CL-840-DOM100-PC
CL-840-DOM100-PC
    INTEMATIX
    LENS 80CRI 4000K 2.2" DOME 1.3"H
CL-840-DOM100-PC 数据手册
D ATA S H E E T Intematix ChromaLit 360 TM Remote Phosphor Light Source: Ellipse, Candle, Dome ChromaLit 360 light sources enable brighter, more energy efficient LED bulbs and lighting fixtures by providing wide angle lighting distribution, improved light quality, and greater design freedom. These remote phosphor light sources from Intematix provide highly uniform light distribution and are offered in a variety of lumen levels for applications in indoor and outdoor general lighting, decorative and retrofit light bulb designs. Features & Benefits Applications & Uses • High light quality with choice of CCT & CRI options • LED retrofit light bulbs • Portable consumer lighting • Uniform, glare-free light that is diffuse and offers soft shadows • Down lights • • • Reduces costs with a smaller heatsink thereby • lowering supply chain costs • Streamlined supply and production of LED lighting systems • Up to 30% higher system efficacy compared to conventional LED lighting designs • Wall sconces Pendants Chandelier and other decorative applications Appliances TA B L E O F C O N T E N T S Product Nomenclature 3 Minor Product Change Policy 3 Optical Characteristics 4 Color Binning Information 4 Relative Spectral Power Distribution 5 Intensity Distribution Diagrams 6 Performance Characteristics Over Wavelength 8 Relative Conversion Efficacy Over Temperature 8 Absolute Maximum and Minimum Ratings 10 Mechanical Characteristics 10 Reliability and Environmental Ratings 14 Handling Considerations 14 Company Information 14 Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Product Nomenclature ChromaLit 360 products are identified by the following product nomenclature: Product order code CL-ABC-DEFGH-IJ Where: A - Designates the first digit of CRI 8 = 80 CRI minimum BC - Designates the first two digits of CCT 30 = 3000K, 40 = 4000K, etc. DEF - Designates shape CAN = candle, ELP = ellipse, DOM = dome GH - Product identification number IJ - Designates the standard polycarbonate material used Example: CL-830-CAN15-PC represents ChromaLit 80CRI, 3000K CCT, Candle 15, polycarbonate Minor Product Change Policy The rigorous qualification testing of ChromaLit products ensures product performance. Slight cosmetic changes which do not affect the form fit or function of the product may occur as Intematix continues product optimization. Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Optical and Performance Characteristics1 Color Designation CL-827 CL-927 CL-830 CL-930 CL-835 CL-840 CL-750 CCT2 Color Consistency3 Min (K) MacAdam Ellipses CRI4 2700 2700 3000 3000 3500 4000 5000 3-step 3-step 3-step 3-step 3-step 3-step 4-step 80 90 80 90 80 80 70 Minimum Conversion Efficacy5 (Lm/Wrad) at 25oC Typical Conversion Efficacy5 (Lm/Wrad) at 25oC 170 155 185 160 195 200 215 180 165 200 170 205 210 225 Notes 1. Performance based on reference design. Please refer to application note for details on reference design. Intematix maintains a tolerance of +7% of luminous flux and radiant watt measurements. Intematix maintains a tolerance of 0.5 MacAdam Ellipses on color consistency measurements. 2. Correlated Color Temperature 3. Color Consistency is dependent on the AVERAGE dominant wavelength of blue LED source. ChromaLit maintains color consistency within a 3-step MacAdam Ellipse given a uniform blue LED source with a constant average wavelength. 2.5nm (+1.25nm) of average blue LED wavelength variation will provide 4-step MacAdam Ellipses of color consistency. 5nm (+2.5nm) of average blue LED wavelength variation will provide 5-step MacAdam Ellipses of color consistency. Values are approximate, please refer to bin diagram on the following page for exact bin definition. 4. Minimum Color Rendering Index rating is based on reference design using blue LEDs with average dominant wavelength of 455nm. 5. Conversion Efficacy is the luminous flux (white light) output per radiant watt of blue light input to ChromaLit. Wrad is the radiometric power measured in watts. Conversion efficacy is rated based on reference operation and dominant blue LED wavelength of 455nm (peak wavelength of 450nm). CIE y Color Binning Diagram CIE x Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Color Bin Center Points CCT (K) x y 2700 3000 3500 4000 5000 0.4578 0.4338 0.4073 0.3818 0.3447 0.4101 0.4030 0.3917 0.3797 0.3553 Relative Radiant Power (%) Relative Spectral Power Distribution Wavelength (nm) Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Intensity Distribution - Ellipse Relative Intensity Luminous Intensity Distribution Diagram1 Angle (Deg) Beam Angle (Full Angle) Maximum Intensity Angle (Half Angle) 280o 75o Luminous Intensity Polar Diagram 1 Intensity distribution pattern is characterized using CL-750-ELP60-PC products. Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Intensity Distribution - Candle Relative Intensity Luminous Intensity Distribution Diagram1 Angle (Deg) Beam Angle (Full Angle) Maximum Intensity Angle (Half Angle) 255o 70o Luminous Intensity Polar Diagram 1 Intensity distribution pattern is characterized using CL-750-CAN40-PC products. Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Intensity Distribution - Dome Relative Intensity Luminous Intensity Distribution Diagram Angle (Deg) Beam Angle (Full Angle) Maximum Intensity Angle (Half Angle) 215o 0o Luminous Intensity Polar Diagram 1 Intensity distribution pattern is characterized using CL-750-DOM60-PC products. Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Performance Characteristics over Wavelength Relative Conversion Efficacy Relative Conversion Efficacy over Wavelength1 Average Dominant Wavelength (nm) 1 Relative conversion efficacy does not reflect performance of blue LED over dominant wavelength. Relative Conversion Efficacy Performance Characteristics over Temperature ChromaLit Temperature (oC) Relative CIE Chromaticity Shift over Wavelength Average Dominant Wavelength Δ CIE X Coordinate Δ CIE Y Coordinate 450nm -0.003 -0.014 452.2nm -0.002 -0.007 455nm 0 0 457.5nm 0.001 0.005 Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. 460nm 0.001 0.008 Absolute Maximum and Minimum Ratings Description Maximum operating temperature (Tmax1) Minimum operating temperature Max storage temperature Minimum storage temperature Response time to full light output Maximum Values 110oC -40oC 110oC -40oC
CL-840-DOM100-PC 价格&库存
很抱歉,暂时无法提供与“CL-840-DOM100-PC”相匹配的价格&库存,您可以联系我们找货
