7012X5
7012X5
    VCC
    LED GREEN CLEAR 0805 SMD
7012X5 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7012X Series Bright Chips™ High Brightness SMT LEDs 0805 Package Size Description and Features ANODE (+) .031 .043 .0 12 .049 .0 51 .079 .051 .047 .005 DIE OFF S E T LE D C HIP C AT HODE MAR K C AT HODE (-) All dimensions in inches. • Premium brightness in miniature chip-type LED assemblies. • Ideally suited for applications such as telecommunications, dataprocessing peripherals and networking units as replacements for through-hole products. • Also ideal for backlighting or light pipe applications. • Compact size: 2mm wide x 1.25mm deep x 1mm high • 4000 pieces per reel • RoHS Compliant • Integral reflection cup maximizes output • Compatible with full range of IR and vapor phase reflow processes, and conductive adhesives, to facilitate high-speed board loading. • Packaged for automatic component placement in pocketed anti-static tape reels. • Refer to “Solder Pad Geometry 1.pdf” Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffus ion P a ckage C olor T es t C urrent (mA) F orward Voltage Typ. (V) F orward V oltage Max. (V ) Luminous Intens ity M in. (mcd) Luminous Intens ity T yp. (mcd) Luminous Intens ity Max. (mcd) P eak Wavelength (nm) Viewing Ang le 20 1/2 (de grees ) P ower Di ssi pation (mW) Operating T emperature (°C ) S torage T empe rature (°C ) P eak F orward C urrentMax. (1μs @ 10% duty cy cle) (mA) R everse V oltage (IR =100μA) (V ) Lead S older T ime @ 260°C 7012X5 G reen Diffus ed C lear 20 2. 1 2. 5 3. 8 6. 4 560 62. 5 -40 to +85 -40 to +90 60 4 5 7012X1 R ed Diffus ed C lear 20 1. 7 2. 0 7. 0 11. 7 660 50 -40 to +85 -40 to +90 60 4 5 7012X7 Y ellow-Gr een Diffus ed C lear 20 2. 1 2. 5 7. 0 11. 7 570 62. 5 -40 to +85 -40 to +90 60 4 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
7012X5 价格&库存
很抱歉,暂时无法提供与“7012X5”相匹配的价格&库存,您可以联系我们找货
7012X5
    • 1+4.31640
    库存:25
    7012X5
      库存:4159
