10508
    CARCLO(Carclo)
    LENS ARRAY 10MM TRPL FROST MED
10508 数据手册
B A C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 9.3 20.0 CUSTOMER DRAWING 4.6 I J E.C.N. DESCRIPTION 1 06-May-08 FIRST ISSUE 2 18-Jun-08 GATE SIZE INCREASED 3 12-Nov-08 10/08/1233 LEG PIN LENGTH REDUCED TO 1.5MM 4 10-Mar-11 04/10/1270 R&K VALUES ALTERED 4A 10-Aug-11 08/11/1306 Gate tolerance updated 1 2 12.0 8.0 2.7 2 3 5.3 3 1.8 1.5 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 0.35 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 0.1 -0.1 GATE CROP 6.9 +0.3 GENERAL TOLERANCES (UNLESS STATED) 13.9 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 B DETAIL SCALE 8:1 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 TITLE 1.9 10mm TRIPLE OPTIC MEDIUM FROSTED 1.5 2.6 DRAWN BB SIZE MATERIAL - UV STABILISED CLEAR POLYCARBONATE SCALE 1:1 A B C D E F G 10-Aug-11 10508 COIL DRG. No. A3 H 6 COIL PART No. 4:1 0.8 B 10-Aug-11 DATE SCALE SEE DETAIL 06-May-11 DATE PW APP'D 6.0 DATE MK CHK'D 6 7 5 60523 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 9.3 J E.C.N. DESCRIPTION 1 06-May-08 FIRST ISSUE 2 18-Jun-08 GATE SIZE INCREASED 3 12-Nov-08 10/08/1233 LEG PIN LENGTH REDUCED TO 1.5MM 4 10-Mar-11 04/10/1270 R&K VALUES ALTERED 4A 10-Aug-11 08/11/1306 Gate tolerance updated 1 4.6 2 2 LED LENS POSITION X3 3 3 12.0 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND 6.7 2.64 GLUE PAD X3 } TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER 2.1 LOCATION HOLE IN PCB X3 1.3 5 CARCLO 5 TITLE 6.9 10mm TRIPLE OPTIC MEDIUM FROSTED DRAWN 13.9 CHK'D 6 DATE MK DATE PW APP'D BB SIZE C D E F G H 10-Aug-11 10508 COIL DRG. No. A3 B 6 COIL PART No. 5:1 A 10-Aug-11 DATE SCALE 7 06-May-08 60523 I SHEET 3 OF 3 J 7
10508 价格&库存
很抱歉,暂时无法提供与“10508”相匹配的价格&库存,您可以联系我们找货
