SUNON
SPECIFICATION FOR APPROVAL
CUSTOMER
MOTOR TYPE
MODEL NO
: LA004-024A83DY
DESCRIPTION
: LED Cooling Module
DIMENSIONS
: ∮86 × 45.4 mm
SUNON SPEC. NO.
: C03001860G-00
CUSTOMER
APPROVAL NO.
APPROVED BY
CUSTOMER
(AUTHORIZED)
DRAWN
CHECKED
Alice-Chang
07/02
Kiddy
Cindy
APPROVED
Kelly
SPEC. NO
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
建準電機工業股份有限公司
SUNONWEALTH ELECTRIC MACHINE INDUSTRY CO., LTD.
NO. 30, LN. 296, XINYA RD., QIANZHEN DIST.,
TEL:886-7-8135888
KAOHSIUNG CITY 80673, TAIWAN (R.O.C)
FAX:886-7-8230505/8230606/8231010
URL:http://www.sunon.com
E-mail: sunon@email.sunon.com.tw
D.C.C.
2014.07.07
SUNON
CHECK LIST
1. SCOPE --------------------------------------------------- Page 2
2. SPECIFICATIONS ------------------------------------ Page 3
3. DIMENSION --------------------------------------------- Page 4-5
4.CHARACTERISTIC DEFINITION
4. CHARACTERISTIC DEFINITION---------------------- Page 6
5. NOTES ----------------------------------------------------- Page 7-9
6. Declaration of RoHS ------------------------------------- Page 10
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
1 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
1.SCOPE
This compact LED cooling module (including SUNON’s
patented fan) is designed for heat dissipation of LED
lamp.
The following specification outlines the performance
of this module for LED lighting system
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
2 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
MODEL : LA004-024A83DY
2.SPECIFICATIONS
1. Module Dimension
∮86 × 45.4 mm
2. Heat Sink Material
AL6063
3. Fan Model Number
HA60150V3-E03U-A99
4. Fan Speed (with Heat Sink)
2200 RPM ± 10%
5. Rated Voltage
5 VDC
6. Rated Current
51 mA
7. Power Consumption
0.26 Watts
8. Fan Bearing System
Vapo
9. Cooling Module Noise
17.0 dB(A)
10. Operating Voltage Range
3.5 ~5.5 VDC
11. Operating Temperature
-10 to + 70 deg. C
12. Storage Temperature
-40 to + 70 deg. C
13. Weight
194 g
14. Thermal resistance
0.53 ℃/W ± 15% (Based on Fortimo SLM3000 G3)
15. Tolerance
±15% on rated power and current.
16. Life Expectancy (MTTF)
70,000 Hours at 60 deg. C, 65% humidity, 90% CL.
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
3 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
3.DIMENSION
UNIT : mm
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
4 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
Fixing Holes Direction for LED Module
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
5 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
1. THERMAL RESISTANCE
Fortimo SLM3000 G3
A simplified model of thermal path from heat source to ambient.
2. ACOUSTICAL NOISE
Measured in a semi-anechoic chamber with background noise level below 9.1dB(A).
The LED cooling module is running in free air under shaft horizontal condition with the
microphone at distance of one meter from the fan intake.
PAGE
SUNONWEALTH
MACHINE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
6 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
Notes
Ⅰ.SAFETY
1. DO NOT use or operate this module in excess of the limitations set forth in
this specification.SUNON is not responsible for the non-performance of
this module and/or any damages resulting from its use, if it is not used or
operated in accordance with the specifications.
2. SUNON recommends adding a protection circuit to the product or application
in which this module is installed, such as a thermo-fuse, or current-fuse or
thermo-protector. The failure to use such a device may result in smoke, fire,
electric shock by insulation degradation in cases of motor lead short circuit,
overload, or over voltage, and/or other failure.
3. SUNON recommends installing a protection device to the product or
application in which this module is installed if there is a possibility of
reverse-connection between VDC (+) and GND (-). The failure to install
such a device may result in smoke, fire, and/or destruction, although these
conditions may not manifest immediately.
4. This module must be installed and used in compliance with all applicable
safety standards and regulations.
5. Use proper care when handling and/or installing this module. Improper
handling or installation of this module may cause damage that could result
in unsafe conditions.
6. Use proper care during installation and/or wiring. Failure to use proper
care may cause damage to certain components of the module including,
but not limited to, the coil and lead wires, which could result in smoke
and/or fire.
7. DO NOT use power or ground PWM to control the fan speed. If the fan
speed needs to be adjusted, please contact SUNON to customize the
product design for your application.
8. For critical or extreme environments, including non stop operation, please
contact SUNON and we will gladly provide assistance with your product
selection to ensure an appropriate cooling product for your application.
SUNONWEALTH
MACHINE
PAGE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
7 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
Notes
II.
SPECIFICATION MODIFICATION
1. SUNON offers engineering assistance on module installation and cooling system
design.
2. All changes, modifications and/or revisions to the specifications, if any, are
incorporated in the attached specifications.
3. No changes, modifications and/or revisions to these specifications are effective
absent agreement, by both SUNON and the customer, in writing.
4. This module will be shipped in accordance with the attached specification
unless SUNON and the customer have agreed otherwise, in writing, as
specified in Paragraph 3, above.
III.
OTHER
1. When building your device, please examine thoroughly any variation of EMC,
temperature rise, life data, quality, etc. of this product by
shock/drop/vibration testing, etc. If there are any problems or accidents in
connection with this product, it should be mutually discussed and examined.
2. Use proper care when handling this module. Components such as module
holders or bearings may be damaged, if touched with fingers or other objects.
Additionally, static electricity (ESD) may damage the internal circuits of the
module.
3. DO NOT operate this module in proximity to hazardous materials such as
organic silicon, cyanogens, formalin, phenol, or corrosive gas environments
including, but not limited to, H2S, SO2, NO2, or Cl2.
4. SUNON recommends that you protect this module from exposure to outside
elements such as dust, condensation, humidity or insects. Exposure of this
module to outside elements such as dust, condensation, humidity or insects
may affect its performance and may cause safety hazards. SUNON does not
warrant against damage to the product caused by outside elements.
SUNONWEALTH
MACHINE
PAGE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
8 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
Notes
5. This module must be installed properly and securely. Improper mounting
may cause harsh resonance, vibration, and noise.
6. Fan guards may prevent injury during handling or installation of the module
and are available for sale with this module.
7. Unless otherwise noted, all testing of this module is conducted at 25°C
ambient temperature and sixty-five percent (65%) relative humidity.
8. DO NOT store this module in an environment with high humidity. This module
must be stored in accordance with the attached specifications regarding
storage temperature. If this module is stored for more than 6 months, SUNON
recommends functional testing before using.
9. SUNON reserves the right to use components from multiple sources at its
discretion. The use of components from other sources will not affect the
specifications as described herein.
10. The “Life Expectancy” of this module has not been evaluated for use in
combination with any end application. Therefore, the Life Expectancy Test
Reports (L10 and MTTF Report) that relate to this module are only for
reference.
VI. WARRANTY
This module is warranted against all defects which are proved to be fault
in our workmanship and material for one year from the date of our delivery.
The sole responsibility under the warranty shall be limited to the repair of the
module or the replacement thereof, at SUNON’s sole discretion. SUNON will
not be responsible for the failures of its modules due to improper handing,
misuse or the failure to follow specifications or instructions for use. In the event
of warranty claim, the customer shall immediately notify SUNON for
verification. SUNON will not be responsible for any consequential damage to
the customer’s equipment as a result of any modules proven to be defective.
SUNONWEALTH
MACHINE
PAGE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
9 OF 10
SPEC. NO.
C03001860G-00
ISSUED DATE
07.02.2014
EDITION
REVISION DATE
D.C.C.
2014.07.07
SUNON
Declaration of RoHS
Control declaration of environment- related substances/ materials
1. In accordance with the Restriction of Hazardous Substances (RoHS) Directive 2011/65/EU,
SUNON product have complied with law and discipline not to employ the forbidden
substances, and restrict the allowable concentration of some limited substances deliberately
in our components.
No
Substance
1 CFCs & HCFCs (ozone depleting substances)
2 Chlorinated Organic Solvent
Plastic (Frame, Impeller, wire harness, etc.)
Solder
3 Lead and its compounds
Steel alloy
Aluminium alloy
Copper alloy
Solder
Parts composed of metals containing zinc
4 Cadmium and its compounds
(e.g. brass, zinc for die casting)
Plastic
5 PBBs and PBDEs
6 PCB and PCT
7 CP, Short-chain Chlorinated paraffins C10-13, Cl ≥48 wt%
8 Mirex
9 PCN
10 Hexavalent Chromium compounds
11 Mercury and its compounds
12 Asbestos
13 Organic Tin compounds
14 Azo compounds
15 TBBP-A in external case plastic parts of products (PCB is exempted)
Nickel in external case parts, which are likely to result in prolonged skin
16
exposure
17 Hexabromocyclododecane (HBCDD)
18 Di-butyl Phthalate (DBP)
19 Benzyl butyl Phthalate (BBP)
20 Di-ethylhexyl Phthalate (DEHP)
21 Di-isobutyl Phthalate (DIBP)
SUNONWEALTH
MACHINE
PAGE
ELECTRIC
INDUSTRY
建準電機工業股份有限公司
CO.,
LTD.
10
Criteria
Forbidden
Forbidden
