C13937_STRADA-2X2-C-STP
    LEDIL(芬兰)
    LENS4POS50X50MMSQ6.27MMH
C13937_STRADA-2X2-C-STP 数据手册
PRODUCT DATASHEET C13937_STRADA-2X2-C-STP STRADA-2X2-C-STP Beam for area and street lighting such as parks and pedestrian walkways TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 50.0 x 50.0 mm 5.3 mm pin, screw yes MATERIAL SPECIFICATIONS: Component Type Material Colour STRADA-2X2-C-STP Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C13937_STRADA-2X2-C-STP » Box size: 476 x 273 x 292 mm Qty in box 800 MOQ MPQ 160 160 Box weight (kg) 5.5 Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP See also our general installation guide: www.ledil.com/installation_guide Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED Bridgelux SMD 5050 FWHM / FWTM 131.0° / 156.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX XTP 2x4 xxx LS G5 FWHM / FWTM 138.0° / 161.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX XTP 2x6 xxx LS G5 FWHM / FWTM 138.0° / 160.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L3 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 137.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 141.0° / 164.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 139.0° / 166.0° Efficiency 92 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 136.0° / 162.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED XP-L2 FWHM / FWTM 139.0° / 166.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 121.0° / 146.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 133.0° / 156.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 133.0° / 156.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED LUXEON V FWHM / FWTM 136.0° / 166.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SST-10-B130 FWHM / FWTM 127.0° / 154.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour Deep Red Required components: LED RecLED 122x50mm 1900lm 730 2x4 Opt G1 FWHM / FWTM Asymmetric Efficiency 98 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 131.0° / 155.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED NVSW319B FWHM / FWTM 139.0° / 162.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 138.0° / 165.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED PrevaLED Brick HP 2x8 FWHM / FWTM 137.0° / 157.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 131.0° / 154.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 137.0° / 157.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 130.0° / 161.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DA G4 FWHM / FWTM 136.0° / 161.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DA G4+ FWHM / FWTM 130.0° / 157.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED Fortimo FastFlex LED 2x8 DA G5 FWHM / FWTM 124.0° / 151.0° Efficiency 98 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x8 DAX G4 FWHM / FWTM 141.0° / 164.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RC12 Z (LH181B) FWHM / FWTM 118.0° / 145.0° Efficiency 99 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RH12 Z (LH351C) FWHM / FWTM 133.0° / 160.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED HiLOM RH16 (LH351C) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM12 Z (LH502C) FWHM / FWTM 121.0° / 150.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM16 Z (LH502C) FWHM / FWTM 122.0° / 152.0° Efficiency 99 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM8 Z (LH502C) FWHM / FWTM 123.0° / 153.0° Efficiency 98 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED LH351B FWHM / FWTM 134.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 127.0° / 153.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH508A FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LED-Pa-L15c2W11c2-xxx-C050-01 FWHM / FWTM 124.0° / 148.0° Efficiency 98 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED Z5M3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M4 FWHM / FWTM 120.0° / 142.0° Efficiency 98 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 117.0° / 146.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 136.0° / 163.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED TL1L4 FWHM / FWTM 119.0° / 143.0° Efficiency 92 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x4 2000lm HP EXC2 OTD FWHM / FWTM 137.0° / 159.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x8 4000lm HP EXC2 OTD FWHM / FWTM 137.0° / 159.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x121mm 2000lm xxx EXC OTD FWHM / FWTM 129.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (MEASURED): LED RLE G1 49x133mm 2000lm xxx EXC OTD FWHM / FWTM 129.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x223mm 4000lm xxx EXC OTD FWHM / FWTM 129.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x245mm 4000lm xxx EXC OTD FWHM / FWTM 129.0° / 158.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED XP-G2 HE FWHM / FWTM 130.0° / 146.0° Efficiency 95 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 128.0° / 148.0° Efficiency 84 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 3030 2D (Round LES) FWHM / FWTM 119.0° / 141.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 2D (Square LES) FWHM / FWTM 121.0° / 143.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED LUXEON 5050 HE FWHM / FWTM 120.0° / 143.0° Efficiency 87 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 5050 HE FWHM / FWTM 122.0° / 145.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 120.0° / 141.0° Efficiency 88 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 5050 Square LES FWHM / FWTM 120.0° / 143.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM 120.0° / 141.0° Efficiency 88 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON HL2Z FWHM / FWTM 117.0° / 134.0° Efficiency 87 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON HL2Z FWHM / FWTM 118.0° / 136.0° Efficiency 95 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 124.0° / 147.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED NVSW219D FWHM / FWTM 120.0° / 140.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 118.0° / 138.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 116.0° / 144.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 124.0° / 144.0° Efficiency 84 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED Fortimo FastFlex LED 2x8 DA HE FWHM / FWTM 120.0° / 140.0 + 138.0° Efficiency 86 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED Fortimo FastFlex LED 2x8 DA HE FWHM / FWTM 122.0° / 140.0 + 138.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RH12 Z (LH351C) FWHM / FWTM 123.0° / 144.0° Efficiency 86 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LH351D FWHM / FWTM 123.0° / 140.0° Efficiency 91 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP PHOTOMETRIC DATA (SIMULATED): LED MJT 5050 FWHM / FWTM 121.0° / 143.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 5050 6V FWHM / FWTM 112.0° / 140.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET C13937_STRADA-2X2-C-STP GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 01/09/2022 Subject to change without prior notice Published: 28/10/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
C13937_STRADA-2X2-C-STP 价格&库存
很抱歉,暂时无法提供与“C13937_STRADA-2X2-C-STP”相匹配的价格&库存,您可以联系我们找货
    • 160+17.35496160+2.10725
    • 320+17.27386320+2.09740
    • 480+17.27348480+2.09736
    • 640+17.27309640+2.09731
    • 800+17.27272800+2.09726
