C13253_TINA2-R-CLIP16 数据手册
PRODUCT
DATASHEET
TINA2-R-CLIP16
Mini reflector with ~60° wide beam and clip
installation
TECHNICAL SPECIFICATIONS:
Dimensions
Ø 16.1 mm
Height
10.1 mm
Fastening
clips
ROHS compliant
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
TINA2-R-CLIP16
Reflector
HRPC
clear
Finish
Coating
ORDERING INFORMATION:
Component
» Box size: 300 x 250 x 250 mm
Qty in box
MOQ
MPQ
300
50
Box weight (kg)
3.8
Last update: 11/01/2022
Subject to change without prior notice
Published: 16/11/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/12
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XB-D
FWHM / FWTM
73.0° / 135.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XB-H
FWHM / FWTM
81.0° / 151.0°
Efficiency
92 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XM-L
FWHM / FWTM
78.0° / 142.0°
Efficiency
88 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XM-L2
FWHM / FWTM
78.0° / 142.0°
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
3/12
PRODUCT
DATASHEET
LED
XP-E
FWHM / FWTM
74.0° / 138.0°
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E2
FWHM / FWTM
74.0° / 136.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
77.0° / 141.0°
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2
FWHM / FWTM
75.0° / 138.0°
Efficiency
89 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
4/12
PRODUCT
DATASHEET
LED
XT-E
FWHM / FWTM
71.0° / 133.0°
Efficiency
87 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON A
FWHM / FWTM
75.0° / 138.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON R
FWHM / FWTM
75.0° / 136.7°
Efficiency
89 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rebel
FWHM / FWTM
72.0° / 131.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
5/12
PRODUCT
DATASHEET
LED
LUXEON Rebel ES
FWHM / FWTM
74.0° / 137.0°
Efficiency
89 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON T
FWHM / FWTM
75.0° / 137.0°
Efficiency
89 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
81.0° / 151.0°
Efficiency
90 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxx19A
FWHM / FWTM
72.0° / 132.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
6/12
PRODUCT
DATASHEET
LED
NF2x757A
FWHM / FWTM
72.0° / 135.0°
Efficiency
92 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19A
FWHM / FWTM
74.0° / 136.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
74.0° / 139.0°
Efficiency
89 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
Duris S5 (2 chip)
FWHM / FWTM
76.0° / 144.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
7/12
PRODUCT
DATASHEET
LED
OSLON Square EC
FWHM / FWTM
75.0° / 138.0°
Efficiency
91 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
75.0° / 140.0°
Efficiency
88 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 80
FWHM / FWTM
71.0° / 108.0°
Efficiency
91 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y15
FWHM / FWTM
72.0° / 137.0°
Efficiency
90 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
8/12
PRODUCT
DATASHEET
LED
Z8Y19
FWHM / FWTM
71.0° / 136.0°
Efficiency
89 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
9/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
XP-G2 HE
FWHM / FWTM
73.0° / 120.0°
Efficiency
86 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 3030
FWHM / FWTM
74.0° / 134.0°
Efficiency
86 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Black
FWHM / FWTM
71.0° / 125.0°
Efficiency
80 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
Protective plate, glass
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
65.0° / 116.0°
Efficiency
94 %
Peak intensity
0.7 cd/lm
LEDs/each optic
1
Light colour
White
10/12
PRODUCT
DATASHEET
LED
LH351B
FWHM / FWTM
78.0° / 138.0°
Efficiency
87 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351C
FWHM / FWTM
79.0° / 140.0°
Efficiency
86 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
11/12
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
12/12
C13253_TINA2-R-CLIP16 价格&库存
很抱歉,暂时无法提供与“C13253_TINA2-R-CLIP16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+60.90727
- 16+15.68691
- 37+14.72291
