12V-DUB-CW-12M
12V-DUB-CW-12M
    INSPIREDLED
    LEDENGCOOLWHT6000K12MREEL
12V-DUB-CW-12M 数据手册
Flexible LED Strip Lights Inspired LED Flexible Strip Lights are a simple, customizable solution for all of your LED lighting needs. These unique strips can be cut to length and terminated with solderless end connectors for easy DIY installation. Energy efficient, with a wide range of options for brightness and color, LED Flex Strips are the perfect option for any lighting application. Warm White 3000K Pure White 4200K Cool White 6000K Red Green Blue NB – Normal Bright ≈ 9 LEDs per foot, 90 lumens per foot, 1 watt per foot SB – Super Bright ≈ 18 LEDs per foot, 170 lumens per foot, 2 watts per foot UB – Ultra Bright ≈ 30 LEDs per foot, 295 lumens per foot, 3.25 watts per foot MB – Mega Bright ≈ 36 LEDs per foot, 335 lumens per foot, 3.5 watts per foot Available in NB & SB Only NB, SB & UB Only Product Features    Minimal Heat Production- No IR or UV Available in various colors and brightness levels Custom pre-cut lengths or full 12m reels Adhesive mounts to almost any clean flat surface Class 2 DC plug in connectors (3.5 x 1.3 mm) or screw terminal end-connectors available Dimmable with compatible components Rated to last up to 100,000 hours To be installed in accordance with NEC, using Class 2 12V DC power supply only Installation Instructions Plug-in System      12V DC 1. Clean desired mounting surface(s) and test Class 2 all products prior to installation Flex Interconnection In-line Control 2. Temporarily mount LED flex strips in desired location using scotch or painter’s tape 3. Connect LED strips using compatible interconnect cables, or tiger paw screw terminals with bulk 18-22 AWG wire 4. If using class 2 plug-in power supply connect first string of lights to controller, then connect to power 5. If using hardwire transformer connect first string of lights directly to transformer, then connect to high voltage wall switch (see transformer spec for more detail) 6. When satisfied with placement, *Individual strips over 200" should be powered from the center of the strip, individual strips should not exceed 400" in length. peel adhesive backing from strips and **Individual strips over 150" should be powered from the center of the strip, individual strips should not exceed 300" in length. *** Individual strips over 105” should be powered from the center of the strip, individual strips should not exceed 210” in length. press firmly to secure LEDs in place **** Individual strips over 100” should be powered from the center of the strip, individual strips should not exceed 200” in length. Inspired LED 1733 E. McKellips Rd. Suite #112 Tempe, AZ 85281 ● (480) 941-4286 ● www.inspiredled.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Inspired LED: UB-3200-CT UB-3200-TR UB-6500-CT UB-6500-TR UB-0465-CT UB-0465-TR NB-0465-CT NB-0465-TR NB0565-CT NB-0565-TR NB-0625-CT NB-0625-TR NB-3200-CT NB-3200-TR NB-6500-CT NB-6500-TR SB-0465CT SB-0465-TR SB-0565-CT SB-0565-TR SB-0625-CT SB-0625-TR SB-3200-CT SB-3200-TR SB-6500-CT SB6500-TR 12V-MB-PW-12M 12V-MB-CW-12M 12V-UB-PW-12M 12V-NB-PW-12M 12V-MB-WW-12M 12V-SB-PW12M 12V-DUB-WW-12M 12V-DUB-WW-01M 12V-DUB-CW-01M 12V-DUB-CW-12M 12V-SB-WW-01M 12V-UBCW-01M 12V-SB-PW-01M 12V-NB-PW-01M 12V-NB-CW-01M 12V-SB-WW-12M 12V-SB-CW-01M 12V-UB-WW12M 12V-NB-WW-01M 12V-UB-PW-01M 12V-UB-WW-01M 12V-NB-CW-12M 12V-UB-CW-12M 12V-SB-CW-12M 12V-NB-WW-12M
12V-DUB-CW-12M 价格&库存
很抱歉,暂时无法提供与“12V-DUB-CW-12M”相匹配的价格&库存,您可以联系我们找货
