CA11959_LAURA-RS-PIN
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM SQ 13.1MM
CA11959_LAURA-RS-PIN 数据手册
PRODUCT DATASHEET CA11959_LAURA-RS-PIN LAURA-RS-PIN ~8° spot beam optimized for CREE XP-E. Assembly with white holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions 21.6 x 21.6 mm Height 13.1 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LAURA-RS Single lens PMMA clear LAURA-PIN-XP-HLD-WHT Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11959_LAURA-RS-PIN » Box size: Single lens Qty in box MOQ MPQ 1440 360 180 Box weight (kg) 7.6 Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (MEASURED): LED XP-E FWHM / FWTM 8.0° / 16.0° Efficiency 93 % Peak intensity 33.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 11.0° Efficiency 93 % LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 7.0° / 16.0° Efficiency 93 % Peak intensity 34 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 11.0° / 21.0° Efficiency 92 % Peak intensity 18.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (MEASURED): LED NCSxx19B FWHM / FWTM 10.0° / 19.0° Efficiency 91 % Peak intensity 27.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 9.0° / 18.0° Efficiency 93 % Peak intensity 20 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 7.0° / 14.0° Efficiency 92 % Peak intensity 42 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4725S FWHM / FWTM 10.0° / 21.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (MEASURED): LED Z5 FWHM / FWTM 7.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED XD16 FWHM / FWTM 8.6° / 18.0° Efficiency 94 % Peak intensity 26.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 8.0° / 14.0° Efficiency 95 % Peak intensity 44 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-P FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 50.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 12.0° / 23.0° Efficiency 92 % Peak intensity 16.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED LUXEON IR Domed 150 FWHM / FWTM 9.0° / 18.0° Efficiency 0% LEDs/each optic 1 Light colour White Required components: LED LUXEON IR Domed 60 FWHM / FWTM 9.2° / 20.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED LUXEON IR Domed 90 FWHM / FWTM 9.0° / 18.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 8.0° / 15.0° Efficiency 95 % Peak intensity 39.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED NV4WB35AM FWHM / FWTM 16.0° / 30.0° Efficiency 96 % Peak intensity 9.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 10.0° / 21.0° Efficiency 94 % Peak intensity 21.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 16.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED KW CULPM1.TG FWHM / FWTM 8.0° / 16.0° Efficiency 96 % Peak intensity 37.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ C 2424 FWHM / FWTM 8.0° / 18.0° Efficiency 96 % Peak intensity 29.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 14.0° / 27.0° Efficiency 94 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 10.0° / 22.0° Efficiency 96 % Peak intensity 18.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 8.0° / 16.0° Efficiency 95 % Peak intensity 40.5 cd/lm LEDs/each optic 1 Light colour Red Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 9.5° / 19.0° Efficiency 94 % Peak intensity 24.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715AS FWHM / FWTM 10.0° / 19.0° Efficiency 94 % Peak intensity 23.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715S FWHM / FWTM 9.5° Efficiency % LEDs/each optic 1 Light colour White Required components: LED SFH 4770S FWHM / FWTM 10.0° / 23.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN PHOTOMETRIC DATA (SIMULATED): LED LM301B FWHM / FWTM 9.0° / 19.0° Efficiency 94 % Peak intensity 24.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CA11959_LAURA-RS-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/05/2018 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CA11959_LAURA-RS-PIN 价格&库存
很抱歉,暂时无法提供与“CA11959_LAURA-RS-PIN”相匹配的价格&库存,您可以联系我们找货
