LSS_104_GTP
LSS_104_GTP
    VCC
    3MMSEALEDLITEPIPELENSASSY
LSS_104_GTP 数据手册
8 D 5 6 7 4 MOISTURE SEAL C 2 3 NOTES: 1. ROHS COMPLIANT 2. MATERIAL: LIGHTPIPE - ACRYLIC (CLEAR OPTICAL GRADE), UL 94-HB LENS - POLYCARBONATE, UL 94-V2 SEAL - EPDM RETAINING RING - POLYPROPYLENE (BLACK) 3. MOUNTING: MOUNTS IN A .171" .002 [ 4.34mm .05] PANEL HOLE ON .250" [6.35mm] CENTER 4. PANEL HOLE SHALL BE DEBURRED, BUT NOT CHAMFERED 5. PANEL THICKNESS: .031" [.8mm] TO .094" [2.39mm] 6. ASSEMBLY: A.) INSERT LITEPIPE THROUGH PANEL HOLE B.) PRESS ON RETAINING RING TO SECURE UNIT TO PANEL C.) SLIDE PCB INTO POSITION ALIGNING LED WITH END OF LITEPIPE UNIT 7. U.S AND FOREIGN PATENTS ISSUED 1 REVISIONS ECN # REV. DESCRIPTION DATE INITIALS CHK'D 391 000 INITIAL RELEASE 2/20/12 KH AZ D .170in 4.32mm RETAINING RING .125in 3.16mm .193in 4.91mm C .240in 6.10mm B B .080in 2.03mm .XXX ORDERING CODE: LSS XXX XXX LITEPIPE A LENS XXX = LENGTH XXX = COLOR 024 .240" (6.10mm) RTP RED TRANSPARENT 044 .440" (11.18mm) ATP AMBER TRANSPARENT 064 .640" (16.26mm) 084 .840" (21.34mm) 104 1.04" (26.4mm) 124 1.24" (31.5mm) CUSTOM LENGTHS AVAILABLE UPON REQUEST 8 GTP BTP GREEN TRANSPARENT BLUE TRANSPARENT YTP YELLOW TRANSPARENT CTP 7 LENS LITEPIPE LED DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED DISPLAY PANEL GAP .050" PCB RNG 132 RETAINING RING INCHES .020 .010 .005 ANGLE 1' MM .508 .254 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX DATE KHOWARD 2/20/12 CHECKED AZANELLI 3/6/12 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: MATERIAL ASSY, 3MM MOISTURE SEALED LITEPIPE THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 5 APPROVAL DRAWN SEE NOTES ASSEMBLY CLEAR TRANSPARENT 6 .X .XX .XXX 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 8:1 DO NOT SCALE DRAWING 2 000 LSS XXX XXX SHEET 1 OF 1 1 A
LSS_104_GTP 价格&库存
很抱歉,暂时无法提供与“LSS_104_GTP”相匹配的价格&库存,您可以联系我们找货
