FLX_444_ATP_02
FLX_444_ATP_02
    VCC
    LITEPIPE FLEX AMBER TRANSP 2"
FLX_444_ATP_02 数据手册
8 7 5 6 4 2 3 1. 2. D 3. 4. 5. 6. 7. 8. 1 REVISIONS NOTES: ROHS COMPLIANT MATERIALS: FIBER OPTIC: 1.5MM OPTICAL CORE, 2.2MM POLYETHYLENE CABLE JACKET LENS MOUNT: OPTICAL GRADE ACRYLIC LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2 FOR THR 5 22 - NYLON 66, UL RATING 94-HB LENS: POLYCARBONATE UL RATING 94-V2 LENS WASHER: FH STEEL, NICKLE PLATE LENS RETAINING RING: THERMOPLASTIC UL RATING 94-V0 LENS SEAL: EPDM OPTICAL CORE ENDS POLISHED TO 10 MICRONS MOUNTS THROUGH FRONT OF PANEL. SECURED BY RETAINING RING LENSES MOUNT THROUGH A 5/16" (7.94mm) HOLE ON 1/2" (6.35mm) CENTERS PANEL THICKNESS 1/32" (0.79mm) TO 1/8" (3.18mm) FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS WITH OUTPUT POWER GREATER THAN 100mcd U.S. AND FOREIGN PAT. ISSUED LITE PIPE ASSEMBLY ORDERING CODE (EXAMPLE): FLX LENS TYPE CODE CMC 441, STANDARD FRESNEL CMS 442, MOISTURE-SEALED FRESNEL CMC 443, PLAIN LENS CMS 444, MOISTURE-SEALED PLAIN END 441 442 443 444 MOUNTING OPTIONS (ORDER SEPARATELY) REV. DESCRIPTION DATE INITIALS CHK'D - 001 INITIAL RELEASE 7/8/09 SMU AZ - 002 DWG FORMAT UPDATE 8/2/10 KH AZ - 003 REVISED PER ECR 092810AA01 10/4/10 KH AZ 396 004 REVISED PER ECR 011812KH01 1/20/12 KH AZ D 44X XXX XX LENS COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT RTP ATP GTP BTP YTP CTP CMS 442 & CMS 444; INCLUDES LENS W/SEAL (MEETS NEMA 6P RATING), CLW 441 LOCKWASHER, AND RTN 441 RETAINING RING C ECN # FIBER LENGTH CODE 02 2.0" 04 4.0" 6.0" 06 08 8.0" 12 12.0" CUSTOM LENGTHS AVAILABLE UPON REQUESTS CMC 441 & CMC 443; INCLUDES LENS, CLW 441 LOCKWASHER, AND RTN 441 RETAINING RING C SMD 22 FIBER OPTIC LENS MOUNT LENS B B .06in±.02 1.52mm±0.51 THR 22 FIBER OPTIC LENGTH XX .25 DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED A .X .XX .XXX THR 5 22 63 INCHES .020 .010 .005 ANGLE 1' MM .508 .254 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX APPROVAL DATE DRAWN KHOWARD 8/2/10 CHECKED AZANELLI 8/2/10 OPTOELECTRONICS 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com TITLE: MATERIAL FLX 44X FLEXFIRE FLEXIBLE LITEPIPE SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 2:1 DO NOT SCALE DRAWING 2 FLX 44X XXX XX 004 SHEET 1 OF 1 1 A
FLX_444_ATP_02 价格&库存
很抱歉,暂时无法提供与“FLX_444_ATP_02”相匹配的价格&库存,您可以联系我们找货
