensity (mcd) 10 16 6.3 10 16 6.3 R ated C urrent (mA) 10 10 10 10 10 10 C ontinuous F orward C urrent Max. (mA) 30 30 30 30 30 30 T yp. (V ) Max. (V ) R everse B reakdown V oltage Min. (V ) 2.0 2.2 2.1 2.0 2.2 2.1 3.0 3.0 3.0 3.0 3.0 3.0 5 5 5 5 5 5 F orward V oltage CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. P eak Wavelength (nm) 650 562 585 650 562 585
5320F1 价格&库存
很抱歉,暂时无法提供与“5320F1”相匹配的价格&库存,您可以联系我们找货
