GWCSSRM1.CC-LUMQ-5R8T-1
    AMSOSRAM(艾迈斯半导体)
    LEDOSLONWARMWHITE3000K1212
GWCSSRM1.CC-LUMQ-5R8T-1 数据手册
2014-02-15 OSLON Square® Datasheet Draft Version 0.0 GW CSSRM1.CC Higher performance. Lower thermal resistance. Extended range of driving conditions. This is the second generation OSLON Square. Higher performance. Lower thermal resistance. Extended range of driving conditions. This is the second generation OSLON Square. Features: Besondere Merkmale: • Package: SMT ceramic package with silicone resin and silicone lens • Viewing angle at 50 % IV: 120° • Color: 2700 K - 4000 K ( white ) • CRI: min. 90 ( typ. 92 ) • Luminous Flux: typ. 174 lm @ 3000 K, 85 °C • Luminous efficacy: typ. 86 lm/W @ 3000 K, 85 °C • Corrosion Robustness: Superior Corrosion Robustness • Lumen Maintenance: Testing according to IESNA LM-80 in progress • Gehäusetyp: SMT-Keramikgehäuse mit Silikonverguss und -linse • Abstrahlwinkel bei 50 % IV: 120° • Farbe: 2700 K - 4000 K ( weiß ) • CRI: min. 90 ( typ. 92 ) • Lichtstrom: typ. 174 lm @ 3000 K, 85 °C • Lichtausbeute: typ. 86 lm/W @ 3000 K, 85 °C • Korrosionsstabilität: Höchste Korrosionsbeständigkeit • Lichtstromerhaltung: Tests nach IESNA LM-80 im Gange Applications Anwendungen • Museum lighting • Shop lighting • Spot lights 2014-02-15 DRAFT – For Reference only. Subject to change. • Museumsbeleuchtung • Ladenbeleuchtung • Spot-Leuchten 1 Draft Version 0.0 GW CSSRM1.CC Ordering Information Bestellinformation Type: Color Temperature Luminous Flux Ordering Code Typ: Farbtemperatur Lichtstrom Bestellnummer 1) page 26 1) Seite 26 IF = 700 mA, TS = 85 °C [K] ΦV [lm] GW CSSRM1.CC-MPMR-5L7N-1 4000 180 ... 224 Q65111A5848 GW CSSRM1.CC-LUMQ-5O8Q-1 3500 164 ... 210 Q65111A5850 GW CSSRM1.CC-LUMQ-5R8T-1 3000 164 ... 210 Q65111A5849 GW CSSRM1.CC-LTMP-5U8X-1 2700 150 ... 194 Q65111A5851 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW CSSRM1.CC-LUMQ-5R8T-1 means that only one group LU, MP, MQ will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. GW CSSRM1.CC-LUMQ-5R8T-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity groups groups will not be orderable (see page 7). In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing unit. E. g. GW CSSRM1.CC-LUMQ-5R8T-1 means that only one forward voltage group K2,L1,L2,M1,M2 will be shippable. In order to ensure availability, single forward voltage groups will not be orderable (see page 5). Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW CSSRM1.CC-LUMQ-5R8T-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen LU, MP, MQ enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. GW CSSRM1.CC-LUMQ-5R8T-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 7). GW CSSRM1.CC-LUMQ-5R8T-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden. Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Durchlassspannungsgruppe geliefert. Z. B. GW CSSRM1.CC-LUMQ-5R8T-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer Verpackungseinheit ist nur eine der Durchlassspannungsgruppen K2,L1,L2,M1,M2 enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten, können einzelne Durchlassspannungsgruppen nicht direkt bestellt werden. 2014-02-15 DRAFT – For Reference only. Subject to change. 2 Draft Version 0.0 GW CSSRM1.CC Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 125 °C Storage temperature range Lagertemperatur Tstg -40 ... 125 °C Junction temperature absolute * Sperrschichttemperatur absolut * Tj, abs 150 °C Junction temperature Sperrschichttemperatur Tj 135 °C Forward current Durchlassstrom (TS = 85 °C) IF 200 ... 1800 mA Surge current Stoßstrom IFM 2000 mA Reverse current 2) page 26 Sperrstrom 2) Seite 26 IR 200 mA 8 kV VESD ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 3B) Note: * This is verified by testing 30 pieces. Pass criteria: No catastrophic failures allowed, luminous flux must be better than L70B50 after 1000 h. Anm: * Dieser Wert wird durch den Test von 30 Bauteilen abgesichert. Dabei dürfen keine Totalausfälle auftreten und der Lichtstrom muß nach 1000 h über L70B50 liegen. 2014-02-15 DRAFT – For Reference only. Subject to change. 3 Draft Version 0.0 GW CSSRM1.CC Characteristics (TS = 85 °C; IF = 700 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 3) page 26 Durchlassspannung 3) Seite 26 (min.) (typ.) (max.) VF VF VF 2.70 2.90 3.20 V V V Reverse voltage Sperrspannung (IR = 20 mA) (max.) VR 1.2 V Color reproduction index 4) page 26 Farbwiedergabe Index 4) Seite 26 (typ.) (min.) Ra Ra 92 90 - Real thermal resistance junction / solder point (typ.) (max.) Rth JS real Rth JS real 3 3.9 K/W K/W (typ.) (max.) Rth JS el Rth JS el 2.1 2.8 K/W K/W 5) page 26 Realer Wärmewiderstand Sperrschicht / Lötpad 5) Seite 26 "Electrical" thermal resistance junction / solder point 5) page 26 "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 5) Seite 26 (with efficiency η e = 29 %) Note: Individual forward voltage groups see next page Anm.: Durchlassspannungsgruppen siehe nächste Seite 2014-02-15 DRAFT – For Reference only. Subject to change. 4 Draft Version 0.0 GW CSSRM1.CC Brightness Groups Helligkeitsgruppen Group Luminous Flux Luminous Flux 1) page 26 1) page 26 1) Seite 26 Lichtstrom 1) Seite 26 Luminous Intensity 6) page 26 Lichtstärke 6) Seite 26 Gruppe Lichtstrom (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] LT 150 164 52 LU 164 180 57 MP 180 194 62 MQ 194 210 67 MR 210 224 72 Note: The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups cannot be ordered. Anm.: Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar. Forward Voltage Groups 3) page 26 Durchlassspannungsgruppen 3) Seite 26 Group Gruppe (min.) VF [V] (max.) VF [V] K2 2.70 2.80 L1 2.80 2.90 L2 2.90 3.00 M1 3.00 3.10 M2 3.10 3.20 2014-02-15 DRAFT – For Reference only. Subject to change. 5 Draft Version 0.0 GW CSSRM1.CC Chromaticity Coordinate Groups 7) page 26 Farbortgruppen 7) Seite 26 Cy 520 525 515 530 0.800 540 510 0.700 550 505 560 0.600 570 500 0.500 580 590 495 0.400 600 610 0.300 490 0.200 630 700 485 480 0.100 0.000 0.000 475 470 460 450 0.100 0.200 0.300 0.400 0.500 0.600 Cx 0.700 Coordinates in reference to CIE 1931 (cx cy) Cy 0.450 2500 K 3000 K 0.430 3500 K 8S 8R 0.410 8Q 4000 K 8O 7P 7N 0.390 6N 7L 0.370 0.350 45 0.330 0.330 00 00 00 40 5J 5I 5H 50 5K 6I 6H 5M 6K 5L 6J 5S 5R 5Q 5P 30 5T 8U 8V 7U 7V 8W 7W 8X 7X 6X 6W 6U 6V 5X 5W 5U 5V 27 0 0 K 00 K 5N 5O 6L 7I 7H 6M 7K 7J 6P 6O 6T 6S 6R 6Q 7O 7M 4500 K 5000 K 7Q 7T 7S 7R 8P neutral white 8T 3 50 0K warm white K K K 0.350 0.370 0.390 0.410 0.430 Coordinates in reference to CIE 1931 (cx cy) 2014-02-15 DRAFT – For Reference only. Subject to change. 6 0.450 0.470 0.490 0.510 Cx Draft Version 0.0 GW CSSRM1.CC Color Chromaticity Groups 7) page 26 Farbortgruppen 7) Seite 26 Group Gruppe 5L 6L 7L 5M 6M 7M 5N Cx Cy 0.3670 0.3578 0.3692 0.3677 0.3746 0.3624 Group Gruppe 5Q Cx Cy 0.4061 0.3773 0.4095 0.3858 0.4147 0.3814 0.4185 0.3902 0.4095 0.3858 0.3775 0.4130 0.3726 0.4185 0.3799 0.3828 0.3714 0.3775 0.3736 0.3874 0.3799 0.3828 0.3773 0.3726 0.3692 0.3677 0.3714 0.3773 6Q 7Q Group Gruppe 6U Cx Cy 0.4420 0.3985 0.4468 0.4077 0.4477 0.3998 0.4526 0.4090 0.4468 0.4077 0.3944 0.4515 0.4168 0.3902 0.4526 0.4090 0.4223 0.3990 0.4576 0.4183 0.4130 0.3944 0.4515 0.4168 0.4164 0.4029 0.4562 0.4260 0.4223 0.3990 0.4576 0.4183 0.4625 0.4275 0.4428 0.3906 7U 8U 0.4261 0.4077 0.4164 0.4029 0.3726 0.4198 0.4115 0.4477 0.3998 0.3670 0.4261 0.4077 0.4483 0.3919 0.3853 0.3776 0.4299 0.4165 0.4534 0.4011 0.3773 0.3726 0.4147 0.3814 0.4477 0.3998 0.3799 0.3828 0.4185 0.3902 0.4526 0.4090 0.3853 0.3776 0.4222 0.3840 0.4534 0.4011 0.4585 0.4104 0.4526 0.4090 0.3826 0.3931 0.3746 0.3624 0.3773 0.3822 8Q 5R 5V 6V 0.4263 0.3929 0.4185 0.3902 0.3931 0.4223 0.3990 0.4576 0.4183 0.3882 0.4263 0.3929 0.4585 0.4104 0.3916 0.3987 0.4305 0.4019 0.4636 0.4197 0.3822 0.3670 0.4223 0.3990 0.4576 0.4183 0.3853 0.3776 0.4261 0.4077 0.4625 0.4275 0.3898 0.3716 0.4305 0.4019 0.4636 0.4197 0.3934 0.3825 0.4346 0.4108 0.4688 0.4290 0.3885 0.3882 0.3799 0.3828 0.3826 0.3885 6R 7R 2014-02-15 DRAFT – For Reference only. Subject to change. 7 7V 8V Draft Version 0.0 Group Gruppe 6N 7N 5O 6O 7O 8O 5P 6P GW CSSRM1.CC Cx Cy 0.3853 0.3776 0.3885 0.3882 0.3934 0.3825 Group Gruppe 8R Cx Cy 0.4261 0.4077 0.4299 0.4165 0.4346 0.4108 0.4387 0.4197 0.4222 0.3840 0.3987 0.4263 0.3935 0.4298 0.4044 0.3970 0.3935 0.3885 0.3882 0.3916 0.3970 0.4006 5S 6S Group Gruppe 5W Cx Cy 0.4483 0.3919 0.4534 0.4011 0.4538 0.3931 0.4591 0.4025 0.4534 0.4011 0.3929 0.4585 0.4104 0.3867 0.4591 0.4025 0.4342 0.3957 0.4644 0.4118 6W 0.3890 0.3690 0.4263 0.3929 0.4585 0.4104 0.3916 0.3772 0.4305 0.4019 0.4636 0.4197 0.3975 0.3731 0.4342 0.3957 0.4644 0.4118 0.4006 0.3815 0.3916 0.3772 0.3943 0.4006 0.4036 0.4386 0.4048 0.4305 0.4019 0.3853 0.4346 0.3815 0.4386 0.3898 7S 8S 7W 0.4697 0.4211 0.4636 0.4197 0.4108 0.4688 0.4290 0.4048 0.4697 0.4211 0.4430 0.4138 0.4750 0.4304 8W 0.3943 0.3853 0.4346 0.4108 0.4538 0.3931 0.3970 0.3934 0.4387 0.4197 0.4591 0.4025 0.4036 0.3898 0.4430 0.4138 0.4593 0.3944 0.4067 0.3982 0.3970 0.3934 0.3997 0.4067 0.4474 0.4228 0.4298 0.3867 0.4015 0.4342 0.3982 0.4373 0.4097 0.4065 0.3975 0.3731 0.4006 0.3815 0.4061 0.3773 5T 6T 0.4648 0.4038 0.4591 0.4025 0.3957 0.4644 0.4118 0.3893 0.4648 0.4038 0.4420 0.3985 0.4703 0.4132 0.4342 0.3957 0.4644 0.4118 0.4386 0.4048 0.4697 0.4211 0.4420 0.3985 0.4703 0.4132 0.4468 0.4077 0.4386 0.4048 0.3898 0.4430 0.3858 0.4468 0.3944 0.4515 0.4095 0.3858 0.4006 0.3815 0.4036 0.4095 0.4130 7T 2014-02-15 DRAFT – For Reference only. Subject to change. 5X 8 6X 7X 0.4758 0.4225 0.4697 0.4211 0.4138 0.4750 0.4304 0.4077 0.4758 0.4225 0.4168 0.4813 0.4319 8X Draft Version 0.0 Group Gruppe 7P 8P GW CSSRM1.CC Cx Cy 0.4036 0.3898 0.4067 0.3982 0.4130 0.3944 0.4164 0.4029 0.4067 0.3982 0.4097 0.4164 0.4198 Group Gruppe 8T Cx Cy 0.4430 0.4138 0.4474 0.4228 0.4515 0.4168 0.4562 0.4260 0.4373 0.3893 0.4065 0.4420 0.3985 0.4029 0.4428 0.3906 0.4115 0.4477 0.3998 5U 2014-02-15 DRAFT – For Reference only. Subject to change. 9 Group Gruppe Cx Cy Draft Version 0.0 GW CSSRM1.CC Group Name on Label Gruppenbezeichnung auf Etikett Example: LU-5R-K2 Beispiel: LU-5R-K2 Brightness Helligkeit Chromaticity Coordinate Farbort Forward Voltage Durchlassspannung LU 5R K2 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2014-02-15 DRAFT – For Reference only. Subject to change. 10 Draft Version 0.0 GW CSSRM1.CC Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 26 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 26 Φrel = f (λ); TS = 85 °C; IF = 700 mA Irel GW CSSRM1.CC 1.0 : Vλ : white 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 6) page 26 Abstrahlcharakteristik 6) Seite 26 Irel = f (ϕ); TS = 85 °C GW CSSRM1.CC ϕ [°] -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° -20° -30° 90° 1.0 : 0° : 45° -40° 0.8 -50° 0.6 -60° 0.4 -70° 0.2 -80° -90° 0.0 -100° 2014-02-15 DRAFT – For Reference only. Subject to change. 11 Irel Draft Version 0.0 GW CSSRM1.CC Relative Luminous Flux 6) page 26 , 8) page 26 Relativer Lichtstrom 6) Seite 26 , 8) Seite 26 ΦV/ΦV (700 mA) = f(IF); TS = 85 °C Forward Current 6) page 26 Durchlassstrom 6) Seite 26 IF = f (VF); TS = 85 °C IF [mA] ΦV GW CSSRM1.CC 1500 1400 GW CSSRM1.CC 2.0 ΦV(700mA) : white 1200 : white 1.5 1000 1.0 800 600 0.5 400 VF [V] Chromaticity Coordinate Shift Farbortverschiebung 6) Seite 26 Cx, Cy = f(IF); TS = 85 °C GW CSSRM1.CC : Cx : Cy 0.43 0.42 0.41 15 00 12 00 0 0 0 10 00 80 60 40 20 0 0.40 IF [mA] 2014-02-15 DRAFT – For Reference only. Subject to change. 00 15 00 00 12 IF [mA] 6) page 26 Cx Cy 10 3.3 80 0 3.2 60 0 3.0 40 0 2.8 20 0 0.0 200 2.6 12 Draft Version 0.0 GW CSSRM1.CC Relative Luminous Flux 6) page 26 Relative Lichtstrom 6) Seite 26 ΦV/ΦV (85 °C) = f(Tj); IF = 700 mA Relative Forward Voltage 6) page 26 Relative Vorwärtsspannung 6) Seite 26 ΔVF = VF - VF(85 °C) = f(Tj); IF = 700 mA ΔVF [V] Φv GW CSSRM1.CC 0.3 : white 0.2 1.0 0.1 0.8 0.0 0.6 -0.1 0.4 -0.2 0.2 -0.3 -40 -20 0 20 40 60 80 0.0 -40 -20 100 120 Tj [°C] Chromaticity Coordinate Shift Farbortverschiebung 6) Seite 26 Cx, Cy = f(Tj); IF = 700 mA GW CSSRM1.CC 0.430 0.425 0.420 0.415 0.410 0.405 -40 -20 : Cx : Cy 0 20 40 60 80 100 120 Tj [°C] 2014-02-15 DRAFT – For Reference only. Subject to change. 0 20 40 60 80 100 120 Tj [°C] 6) page 26 Cx Cy 0.400 GW CSSRM1.CC 1.2 Φv(85°C) : white 13 Draft Version 0.0 GW CSSRM1.CC Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [mA] GW CSSRM1.CC 1900 1800 1700 1600 1500 1400 1300 1200 1100 1000 900 800 700 600 500 400 300 200 Do not use below 200 mA 100 0 0 20 40 60 80 100 120 Ts [°C] 2014-02-15 DRAFT – For Reference only. Subject to change. 14 Draft Version 0.0 GW CSSRM1.CC Package Outline 9) page 26 Maßzeichnung 9) Seite 26 Approximate Weight: 29 mg Gewicht: 29 mg Mark: Cathode Markierung: Kathode ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschaltet ist. Corrosion robustness: Test conditions: 40 °C / 90 % rh / 15 ppm H2S / 336 h = Stricter than IEC 60068-2-43 (H 2S) [25°C / 75 % rh / 10 ppm H 2S / 21 days] = Regarding relevant gas (H2S) stricter than EN 60068-2-60 (method 4) [25 °C / 75 % rh / 200 ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days] 2014-02-15 DRAFT – For Reference only. Subject to change. 15 Draft Version 0.0 GW CSSRM1.CC Korrosionsfestigkeit: 2014-02-15 DRAFT – For Reference only. Subject to change. Test Kondition: 40°C / 90 % rh / 15 ppm H 2S / 336 h = Besser als IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 Tage] = Bezogen auf das Gas (H 2S) besser als EN 60068-2-60 (method 4) [25°C / 75 % rh / 200ppb SO2, 200ppb NO2,10ppb Cl2 / 21 Tage] 16 Draft Version 0.0 GW CSSRM1.CC Recommended Solder Pad 9) page 26 Empfohlenes Lötpaddesign 9) Seite 26 foot print Cu area 2014-02-15 DRAFT – For Reference only. Subject to change. Reflow soldering Reflow-Löten solder resist 17 solder stencil Draft Version 0.0 GW CSSRM1.CC Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. For further information please refer to our Application Note “Handling and Processing Details for Ceramic LEDs“. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Weitere Informationen finden Sie in der Applikationsschrift „Handling and Processing Details for Ceramic LEDs“. 2014-02-15 DRAFT – For Reference only. Subject to change. 18 Draft Version 0.0 GW CSSRM1.CC Reflow Soldering Profile Reflow-Lötprofil Preconditioning: JEDEC Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2014-02-15 DRAFT – For Reference only. Subject to change. °C 19 s Draft Version 0.0 GW CSSRM1.CC Taping 9) page 26 Gurtung 9) Seite 26 2014-02-15 DRAFT – For Reference only. Subject to change. 20 Draft Version 0.0 GW CSSRM1.CC Tape and Reel Gurtverpackung 12 mm tape with 600 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions in mm (inch) Tape dim ensions in m m ( inch) W P0 P1 P2 D0 E F 12 +0.3/-0.1 4 ± 0.1 (0.157 ± 0.004) 4 ± 0.1 (0.157 ± 0.004) or 8 ± 0.1 (0.315 ± 0.004) 2 ± 0.05 (0.079 ± 0.002) 1.5 ± 0.1 (0.059 + 0.004) 1.75 ± 0.1 (0.069 ± 0.004) 5.5 ± 0.05 (0.217 ± 0.002) Reel dimensions in mm (inch) Reel dim ensions in m m ( inch) A W Nmin W1 W2max 180 (7) 12 (0.472) 60 (2.362) 12.4 + 2 (0.488 + 0.079) 18.4 (0.724) 2014-02-15 DRAFT – For Reference only. Subject to change. 21 Draft Version 0.0 GW CSSRM1.CC Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) EX AM PL E OSRAM Opto po BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors tors ors r RoHS Compliant (6P) BATCH NO: NO:: 1234567 1234567890 234 4 7890 8 890 ML Temp ST X XXX °C X (1T) LOT NO: 1234567890 (9D) ((9D 9D D) D/C: D) D/C D : 123 D/ 1234 23 234 34 RXX Pack: R RX XX DEMY Y XXX XXX X_X123_1234.1234 X_X123_1 12 _123 123 12 234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X XX-XX XX XXXX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print L VE LE see labe ). (RH idity ˚C < 40 . RH hum 0% e tive ˚C/6 red kag rela 30 _ pac < infra of 90% to ak < ns ed (pe or ditio and ject ˚C, sing 5 con ± N s IVE S Otain TOR SIT UC TI SEN ND U Econ As bag UR ICO CThiIST SEM 1. sub ces be pro ory Barcode label l k, code blan If bar ˚C e). cod date r rs rs rs Hou rs Hou 72 Hou 48 Hou 24 6 time time r time 23 will at l with fact r ent˚C). MO Floo . time TO at at r Floo l ths that tica d ival ure OP Floo 4 if: rea w Floo labe mon iden 5 ced equ el ices g, n e 5a is el belo or 24 pro Lev 6 dev : ntin el whe cod e , w, e Lev el see e bag Lev l date mou bak ned stur e Lev reflo bar re> 10% led stur e time sea for ope e Moi r see stur k, is . Moi sea is has k, stur befo d 033 Moi in Floo RH blan Moi or-p blan in bag Car ing, r TD(if life r . If with r lf 10%bak J-S thisvapp. Yea _ eks rs < r w, met cato 1 Yea tem d, She nted at uire not > y 1 WeHou DEC Afte Indi 4 uire reflo is bod Mou red req /JE time 168 req : 2b r a) Sto ices idity time is IPC r or time b) ned Floo r Hum ing ce time Dev 2a r Floo a) ope 3. b) bakren Floo 1 l date Floo If 2 refe time el 4. 2a el sea Lev 3 el and e Lev el Bag e e Lev stur e Lev Dat stur e Moi stur Moi stur Moi Moi O S R A M 2. Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2014-02-15 DRAFT – For Reference only. Subject to change. 22 Draft Version 0.0 GW CSSRM1.CC Transportation Packing and Materials Kartonverpackung und Materialien 8 Q- 1 R1 lti LS TO Y T6 PL 76 1+ Mu P- 44 (9D ) 4 20 23 3G (6P ) LO T 00 D/C : 01 998 NO : 12 O 021 H1 210 BA TC H Se SR mi AM co nd O uc pt to o rs NO : ). 5 14 2 110 0 (Q) QT Y: see labe N (1T ) O NO : TI PR OD U (X) A (G) l k, C GR OU P: Muster L VE LE code (RH blan If y bar . idit RH hum e 60% tive d ˚C/ kag rela are 30 E S s _ infr pac < OR of 90% to ak tainITIV urs CT < or e). ted (pe urs ons Ho con NS g urs SE DU Ho and jec ˚C, diti cod 72 sin Ho urs 5 e bag E ON 48 ˚C sub e Ho con ± ces is UR 24 6 dat e MIC 40 be tim ˚C h e ThISTSE pro < tory tim . or t wit 23 tim e at t will or fac . MO Flo al len ˚C) s tim TO at or at Flo d or ure iva el nth s tha OP ntic Flo 4 if: rea , Flo lab ow mo ice equ ced ide 5 el e 5a is ingen el or bel 24 pro 6 Lev e dev, : el e cod , unt wh Lev el re ow see bag Lev l dat mo re bak e bar ned Lev refl istu 10% re tim for sea istu ore> re Mo see 3 istu is or . sea is Mo bef nk, istu pha nk, Flo , rd -03 Mo in RH bla Mo orbag ingCa bla hin TD life (if ar If wit t. vapp. 10%baktor J-S this elf Ye ar eks , _ < ed ica med, C 1 urs Ye erow tem Sh at uire not > y 1 WeHo DE unt Aft Ind 1. e 4 uire refl red req 2. bod Mo e ity is /JE tim 168 req : e 2b a) Sto es tim or mid is IPC or tim e vic ned b) or Hu Flo tim ing ce or e De 2a Flo a) ope or 3. b) bakren Flo e 1 l dat Flo If 2 el refe tim 2a 4. el sea 3 Lev g el and Lev el re Ba te Lev re Lev istu Da re istu re Mo istu Mo istu Mo Mo DE 8 Q- 1 R1 lti LS TO Y T6 PL 76 1+ PP: OU GR (G) : 01 O SR AM rs D/C to ) uc (9D 00 nd 21 00 21 99 8 : 4 20 NO 23 QT (Q) O SR m A ico M H H1 TC BA 3G ) : 12 (6P (X) PR OD NO : (1T ) 11 00 LO T 14 2 NO 5 Se Y: O pt o 44 Mu MY ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Te 2a 220 mp 3 240 ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: ope se Muster led DE MY Barcode label ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Tem 2a 220 3 240 p ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: Barcode label Packing Sealing label OHA02044 Dimensions of transportation box in mm (inch): Width / Breite Length / Länge Height / Höhe 195 ± 5 (7.677 ± 0.1968) 195 ± 5 (7.677 ± 0.1968) 30 ± 5 (1.181 ± 0.196) 2014-02-15 DRAFT – For Reference only. Subject to change. 23 Draft Version 0.0 GW CSSRM1.CC Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Moderate risk (Expositionsdauer 0,25 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED contain, among other substances, goldplated and Ag-filled materials. In spite of the improved corrosion stability of this LED, it can be affected by environments that contain very high concentrations of aggressive substances. Therefore, we recommend avoiding aggressive atmospheres during storage, production and use. Einzelkomponenten dieser LED enthalten u.a. goldbeschichtete und Ag-gefüllte Materialien. Trotz der verbesserten Korrosionsstabilität dieser LED können Einzelkomponenten durch sehr hohe Konzentration aggressiver Substanzen angegriffen werden. Aus diesem Grund wird empfohlen, aggressive Umgebungen während der Lagerung, Produktion und im Betrieb zu vermeiden. For further application related informations please visit www.osram-os.com/appnotes Für weitere applikationsspezifische Informationen besuchen Sie bitte www.osram-os.com/appnotes Change management for this component is aligned with the requirements of the lighting market. Change management for this component is aligned with the requirements of the lighting market. 2014-02-15 DRAFT – For Reference only. Subject to change. 24 Draft Version 0.0 GW CSSRM1.CC Disclaimer Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time. OSRAM OS übernimmt keine wie auch immer geartete Haftung für die Nutzung dieses Dokuments und seines Inhaltes durch den Empfänger, insbesondere nicht für irgendwelche Design-Aktivitäten, die auf dieser vorläufigen Entwurfsversion basieren. OSRAM OS behält sich beispielsweise auch vor, jederzeit die Weiter- und Fertigentwicklung des zugrundeliegenden Designs einseitig einzustellen. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 2014-02-15 DRAFT – For Reference only. Subject to change. 25 Draft Version 0.0 GW CSSRM1.CC Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 8 % and an expanded uncertainty of ± 11 % (acc. to GUM with a coverage factor of k = 3). 1) Helligkeit: Helligkeitswerte werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 8 % und einer erweiterten Messunsicherheit von ± 11 % gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 2) Reverse Operation: A minimum of 10 hours of reverse operation is permisable in total. 2) Betrieb in Sperrrichtung: Eine Gesamtbetriebszeit von wenigstens 10 Stunden in Sperrrichtung ist gewährleistet. 3) Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an internal reproducibility of ± 0.05 V and an expanded uncertainty of ± 0.1 V (acc. to GUM with a coverage factor of k = 3). 3) Durchlassspannung: Vorwärtsspannungen werden während eines Strompulses einer typischen Dauer von 8 ms, mit einer internen Reproduzierbarkeit von ± 0,05 V und einer erweiterten Messunsicherheit von ± 0,1 V gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 4) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 2 and an expanded uncertainty of ± 3 (acc. to GUM with a coverage factor of k = 3). 4) Farbwiedergabe Index: Werte des Farbwiedergabe Index (CRI-RA) werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 2 und einer erweiterten Messunsicherheit von ± 3 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 5) Thermal Resistance: Rth max is based on statistic values (6σ). 5) Wärmewiderstand: Rth statistischen Werten (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 7) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 0.005 and an expanded uncertainty of ± 0.01 (acc. to GUM with a coverage factor of k = 3). 7) Farbortgruppen: Farbkoordinaten werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 0,005 und einer erweiterten Messunsicherheit von ± 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 8) Relative Brightness Curve: In the range where the line of the graph is broken, you must expect higher brightness differences between single LEDs within one packing unit. 8) Relative Helligkeitskurve: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Helligkeitsunterschieden zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 9) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. 2014-02-15 DRAFT – For Reference only. Subject to change. 26 max basiert auf Draft Version 0.0 GW CSSRM1.CC Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2014-02-15 DRAFT – For Reference only. Subject to change. 27
GWCSSRM1.CC-LUMQ-5R8T-1 价格&库存
很抱歉,暂时无法提供与“GWCSSRM1.CC-LUMQ-5R8T-1”相匹配的价格&库存,您可以联系我们找货
